    calculate the positions of switch, low and high
    1.4k
      droftarts administrators @chris4
      @chris4 Can you send M115 to your Duet and post response? Just to check you're on the correct firmware version to match your config.g. Also, I'm assuming you have a Cartesian printer like the picture, not a CoreXY or something else. Usually it's best to post your hole config.g, and a brief description of your printer; see https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
      It's difficult for us to know which direction (forwards/backwards) to set motors, as it depends on wiring and which side of the pulley the belt runs. You have to test it. See https://duet3d.dozuki.com/Wiki/Test_axes_or_motors_individually
      You currently have your endstops all as 'low' (or minimum) endstops (with X1 Y1 Z1), which should be correct from the picture. You do have them set to 'Active low' with S0. 'Active high' or 'Normally Closed', set with S1, is recommended, as it's less susceptible to noise, but it depends on the wiring of your endstop. See https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Microswitch
      Test your endstops by looking at the DWC or sending M119. See https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Test_endstop_switches
      • chris4undefined
        chris4
        @droftarts said in calculate the positions of switch, low and high:
        Cartesian printer
        I'll try it.
        Yes is Cartesian printer and
        Duet WiFi 1.02 or later
        2.02(RTOS) (2018-12-24b1)
        Ihave this movement of the step motors
        -the X step motor to move from the switch, left to right, go backwards = S0
        -the Y step motor to move from the switch (back) to forward move backward = S0
        -the ZA, ZB step motor to move from the switch up, move forward S = 1
        -all the switch are NO connected
          A Former User @chris4
          @chris4 said in calculate the positions of switch, low and high:
          you'd be better off with NC, as it would prevent damage if you try to home in the event of a wire coming loose. (with NO it would never trigger, while NC it would already be triggered in the event of a fault)
          • chris4undefined
            chris4
            @bearer said in calculate the positions of switch, low and high:
            should i change to NC for all switches? outermost contacts (1-2, NC-C connection)
              As we've all said, it would be better/safer!
              Update to the latest RepRapFirmware 2, which is 2.05.1, here: https://github.com/dc42/RepRapFirmware/releases/tag/2.05.1
              To update firmware, see https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
              chris4undefined 1 Reply Last reply Reply Quote 0
              • chris4undefined
                chris4 @droftarts
                @droftarts
                Thanks, do you have time to help me with config.g if it is correct?
                ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Feb 18 2020 18:56:18 GMT+0100 (centraleuropeisk normaltid)
                G90                                     ; send absolute coordinates...
                M83                                     ; ...but relative extruder moves
                M550 P"My Printer"                      ; set printer name
                M552 S1                                 ; enable network
                M586 P0 S1                              ; enable HTTP
                M586 P1 S0                              ; disable FTP
                M586 P2 S0                              ; disable Telnet
                M569 P0 S1                              ; physical drive 0 goes backwards
                M569 P1 S1                              ; physical drive 1 goes backwards
                M569 P2 S0                              ; physical drive 2 goes forward
                M569 P3 S1                              ; physical drive 3 goes backwards
                M584 X0 Y1 Z2 E3                        ; set drive mapping
                M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
                M92 X160.00 Y160.00 Z2560.00 E837.08    ; set steps per mm
                M566 X900.00 Y900.00 Z12.00 E120.00     ; set maximum instantaneous speed changes (mm/min)
                M201 X400.00 Y500.00 Z20.00 E250.00     ; set accelerations (mm/s^2)
                M906 X800 Y800 Z800 E800 I30            ; set motor currents (mA) and motor idle factor in per cent
                M84 S30                                 ; Set idle timeout
                M208 X0 Y0 Z0 S1                        ; set axis minima
                M208 X230 Y210 Z200 S0                  ; set axis maxima
                M574 X1 Y1 Z1 S0                        ; set active low and disabled endstops
                M558 P0 H5 F120 T6000                   ; disable Z probe but set dive height, probe speed and travel speed
                M557 X15:215 Y15:195 S20                ; define mesh grid
                M305 P0 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 0
                M143 H0 S120                            ; set temperature limit for heater 0 to 120C
                M305 P1 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 1
                M143 H1 S280                            ; set temperature limit for heater 1 to 280C
                M106 P0 S0 I0 F500 H-1                  ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                M106 P1 S1 I0 F500 H1 T45               ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                M563 P0 D0 H1 F0                        ; define tool 0
                G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
                G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
                  @chris4 Difficult to know if it's 'right'! Apart from saying it's a Cartesian printer, I know very little about the machine, eg motor, belt, leadscrew, hot end, thermistors etc etc. And I have no idea if you've wired it up correctly. If you've followed through the commissioning steps here https://duet3d.dozuki.com/Wiki/Step_by_step_guide#Section_Commissioning_tests you've got a good chance everything will be fine, and it's on to test prints and tuning.
                  Couple of notes:
                  With these settings, I'd guess you were using GT2 belts and 0.9º motors on X and Y. Z2560 for Z implies 1.8º motors with M8 (1.25mm pitch) leadscrews. Probably a 0.9º extruder motor.
                  Your other motor settings look pretty default.
                  M574 X1 Y1 Z1 S0
                  Your endtops are still set 'active low'.
                  T100000 B4138 is the default thermistor setting, for a Honeywell 135-104QAD-J01 thermistor that shipped with hot ends from RepRapPro, who have been out of business for 4 years! So I doubt you have the correct thermistor settings, and likely the temperature your heaters are reporting is not accurate. All 100k ohm thermistors have a resistance of 100k ohms at 25C, and will be fairly accurate at room temperature, but they report very differently as they get hotter. So please check what thermistors you have in your bed and hot end, and set them correctly, then you have a chance of accurately setting extrusion temperature.
                  That's all I can see from config.g. Whether your homing gcodes are accurate is another story!
                  • chris4undefined
                    chris4
                    another story
                    Thanks Ian, I have GT2 belts and 0.9º motors on X and Y and Z implies 1.8º motors with M8 (1.25mm pitch) lead screws. 0.9º extruder motor. Do you have time (another story homeall, homex, homey homez) if they are right? otherwise you can take when you have time for it.
                    I fixed to 2.05.1 (2020-02-09b1)
                    ; homeall.g
                    ; called to home all axes
                    G1 H2 Z5 F6000          ; lift Z relative to current position
                    G1 H1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                    G1 H2 X5 Y5 F6000       ; go back a few mm
                    G1 H1 X-235 Y-215 F360  ; move slowly to X and Y axis endstops once more (second pass)
                    G1 H1 Z-205 F360        ; move Z down stopping at the endstop
                    G90                     ; absolute positioning
                    G92 Z0                  ; set Z position to axis minimum (you may want to adjust this)
                    ;G91                    ; relative positioning
                    ;G1 Z5 F100             ; lift Z relative to current position
                    ;G90                    ; absolute positioning
                    ; homex.g
                    ; called to home the X axis
                    G1 H1 X-235 F1800 ; move quickly to X axis endstop and stop there (first pass)
                    G1 H2 X5 F6000    ; go back a few mm
                    G1 H1 X-235 F360  ; move slowly to X axis endstop once more (second pass)
                    G1 H2 Z-5 F6000   ; lower Z again
                    ; homey.g
                    ; called to home the Y axis
                    G1 H1 Y-215 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                    G1 H2 Y5 F6000    ; go back a few mm
                    G1 H1 Y-215 F360  ; move slowly to Y axis endstop once more (second pass)
                    ; homez.g
                    ; called to home the Z axis
                    G1 H1 Z-205 F1800 ; move Z down until the endstop is triggered
                    G1 H2 Z5 F6000    ; go back a few mm
                    G1 H1 Z0 F360     ; move slowly to Y axis endstop once more (second pass)
                    G1 H2 Z-5 F360    ; lower Z again
                      @chris4 Homing files look okay. Good luck with your first tests!
                      chris4undefined 2 Replies Last reply Reply Quote 0
                      • chris4undefined
                        chris4 @droftarts
                        @droftarts
                        Thanks Ian.
                        • chris4undefined
                          chris4 @droftarts
                          @droftarts
                          HI again Ian,
                          I forgot about switch how should I connect for this configuration we talked about last time. Should I connect pin 1 and 2 (NC-C) as outermost pins on the switch on all 3 switches. And on the duet2wifi stop end 3 pin connector (pins 1 and 3) is that right?
                          Thanks again
                          • chris4undefined
                            chris4
                            @droftarts
                            Crash....
                            with new connection NC switches have crashed.
                            How to be LEDs on the duet2wifi card when the switch is pressed.
                            Mine lights up when the switches are pressed. should they be so?
                            I can take my settings once. left side set front view is home to my printer -X step motor to go right, must rotate backwards.
                            -Ystep motor to go from home position to front must rotate backward.
                            -Z steper motors to go up from home position must rotate forward.
                            All axes in the hom position, the switches are pressed.
                            What am I doing wrong?
                            Now I have this configuration.
                            Hope you have time with an old man.
                            Thanks Christian
                            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Feb 28 2020 19:10:29 GMT+0100 (centraleuropeisk normaltid)
                            M569 P0 S0                              ; physical drive 0 goes backwards
                            M569 P1 S0                              ; physical drive 1 goes backwards
                            M569 P2 S1                              ; physical drive 2 goes forwards
                            M569 P3 S0                              ; physical drive 3 goes backwards
                            M92 X160.00 Y160.00 Z1600.00 E873.08    ; set steps per mm
                            M201 X500.00 Y500.00 Z20.00 E250.00     ; set accelerations (mm/s^2)
                            M574 X1 Y1 Z1 S1                        ; set active high endstops
                            M305 P1 T100000 B4092 R4700             ; set thermistor + ADC parameters for heater 1
                            ; homeall.g
                            ; homex.g
                            ; homey.g
                            ; homez.g
                            • Danalundefined
                              Danal
                              Prior to moving a machine that's had endstop configuration changes, verify switches by pressing with your finger and looking at the "Machine Specific" tab of the Web interface. You can see their triggered status go "Yes" or "No" in real time.
                              The lights help you know the switch is wired, and changing. The lights to NOT tell you if the firmware considers the switch triggered or not. The web interface does that.
                              • chris4undefined
                                chris4 @Danal
                                @Danal
                                Have a little hard to understanding how is it with Endstop Location at low end high end. How can explain this to an old man.
                                If we take X axis in my case, I have home 0 for printer on left seen from the front.
                                X step motor to go right must rotate counterclockwise (backward).
                                The switch is to the left of the X axis, and connected to the NC.
                                How about the endstop which should i choose, low end or high end.
                                has drawn a sketch of it.
                                • Danalundefined
                                  Danal
                                  If moving the axis to bigger (positive) numbers makes it go toward the switch, the switch is at the high end.
                                  If moving the axis to smaller (negative) numbers makes it go toward the switch, the switch is at the low end.
                                  To keep from crashing things, do a very small move. This is easiest to do in relative mode, for example (you can enter these one at a time on the console):
                                  M564 H0
                                  G91
                                  G1 F1000 X-10
                                  The M564 allows movement without homing. The G91 is relative mode, and the G1 will move X 10 mm. Since it is negative, if X moves toward the homing switch, that switch is at the low end.
                                  • chris4undefined
                                    chris4
                                    @Danal said in calculate the positions of switch, low and high:
                                    Where is located on an X axis low end and high end.
                                    On the left or right of the shaft (0 home is on the left together with the switch and the stepper motor is going from left to right on the Xaxel to move the extruder carriage)
                                    One question, stepmotor motion is against the switch or vice versa when setting stepmotor motion to in drivers.
                                    very complicated for me. Must learn more about this.
                                    • Danalundefined
                                      Danal
                                      You've asked about everything EXCEPT the numeric value that moves X. And that value is THE determinant. Yes, it seems complex if you bring in left, right, counterclockwise. But... none of that matters. Push it out of your mind. Make it simple.
                                      Does M564 H0 G91 G1 F1000 X-10 move the carriage TOWARD the switch? If so, that is the low end. Period. Nothing else enters into it. You can enter all three commands on one line exactly as shown. Please do that and report whether it moves toward the switch.
                                      P.S. The "negative moves toward = low" is exactly what @deckingman said in the third post in this thread.
                                      • chris4undefined
                                        chris4
                                        Thanks so much for the explanation.
                                        G code M564 H0 G91 G1 F1000 X-10, nothing happens but if you do X positive, 10 moved to the right.
                                        With a little more experiment , maybe I understand how it works.
                                        but thanks for the help-
                                        • Danalundefined
                                          Danal @chris4
                                          Was that toward or away from the switch?
                                            A Former User
                                            The first part of -10 nothting happens is expected ; unless you set x > 0 or allow it to move outside the axis minima it will not move below 0.
                                            The second part is correct, +10 should move to the right in a Cartesian coordinate system. The last part of the puzzle is to determine if the switch is on the far left (M574 X1) or far right (M574 X2).
