    Adding a 24V safety relay for the heaters, any thoughts?
    98
    5.0k
    • Danalundefined
      Danal
      @DaBit said in Adding a 24V safety relay for the heaters, any thoughts?:
      use a sprinkler instead. Way cheaper also
      Could you expand on that? It would seem a sprinkler requires a water supply, and it is hard to see how that is cheaper.
      DaBitundefined 1 Reply Last reply Reply Quote 0
        deckingman @DaBit
        ..................... It is better than nothing, but their their effectiveness is too low. If you want actual protection instead of a good feeling, use a sprinkler instead. '.
        Better still, use a clean agent fire extinguisher as I mentioned above - much kinder to the electronics than water (or foam).
          A Former User
          But nasty to people I guess? add ventilation or oxygen alam or no big deal?
            deckingman @A Former User
            @bearer Not sure about that TBH. I don't think they are desperately harmful - at lease there are no warning stickers to that effect. It is necessary to use a size which is appropriate to the volume of space in which it is enclosed but I think that's more to do with ability to put out a fire if the extinguisher was too small. The only thing I can add is to quote from the site that I linked too above which states "Typical applications include Boats, Computer Rooms, Clean rooms, switch rooms and telecomms, Data Storage Areas and art storage rooms."
              deckingman
              .........bit more information here - https://blog.koorsen.com/a-comparison-of-the-three-most-common-fire-suppression-clean-agents-inert-novec-1230-and-fm-200 which indicates that clean agent systems are not a health risk in themselves - at least that's my take on it.
              @zapta - apologies for going off at a tangent in your thread.
                A Former User @deckingman
                @deckingman i did have a read and couldn't say for sure which gas it is and if it was lighter or heavier than the oxygen its meant to displace, in any case displaced oxygen isn't a good thing for people. how dangerous it is depends a little on how it behaves in the event of a leak. it listed nitrogen but not sure if thats just a part of it or the whole thing.
                  @bearer Yes, not sure either. But I guess faced with a room full of smoke, the best advice would be to "leg it", regardless of what the atmosphere contained in addition to the smoke and other noxious combustion products. ☺ In my own situation, the extinguisher is fitted to a fairly well sealed, enclosed "booth" which itself is inside my garage. So in the worse case scenario, I'd open the garage roller door to give plenty of ventilation before opening up the "booth" (after the fire has been extinguished of course). My main reason for fitting it was that the booth itself is made from MDF and painted, so nice and flamable ☺
                    @deckingman no, the worst case scenario is a leak or otherwise unintended discharge without a delay to allow evacuation of personnel; maybe a garage is less of an issue but given nitrogen actually kills people in industrial settings where the danger should be known I'd hesitate to recommend something like that for use in residential settings without much clearer warnings or monitoring.
                      @bearer That's true - hadn't thought about errant leakages.
                      Edit. But try as I might, I can't find any evidence that clean agent fire extinguishers are hazardous to health (unless you act really stupidly). My searches keep coming with sites such as this https://resources.impactfireservices.com/are-fire-suppression-systems-harmful-to-humans
                      TL:DR quote "These systems are generally people-safe and approved for normally-occupied rooms when designed within appropriate criteria."
                        @deckingman Maybe its better if you ask the manufacturer what the appropriate design criteria is; the US is or is looking into using nitrogen for their capital punishment - which I doubt they'd do if it didn't have some adverse health effects.
                        Maybe they have added a scent or colour to the gas, idk. But inert gasses are dangerous, even a common CO2 extinguisher can take care of both you and the fire if you use it in a small basement without some thought to your own safety.
                        • arhiundefined
                          arhi @DaBit
                          given the limited power density of the heater
                          I have 750W, 1000W and 2500W silicone heaters here on some aluminium beds ... never tested how far they can go but they get up to 100C in seconds, I would never allow them to run without meltable fuse for security. Running low power beds that would settle at max power around 100-150C is safe but I don't run those and more and more printers are made/upgraded with high power beds.
                            @bearer I appreciate your concern but extensive searches on my part don't return any causes for me to be concerned on my part. These readily available clean agent extinguishers replace Halon which is now banned in the UK for health reasons. In the worse case scenario, I'm reasonably confident that my extinguisher will put out any fire, without itself damaging the Duet boards as other system might do. At the same time, because the cylinder size is matched to the enclosure volume, I do not believe that it poses any significant health risk should it discharge inappropriately. Now I really do think that we ought not to hijack @zapta's thread any more than we have done already.
                            • zaptaundefined
                              zapta @deckingman
                              @deckingman, I find it interesting. Alternative ways to achieve same goal.
                              Edit: I would think that with electrical fire it's important to disconnect power otherwise it will keep igniting. Is it so?
                              deckingmanundefined A Former User? 2 Replies Last reply Reply Quote 0
                                deckingman @zapta
                                @zapta Quite possibly. That's why I have a smoke alarm too. That would probably go off before any fire really got hold enough to trigger the automatic extinguisher. Realistically, my printer probably has more layers of protection against fire than any of the appliances in my house - including our built in electric ovens. Prior to moving it to it's new home which is fitted with an automatic fire extinguisher, it resided in a spare bedroom without any fire extinguisher but I still slept peacefully at night. ☺
                                  A Former User @zapta
                                  @zapta said in Adding a 24V safety relay for the heaters, any thoughts?:
                                  that would probably vary quite a lot, but I'd guess more often than not, "no" as fuses would trip, flammable materials get burned up and if the fault required some logic state to start odds are that would be dead in the water.
                                  however getting the power cut would certainly be a good thing
                                  • DocTruckerundefined
                                    DocTrucker @A Former User
                                    @bearer most off the shelf fire alarms have a way to tie into other fire alarms so if one is triggered they all beep. Trying to find decent documentation on that is difficult though.
                                    There are probably off the shelf systems for industrial environments that kill power on fire detection.
                                    With UPS, the cut obviously has to be on the protected side of the batteries! 😄 😉
                                    All that said the probability of a fire starting in a well designed system with thermal fuses, well protected wiring, redundant thermistors, heater interlock, etc is minimal and a fire proof cabinate design isn't without its challenges and risks strength to resist sudden increase in pressure and where and how that pressure is vented for the first two.
                                      deckingman
                                      Anybody got a Whirlpool, Hotpoint, Indesit or Credit tumble dryer? Come on, own up - there are 5.3 million of you out there with these defective appliances. Here in the UK there are on average 60 fires a week caused by faulty appliances - mostly tumble dryers and washing machines. And of course, the recent Grenfell disaster was caused by a defective fridge/freezer. The moral of this story? Don't set the washing machine, dishwasher or tumble drier going, then go off to work or go shopping. (A bit more difficult to do with a fridge freezer though.............)
                                        DocTrucker @deckingman
                                        @deckingman risk assessment and safety on household appliances is poor in comparison to industral equipment standards. No harm in trying to do better. That said thermal fuses and resetting switches are common place even so.
                                        • DaBitundefined
                                          DaBit @Danal
                                          @Danal said in Adding a 24V safety relay for the heaters, any thoughts?:
                                          I think that is more applicable to my situation. Machines in the garage, and there is a water supply available.
                                          For the price of one AFO fireball one can buy a lot of pipe and mounting clamps, and the sprinkler heads themselves are not very expensive either.
                                          In my situation it might be a good idea. The 3D printer is not the only machine.
                                          @deckingman said in Adding a 24V safety relay for the heaters, any thoughts?:
                                          I will look into that.
                                          I am also wondering: how effective are one-shot devices when the power is not killed? Water would sooner or later trip the ground fault interrupter, and it keeps flowing (which might be a 'small' disadvantage also)
                                          @arhi said in Adding a 24V safety relay for the heaters, any thoughts?:
                                          Mine is a 600W heater on a 300x300x10mm aluminium plate. They can become way hotter than needed, but it lacks the power needed to reach autoignition-hot. I think the remaining risk after taking into account the overheating prevention of the Duet in combination with the regular SSR and relay is acceptably small. Can it be better? Sure.
                                          DocTruckerundefined 1 Reply Last reply Reply Quote 1
                                          • Danalundefined
                                            Danal
                                            Got it! That does sound like a good idea, as a final safety net.
