    PanelDue and Motors will not function properly with Duet Wifi
    80
    3.9k
    • Danalundefined
      Danal @firex726
      @firex726 said in PanelDue and Motors will not function properly with Duet Wifi:
      there would just be a simple setting I could flip to mirror whatever axis I want
      There are such settings. Any function of this whole setup can be flipped with a single change to config.g.
      The issue is: Endstops at which end of the machine vs. travel direction vs. homing with + or - numbers in the homing files. They all have to match each other. And the VERY first thing that has to work is CoreXY movement.
      Work through ONE of these at a time, and it can all be figured out.
      Since we can't see your printer, nor exact results of various commands, it is very difficult to remote support (btw, I'm just a customer) unless we get so very meticulous in our terminology and photos and etc that everyone gets impatient... and then there is an ever so slight miscommunication and the whole 9 way (3 axis, 3 things to get aligned with each other) thing becomes confusing again.
      Which is a really long winded way of saying: Work slowly, first movement (NO HOME), then endstops (still no home), then home to endstops and you will actually be able to figure this out faster on your own than all the interaction on the forum here.
      We will all still try to help (I've been in workshops all day, so I didn't post much earlier today)... at the same time, the "do not attempt the next thing until the first thing works" approach can iron this out in minutes.
      • firex726undefined
        firex726 @Phaedrux
        @Phaedrux said in PanelDue and Motors will not function properly with Duet Wifi:
        Alright, let's take one more shot at this.
        Please post your current config.g and homing files.
        Also please confirm where your Y endstop is located. Your photo shows X but not Y. From previous descriptions it sounds like it's located at the front as labeled on your last photo?
        Hi there,
        Here ya go... I figured I'd start with fresh config files, and a new photo for us to base things on. The labels are for where I intend the machine to think each set of coordinates is at.
        homez.g
        homey.g
        homex.g
        homeall.g
        config.g
        • Danalundefined
          Danal
          This post is deleted!
            Ok that photo looks good. Looks like the Y endstop is at the front now for Y min.
            Just noticed your drive mappings are pretty... non-standard
            M584 X3 Y4 Z2 E1 ; set drive mapping
            Don't think it really matters here, but wondering if there's rhyme to the reason? Are we dealing with a blown driver or something?
            Typically they'd be connected like so:
            M584 X0 Y1 Z2:3 E4:5:6 ; Driver 0 controls the X motor, 1 controls Y, 2 and 3 control Z motors, 4 5 and 6 control E motors
            Axis limits and endstops look correct.
            M208 X0 Y0 Z0 S1                               ; set axis minima
            M208 X280 Y280 Z280 S0                         ; set axis maxima
            M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
            M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
            M574 Z1 S1 P"zstop"                            ; configure active-high endstop for low end on Z via pin zstop
            Your homing moves look correct.
            ; homeall.g
            G91                    ; relative positioning
            G1 H2 Z5 F600          ; lift Z relative to current position
            G1 H1 X-285 Y-285 F600 ; move quickly to X or Y endstop and stop there (first pass)
            G1 H1 X-285            ; home X axis
            G1 H1 Y-285            ; home Y axis
            G1 X5 Y5 F600          ; go back a few mm
            G1 H1 X-285 F180       ; move slowly to X axis endstop once more (second pass)
            G1 H1 Y-285            ; then move slowly to Y axis endstop
            G1 H1 Z-285 F180       ; move Z down stopping at the endstop
            G90                    ; absolute positioning
            G92 Z0                 ; set Z position to axis minimum (you may want to adjust this)
            The next thing to nail down is the direction of rotation for the X/Y motors.
            M569 P3 S1                                     ; physical drive 3 goes forwards
            M569 P4 S1                                     ; physical drive 4 goes forwards
            M569 P2 S0                                     ; physical drive 2 goes backwards
            M569 P1 S1                                     ; physical drive 1 goes forwards
            Now in your setup P3 and P4 would be X and Y. This is where we'd do the G91 G1 H2 X10 and G91 G1 H2 Y10 moves and go from there.
            https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
            The testing begins with the assumption that we'd be using M569 P3 S0 and M569 P4 S0 so change those to S0 and do the movement test.
              This would also be a good time to test the endstops before even testing homing just to ensure they are configured corrected. If you trip them manually do they show as triggered in the machine status view?
              • Danalundefined
                Danal
                Curious where the X endstop is, physically?
                  I believe it's on the printhead on the HEVO. You can see the Red green black wires for the optical endstop running to it. The flag is on the left X gantry block.
                  • firex726undefined
                    firex726
                    Hi All,
                    Carriage is in the center, normally 140, 140...
                    G91 G1 H2 X10
                    Moves diagonal towards 0, 280.
                    G91 G1 H2 Y10
                    Moves diagonal towards 0, 0.
                    M569 P3 S0
                    M569 P4 S0
                    G91 G1 H2 X10
                    Moves diagonal towards 280, 0.
                    G91 G1 H2 X10
                    Moves diagonal towards 280, 280.
                    Correct, which is also why the homing speed is so slow, to give my hand time.
                    Yes, earlier when having issues with only one motor moving it ended up being the diver was blown.
                    A Former User? Phaedruxundefined 2 Replies Last reply Reply Quote 0
                      A Former User @firex726
                      you can test the switches without moving the motors, just press and hold a switch while you run M119 release switch and run M119again to confirm both states. repeat for each axis
                        jay_s_uk @A Former User
                        @firex726 Or use the machine specific settings page in DWC to watch the endstops while triggering them, rather than running M119
                        • Danalundefined
                          Danal
                            droftarts administrators @Danal
                            • Danalundefined
                              Danal @droftarts
                                Edit: Posts deleted to avoid confusion! But leaving this bit because of note about documentation.
                                He's basically doing this: https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
                                Though document needs updating to change S2 to H2 moves.
                                • Danalundefined
                                  Danal
                                  YIKES!!!
                                  Working from memory, I thought the H2 was endstop related ( as a safety net).
                                  I've deleted my above post... thanks for catching that.
                                    Phaedrux Moderator @firex726
                                    Hi All,
                                    G91 G1 H2 X10
                                    Was this with M569 P3 S1 and M569 P4 S1?
                                    G91 G1 H2 Y10
                                    M569 P3 S0
                                    M569 P4 S0
                                    G91 G1 H2 X10
                                    From the test description: If it moves towards +X and -Y, swap the X and Y motor connections.
                                    G91 G1 H2 X10
                                    I assume you mean Y10?
                                    Swap the motor connections and test again. Make sure you're using M569 P3 S0 and M569 P4 S0.
                                    • firex726undefined
                                      firex726
                                      Well that did it.
                                      Reversing the motor directions and also swapping the wiring. It'll both home and move in the correct directions now...
                                      Thanks for everyone's help!
                                      Now to clean up the wiring and calibrate it.
                                      • Danalundefined
                                        Danal
                                        Woo Hoo!!! Extremely glad to hear that things are moving in the anticipated directions, etc, etc.
                                        Woooo Hoooo!!!!
                                          I knew we'd get there eventually.
                                          • richardmckennaundefined
                                            richardmckenna
                                            Ha ha I haven't commented on this thread before but have followed it along the way. Just goes to show while building and setting up 3D printers can be very frustrating at times, if you stick with it and work through problems logically you get there in the end.
                                            I've been a member of this forum for 5 years now, active off and on and it is by far the best community I have found.
                                            For those that are far more knowledgable than I and constantly strive to help others and never giving up, like in this thread, and never getting fed up with constant "noob" questions, I thank you!
                                            On a personal note, I'm immensely grateful to have such a wealth of knowledge at my finger tips and probably would have given up on this hobby long ago.
                                            Oh dear god, I seem to have something in my eye causing it to water 😂 I'm going now lol
