    RepRapFirmware road map as at 15 February 2020
    39
    2.7k
      Here is a summary of development work on RepRapFirmware planned for the near future.
      RRF 3.01, expected early March 2020
      New firmware features:
      • GCode meta commands complete, but no support for variables yet
      • Object model mostly complete
      • GCode (M409) and HTTP (rr_model) commands provided to retrieve parts of the object model
      • Daemon GCode task
      New Duet 3 hardware support:
      • Tool Board
      • Enumeration of connected expansion and tool boards
      • Triggers (M581) and wait-for-input (M577) supported on expansion and tool boards
      • Emergency Stop to shut down expansion boards and tool boards
      RRF 3.02
      • Variables in GCode meta commands
      • Support object model expressions in 12864 display menus
      • Support image buttons on 12864 display
      • Support cancelling some objects on a build plate (M486)
      • Support configuration of aux serial port either not at all (for Duet 3), in PanelDue mode (default), or in raw mode
      • Improved M303 heater tuning algorithm
      • Improved laser rastering support (multiple laser power values per G1 movement)
      • Support M303 on Duet 3 expansion and tool boards
      • Support filament monitors connected to expansion and tool boards
      • Support switch-type Z probes on expansion and tool boards
      • Report stalls from expansion and tool boards
      Later
      RPi connection option for Duet 2
      deckingmanundefined littlehobbyshopundefined 3 Replies Last reply Reply Quote 11
      • gtj0undefined
        gtj0
        Nice summary David! Thanks!
        • Danalundefined
          Danal
          Thank you!
          Is there any roadmap for DSF implementation of all above?
            deckingman @dc42
            @dc42 One quick question - are hiccups now working on expansion boards - or will they be? Some time back they weren't or not reliably - but that was a while ago. The reason for asking is that I'd like to see what combination of high micro-stepping and retraction speed I can use on my mixing hot end extruders. Alternatively, if I knew the max step pulse rate of expansion boards, I could work from that.
            • becky9undefined
              becky9
              Just curious at the current level of functionality with the tool board in the current firmware given the roadmap x
                dc42 administrators @becky9
                @becky9 said in RepRapFirmware road map as at 15 February 2020:
                Nearly everything except filament monitor, stall detection, Z probe, and automatic heater tuning.
                  dc42 administrators @deckingman
                  @deckingman said in RepRapFirmware road map as at 15 February 2020:
                  Hiccups are not reported back to the main board yet, so the main board motors may get a little ahead of expansion board motors if there are no breaks in motor movement and there are hiccups on expansion board motors. I will probably fix this in 3.02.
                  • garyd9undefined
                    garyd9
                    There was talk in the past of adding support in RRF3 to redirect certain file system related gcodes to DSF so that PanelDue could be fully utilized with a Duet3 attached to DSF.
                    Is this still on the road map?
                    • whosrdaddyundefined
                      whosrdaddy
                      @dc42 said in RepRapFirmware road map as at 15 February 2020:
                      Is the plan to have this for the existing Duet 2 boards or will this option only be available for a newer revision board?
                      • chas2706undefined
                        chas2706
                        I think it might be a good idea to concentrate on getting the dsf up to date on duet3 rpi first??
                        A Former User? dc42undefined 2 Replies Last reply Reply Quote 1
                          A Former User @chas2706
                          @chas2706 said in RepRapFirmware road map as at 15 February 2020:
                          mostly developed by different people if not mistaken it won't be detrimental to the DSF, might even be beneficial to get a larger user base providing feedback.
                          @whosrdaddy said in RepRapFirmware road map as at 15 February 2020:
                          it was said that you could in theory disconnect an ethernet module and wire that interface to a Pi once the firmware support is in place, but we'll have to wait and see I guess.
                          • Danalundefined
                            Danal
                            The Pi to Duet 3 interface is SPI. Duet 2 does bring SPI out to the expansion connector.
                            Pure speculation on my part... but I'd expect nothing will need to be removed, just hook up the SPI and run the correct firmware.
                              dc42 administrators @chas2706
                              Duet 2 will use the same DSF as Duet 3, so no additional DSF work will be needed.
                                dc42 administrators @Danal
                                @Danal said in RepRapFirmware road map as at 15 February 2020:
                                The plan in the short term is to use a Duet 2 Ethernet without the Ethernet module. The high speed SPI bus is on the socket for the Ethernet module.
                                arhiundefined tekkydaveundefined 2 Replies Last reply Reply Quote 2
                                  dc42 administrators @garyd9
                                  @garyd9 said in RepRapFirmware road map as at 15 February 2020:
                                  Yes I hope to implement that, but it needs support in DSF, which may not be implemented in time for 3.02.
                                  • littlehobbyshopundefined
                                    littlehobbyshop @dc42
                                    • Triggers (M581) and wait-for-input (M587) supported on expansion and tool boards
                                    M587 is Add WiFi network. Do you mean M577? I would very much like a 'Wait for external trigger' function
                                    BLV MGN Cube w/Hemera, K8200, Sunlu S8
                                    • botundefined
                                      bot
                                      dc42,
                                      I have an interest in beginning an effort to continue development on RRF 2 until end of life. RRF 2 in its current state is just splendid for me, and I see potential value in maintaining it as a sort of "long-term-support" firmware that users can rely on to always be available to troubleshoot or implement in mission critical machines.
                                      Do you have any thoughts about RRF 2.0 you could document before leaving it to the community? I think you did some seriously magnificent things with RRF 2, and you seem off to the races with RRF 3. A short-medium length debrief of your thoughts about how you left it and what you may have wished to implement had development continued would be super-welcomed.
                                      Thanks! You are literally one of the most important people in the RepRap community. I will continue directly supporting your products as long as you continue to produce them.
                                      *not actually a robot
                                        dc42 administrators @littlehobbyshop
                                        @littlehobbyshop said in RepRapFirmware road map as at 15 February 2020:
                                        Thanks for pointing that out. I have corrected it.
                                          deckingman @dc42
                                          Bit confused by this on the road map for RRF3.02. I already have the Metrol switch that I use as a Z (nozzle) probe configured as a simple switch (using M574) and connected to an expansion board. Did you mean "non switch-type Z probes on expansion boards? Or did you mean add type 5 to M558 for expansion boards?
                                            M574 configures it as an endstop switch, not a Z probe.
