    calculate the positions of switch, low and high
    1.4k
    • chris4undefined
      chris4 @droftarts
      @droftarts
      Thanks, do you have time to help me with config.g if it is correct?
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Feb 18 2020 18:56:18 GMT+0100 (centraleuropeisk normaltid)
      G90                                     ; send absolute coordinates...
      M83                                     ; ...but relative extruder moves
      M550 P"My Printer"                      ; set printer name
      M552 S1                                 ; enable network
      M586 P0 S1                              ; enable HTTP
      M586 P1 S0                              ; disable FTP
      M586 P2 S0                              ; disable Telnet
      M569 P0 S1                              ; physical drive 0 goes backwards
      M569 P1 S1                              ; physical drive 1 goes backwards
      M569 P2 S0                              ; physical drive 2 goes forward
      M569 P3 S1                              ; physical drive 3 goes backwards
      M584 X0 Y1 Z2 E3                        ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z2560.00 E837.08    ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00     ; set maximum instantaneous speed changes (mm/min)
      M201 X400.00 Y500.00 Z20.00 E250.00     ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30            ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                 ; Set idle timeout
      M208 X0 Y0 Z0 S1                        ; set axis minima
      M208 X230 Y210 Z200 S0                  ; set axis maxima
      M574 X1 Y1 Z1 S0                        ; set active low and disabled endstops
      M558 P0 H5 F120 T6000                   ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20                ; define mesh grid
      M305 P0 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 0
      M143 H0 S120                            ; set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 1
      M143 H1 S280                            ; set temperature limit for heater 1 to 280C
      M106 P0 S0 I0 F500 H-1                  ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45               ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 F0                        ; define tool 0
      G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
      G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
        droftarts administrators @chris4
        @chris4 Difficult to know if it's 'right'! Apart from saying it's a Cartesian printer, I know very little about the machine, eg motor, belt, leadscrew, hot end, thermistors etc etc. And I have no idea if you've wired it up correctly. If you've followed through the commissioning steps here https://duet3d.dozuki.com/Wiki/Step_by_step_guide#Section_Commissioning_tests you've got a good chance everything will be fine, and it's on to test prints and tuning.
        Couple of notes:
        With these settings, I'd guess you were using GT2 belts and 0.9º motors on X and Y. Z2560 for Z implies 1.8º motors with M8 (1.25mm pitch) leadscrews. Probably a 0.9º extruder motor.
        Your other motor settings look pretty default.
        M574 X1 Y1 Z1 S0
        Your endtops are still set 'active low'.
        T100000 B4138 is the default thermistor setting, for a Honeywell 135-104QAD-J01 thermistor that shipped with hot ends from RepRapPro, who have been out of business for 4 years! So I doubt you have the correct thermistor settings, and likely the temperature your heaters are reporting is not accurate. All 100k ohm thermistors have a resistance of 100k ohms at 25C, and will be fairly accurate at room temperature, but they report very differently as they get hotter. So please check what thermistors you have in your bed and hot end, and set them correctly, then you have a chance of accurately setting extrusion temperature.
        That's all I can see from config.g. Whether your homing gcodes are accurate is another story!
        • chris4undefined
          chris4
          @droftarts said in calculate the positions of switch, low and high:
          another story
          Thanks Ian, I have GT2 belts and 0.9º motors on X and Y and Z implies 1.8º motors with M8 (1.25mm pitch) lead screws. 0.9º extruder motor. Do you have time (another story homeall, homex, homey homez) if they are right? otherwise you can take when you have time for it.
          I fixed to 2.05.1 (2020-02-09b1)
          ; homeall.g
          ; called to home all axes
          G1 H2 Z5 F6000          ; lift Z relative to current position
          G1 H1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y5 F6000       ; go back a few mm
          G1 H1 X-235 Y-215 F360  ; move slowly to X and Y axis endstops once more (second pass)
          G1 H1 Z-205 F360        ; move Z down stopping at the endstop
          G90                     ; absolute positioning
          G92 Z0                  ; set Z position to axis minimum (you may want to adjust this)
          ;G91                    ; relative positioning
          ;G1 Z5 F100             ; lift Z relative to current position
          ;G90                    ; absolute positioning
          ; homex.g
          ; called to home the X axis
          G1 H1 X-235 F1800 ; move quickly to X axis endstop and stop there (first pass)
          G1 H2 X5 F6000    ; go back a few mm
          G1 H1 X-235 F360  ; move slowly to X axis endstop once more (second pass)
          G1 H2 Z-5 F6000   ; lower Z again
          ; homey.g
          ; called to home the Y axis
          G1 H1 Y-215 F1800 ; move quickly to Y axis endstop and stop there (first pass)
          G1 H2 Y5 F6000    ; go back a few mm
          G1 H1 Y-215 F360  ; move slowly to Y axis endstop once more (second pass)
          ; homez.g
          ; called to home the Z axis
          G1 H1 Z-205 F1800 ; move Z down until the endstop is triggered
          G1 H2 Z5 F6000    ; go back a few mm
          G1 H1 Z0 F360     ; move slowly to Y axis endstop once more (second pass)
          G1 H2 Z-5 F360    ; lower Z again
            @chris4 Homing files look okay. Good luck with your first tests!
            chris4undefined 2 Replies Last reply Reply Quote 0
            • chris4undefined
              chris4 @droftarts
              @droftarts
              Thanks Ian.
              • chris4undefined
                chris4 @droftarts
                @droftarts
                HI again Ian,
                I forgot about switch how should I connect for this configuration we talked about last time. Should I connect pin 1 and 2 (NC-C) as outermost pins on the switch on all 3 switches. And on the duet2wifi stop end 3 pin connector (pins 1 and 3) is that right?
                Thanks again
                • chris4undefined
                  chris4
                  @droftarts
                  Crash....
                  with new connection NC switches have crashed.
                  How to be LEDs on the duet2wifi card when the switch is pressed.
                  Mine lights up when the switches are pressed. should they be so?
                  I can take my settings once. left side set front view is home to my printer -X step motor to go right, must rotate backwards.
                  -Ystep motor to go from home position to front must rotate backward.
                  -Z steper motors to go up from home position must rotate forward.
                  All axes in the hom position, the switches are pressed.
                  What am I doing wrong?
                  Now I have this configuration.
                  Hope you have time with an old man.
                  Thanks Christian
                  ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Feb 28 2020 19:10:29 GMT+0100 (centraleuropeisk normaltid)
                  M569 P0 S0                              ; physical drive 0 goes backwards
                  M569 P1 S0                              ; physical drive 1 goes backwards
                  M569 P2 S1                              ; physical drive 2 goes forwards
                  M569 P3 S0                              ; physical drive 3 goes backwards
                  M92 X160.00 Y160.00 Z1600.00 E873.08    ; set steps per mm
                  M201 X500.00 Y500.00 Z20.00 E250.00     ; set accelerations (mm/s^2)
                  M574 X1 Y1 Z1 S1                        ; set active high endstops
                  M305 P1 T100000 B4092 R4700             ; set thermistor + ADC parameters for heater 1
                  ; homeall.g
                  ; homex.g
                  ; homey.g
                  ; homez.g
                  • Danalundefined
                    Danal
                    Prior to moving a machine that's had endstop configuration changes, verify switches by pressing with your finger and looking at the "Machine Specific" tab of the Web interface. You can see their triggered status go "Yes" or "No" in real time.
                    The lights help you know the switch is wired, and changing. The lights to NOT tell you if the firmware considers the switch triggered or not. The web interface does that.
                    chris4undefined 1 Reply Last reply Reply Quote 0
                    • chris4undefined
                      chris4 @Danal
                      @Danal
                      Have a little hard to understanding how is it with Endstop Location at low end high end. How can explain this to an old man.
                      If we take X axis in my case, I have home 0 for printer on left seen from the front.
                      X step motor to go right must rotate counterclockwise (backward).
                      The switch is to the left of the X axis, and connected to the NC.
                      How about the endstop which should i choose, low end or high end.
                      has drawn a sketch of it.
                      • Danalundefined
                        Danal
                        If moving the axis to bigger (positive) numbers makes it go toward the switch, the switch is at the high end.
                        If moving the axis to smaller (negative) numbers makes it go toward the switch, the switch is at the low end.
                        To keep from crashing things, do a very small move. This is easiest to do in relative mode, for example (you can enter these one at a time on the console):
                        M564 H0
                        G91
                        G1 F1000 X-10
                        The M564 allows movement without homing. The G91 is relative mode, and the G1 will move X 10 mm. Since it is negative, if X moves toward the homing switch, that switch is at the low end.
                        • chris4undefined
                          chris4
                          @Danal said in calculate the positions of switch, low and high:
                          Where is located on an X axis low end and high end.
                          On the left or right of the shaft (0 home is on the left together with the switch and the stepper motor is going from left to right on the Xaxel to move the extruder carriage)
                          One question, stepmotor motion is against the switch or vice versa when setting stepmotor motion to in drivers.
                          very complicated for me. Must learn more about this.
                          • Danalundefined
                            Danal
                            You've asked about everything EXCEPT the numeric value that moves X. And that value is THE determinant. Yes, it seems complex if you bring in left, right, counterclockwise. But... none of that matters. Push it out of your mind. Make it simple.
                            Does M564 H0 G91 G1 F1000 X-10 move the carriage TOWARD the switch? If so, that is the low end. Period. Nothing else enters into it. You can enter all three commands on one line exactly as shown. Please do that and report whether it moves toward the switch.
                            P.S. The "negative moves toward = low" is exactly what @deckingman said in the third post in this thread.
                            • chris4undefined
                              chris4
                              Thanks so much for the explanation.
                              G code M564 H0 G91 G1 F1000 X-10, nothing happens but if you do X positive, 10 moved to the right.
                              With a little more experiment , maybe I understand how it works.
                              but thanks for the help-
                              • Danalundefined
                                Danal @chris4
                                @chris4 said in calculate the positions of switch, low and high:
                                Was that toward or away from the switch?
                                  A Former User
                                  The first part of -10 nothting happens is expected ; unless you set x > 0 or allow it to move outside the axis minima it will not move below 0.
                                  The second part is correct, +10 should move to the right in a Cartesian coordinate system. The last part of the puzzle is to determine if the switch is on the far left (M574 X1) or far right (M574 X2).
                                  • chris4undefined
                                    chris4
                                    @bearer said in calculate the positions of switch, low and high:
                                    The switch is on the far left (M574 X1)
                                    and now works properly with home all.
                                    step motor goes towards the switch on the left press and x step motor stops. I continue with the calibration now, it will be a challenge for a senior, who is a bit sluggish.
                                    PS motion on stepmotor forward and backward is determined by low end and high end, or anything else, or not at all. My clever puzzle that I have to solve
                                    A Former User? Danalundefined 2 Replies Last reply Reply Quote 0
                                    • chris4undefined
                                      chris4 @Danal
                                      10 mowed to the right
                                      -10 to the left
                                        A Former User @chris4
                                        is that a question for y?
                                        if you have a printer like in the pictures where the bed moves, the confusing part may be that you're not interested in the movement of the bed, but rather the position of the nozzle on the bed. so a positive Y movement should move the bed towards the front, but the nozzles relative position would be towards the back of the bed.
                                        so the y switch at the back of the printer would trigger when the nozzle is at the front of the bed, meaning low end.
                                        (i.e. its the nozzle and coordinate system that determine motor direction, and then you set the end stop location after the motor direction is having the desired effect on the nozzle position)
                                        • chris4undefined
                                          chris4
                                          That explains some of what I couldn't. Thanks
                                          • Danalundefined
                                            Danal @chris4
                                            -10 to the left
                                            Fantastic! Combining these two answers, the negative move moved TOWARD the switch. That means the switch is on the LOW END.
                                            That means your M574 for this switch should specify X1 S1
                                            Yay! Progress!
