RepRapFirmware road map as at 15 February 2020
39
2.6k
    whosrdaddy
    @dc42 said in RepRapFirmware road map as at 15 February 2020:
    RPi connection option for Duet 2
    Is the plan to have this for the existing Duet 2 boards or will this option only be available for a newer revision board?
      chas2706
      I think it might be a good idea to concentrate on getting the dsf up to date on duet3 rpi first??
      ? undefined 2 Replies Last reply 25 Feb 2020, 20:59 Reply Quote 1
        A Former User @chas2706
        @chas2706 said in RepRapFirmware road map as at 15 February 2020:
        mostly developed by different people if not mistaken it won't be detrimental to the DSF, might even be beneficial to get a larger user base providing feedback.
        @whosrdaddy said in RepRapFirmware road map as at 15 February 2020:
        it was said that you could in theory disconnect an ethernet module and wire that interface to a Pi once the firmware support is in place, but we'll have to wait and see I guess.
          Danal
          The Pi to Duet 3 interface is SPI. Duet 2 does bring SPI out to the expansion connector.
          Pure speculation on my part... but I'd expect nothing will need to be removed, just hook up the SPI and run the correct firmware.
          undefined 1 Reply Last reply 25 Feb 2020, 22:42 Reply Quote 0
            dc42 administrators @chas2706
            Duet 2 will use the same DSF as Duet 3, so no additional DSF work will be needed.
              dc42 administrators @Danal
              @Danal said in RepRapFirmware road map as at 15 February 2020:
              The plan in the short term is to use a Duet 2 Ethernet without the Ethernet module. The high speed SPI bus is on the socket for the Ethernet module.
              undefined undefined 2 Replies Last reply 26 Feb 2020, 20:52 Reply Quote 2
                dc42 administrators @garyd9
                @garyd9 said in RepRapFirmware road map as at 15 February 2020:
                There was talk in the past of adding support in RRF3 to redirect certain file system related gcodes to DSF so that PanelDue could be fully utilized with a Duet3 attached to DSF.
                Is this still on the road map?
                Yes I hope to implement that, but it needs support in DSF, which may not be implemented in time for 3.02.
                  littlehobbyshop @dc42
                  • Triggers (M581) and wait-for-input (M587) supported on expansion and tool boards
                  M587 is Add WiFi network. Do you mean M577? I would very much like a 'Wait for external trigger' function
                  BLV MGN Cube w/Hemera, K8200, Sunlu S8
                  undefined 1 Reply Last reply 26 Feb 2020, 07:54 Reply Quote 0
                    bot
                    dc42,
                    I have an interest in beginning an effort to continue development on RRF 2 until end of life. RRF 2 in its current state is just splendid for me, and I see potential value in maintaining it as a sort of "long-term-support" firmware that users can rely on to always be available to troubleshoot or implement in mission critical machines.
                    Do you have any thoughts about RRF 2.0 you could document before leaving it to the community? I think you did some seriously magnificent things with RRF 2, and you seem off to the races with RRF 3. A short-medium length debrief of your thoughts about how you left it and what you may have wished to implement had development continued would be super-welcomed.
                    Thanks! You are literally one of the most important people in the RepRap community. I will continue directly supporting your products as long as you continue to produce them.
                    *not actually a robot
                      dc42 administrators @littlehobbyshop
                      @littlehobbyshop said in RepRapFirmware road map as at 15 February 2020:
                      Thanks for pointing that out. I have corrected it.
                        deckingman @dc42
                        Support switch-type Z probes on expansion and tool boards
                        Bit confused by this on the road map for RRF3.02. I already have the Metrol switch that I use as a Z (nozzle) probe configured as a simple switch (using M574) and connected to an expansion board. Did you mean "non switch-type Z probes on expansion boards? Or did you mean add type 5 to M558 for expansion boards?
                        undefined 1 Reply Last reply 26 Feb 2020, 09:30 Reply Quote 0
                          dc42 administrators @deckingman
                          @deckingman said in RepRapFirmware road map as at 15 February 2020:
                          M574 configures it as an endstop switch, not a Z probe.
                            chas2706
                            I was referring to conditional gcode does not work on duet3 with SBC and anything regards console feedback e.g G32 does not either.
                              oozeBot
                              When will you have time to address the SD card connection issues with the PanelDue and Duet3 running from a RPi? Thanks
                              undefined 1 Reply Last reply 26 Feb 2020, 13:19 Reply Quote 0
                                dc42 administrators @oozeBot
                                @gfisher said in RepRapFirmware road map as at 15 February 2020:
                                See my earlier reply https://forum.duet3d.com/post/135146.
                                undefined 1 Reply Last reply 27 Feb 2020, 13:22 Reply Quote 0
                                  copystring
                                  Any plans for M80/M81 support for meanwell PSUs?
                                  I know I asked this before. Like many other. Is this anywhere on a plan?
                                  undefined undefined 2 Replies Last reply 26 Feb 2020, 20:29 Reply Quote 0
                                    dc42 administrators @copystring
                                    @copystring said in RepRapFirmware road map as at 15 February 2020:
                                    Do you mean to invert the PS_ON signal, or something else?
                                    undefined 1 Reply Last reply 26 Feb 2020, 20:45 Reply Quote 0
                                      copystring @dc42
                                      @dc42 Yes. This.
                                        arhi @dc42
                                        USB serial port not fast enough?
                                        undefined 1 Reply Last reply 26 Feb 2020, 23:43 Reply Quote 0
                                          gtj0 @arhi
                                          @arhi said in RepRapFirmware road map as at 15 February 2020:
                                          The idea was to keep the USB serial port free and the the SPI bus runs at 5MHz (depending on how you have it configured) and uses less resources on the Duet. Didn't make sense to develop 2 different ways to communicate between the Duets and SBC.
                                          undefined 1 Reply Last reply 27 Feb 2020, 13:57 Reply Quote 0
                                          18 out of 39
