    Wifi problems on Mac
    30
    908
    • Jaimeundefined
      Jaime @dc42
      thanks!! was working.
      now I´m stock after entry password, I think the problem is the Macpronterface.
      any way thanks a lot for your help
        Pronterface will change all commands to capital letters, which could be messing up your SSID password.
        Best way to add an SSID is to put the commands into a macro file named ADDSSID.g on the SD card, and then send M98 Paddssid.g to run it.
        Jaimeundefined 1 Reply Last reply Reply Quote 0
        • Jaimeundefined
          Jaime @Phaedrux
          @Phaedrux hi,
          sorry could you please explain me a bit deeper? I don't have experience with macros, and I'm still stock!!
            Here are 3 options:
            • Is there a terminal emulator on your Mac? if so, use that instead of Pronterface.
            • Use Pronterface, but for every lowercase character in your SSID and password in the M587 command, prefix that character with a single quote character. This will undo the conversion to uppercase that Pronterface performs.
            • Move the SD card to a PC, then in the /gcodes folder create a file called SetNetwork.g. In that file, put the M587 command that you want to send. Save it, safely eject it, put it back in the Duet and restart the Duet. Then run M98 P"SetNetwork.g" from Pronterface.
              Let me know if the description of how to proceed from DC42 isn't enough and I can provide an example macro that you can fill in your SSID and password and use to add the network.
              • Jaimeundefined
                Jaime
                Hi guys, I still having the same problema using Windows, can´t setup the wifi.
                M552 S1
                ok
                WiFi reported error: no known networks found
                this is what I have
                  droftarts administrators @Jaime
                  @Jaime Are you working through this guide? https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
                  It sounds like it's not finding a network that it knows about to connect to.
                  If you're connected using YAT on a Windows PC, send:
                  M552 S-1 ; to stop WiFi module
                  M552 S0 ; to put Wifi into idle mode
                  M587 ; to get a list of remembered WiFi networks
                  If your network is not on the list, add it with:
                  M587 S"your-network-ssid" P"your-network-password"
                  M587 ; get list of WiFi networks to check it's there
                  M552 S1 ; to connect to the network
                  Also send M115 and post response. There is a bug in RRF 3.0 that doesn't set the password, so update to latest if using RRF 3.
                  • Jaimeundefined
                    Jaime @droftarts
                    @droftarts Thanks,
                    yes im working wth this guide, first i started with my Mac now i change to windows10, also i créate a macro with the SSD and pasword but still the same, i´m lost.
                      @Jaime Send M115, post response.
                      Copy paste the log from sending the commands in my previous post, so we can see the responses. Without information, we can't help!
                      • Jaimeundefined
                        Jaime @droftarts
                        @droftarts , ok
                        M552 S-1
                        WiFi module stopped
                        ok
                        M552 S0
                        ok
                        WiFi module started
                        M587
                        Remembered networks:
                        RED WI IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
                        RED WI-FI DE JAIME CAPLLONCH IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
                        RéD´D´E´J´A´I´M ´E´C à IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
                        Red Wifi de Jaime Capllonch IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
                        ok
                        M552 S1
                        ok
                        WiFi module is idle
                        WiFi module is idle
                        Jaimeundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                        • Jaimeundefined
                          Jaime @Jaime
                          @Jaime
                          M115
                          FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-12-24b1
                          ok
                            @Jaime said in Wifi problems on Mac:
                            RED WI
                            RéD´D´E´J´A´I´M ´E´C Ã
                            These are all different. What is the real SSID?
                            Dougal1957undefined Jaimeundefined 2 Replies Last reply Reply Quote 0
                            • Dougal1957undefined
                              Dougal1957 @droftarts
                              @droftarts is a space an acceptable character in RRF for the SSID?
                              • Jaimeundefined
                                Jaime @droftarts
                                @droftarts
                                this is the real one
                                how can I delete the others?
                                  Dougal1957 @Jaime
                                  @Jaime M588 S"ssid" I think is the correct format?
                                  Forget Network name
                                  • Jaimeundefined
                                    Jaime @Dougal1957
                                    @Dougal1957
                                    M587 S"Red Wi-FI de Jaime Capllonch"
                                    this supouse to be correct.
                                      Dougal1957 @Jaime
                                      @Jaime I think so but it is a longtime since I had to do it!
                                        Send M588 S"*" to clear the entire current list.
                                        Then send M587 S"Red Wi-FI de Jaime Capllonch" P"password"
                                        Then send M587 by itself to see if it was added to the list correctly.
                                        If the letter case wasn't preserved, you can use a macro on the SD card to add it rather than send it over USB console.
                                        • Jaimeundefined
                                          Jaime @Phaedrux
                                          @Phaedrux
                                          Awesome!! thats great WORKS!!
                                          thanks a lot.
                                            @Jaime none of the ones that were stored were correct; SSID is case-sensitive, and/or hyphen was missing!
