    Duet 3 Tool Board
    Order discussion
    16
    44
    3.0k
      A Former User @gtj0
      @gtj0 said in Duet 3 Tool Board:
      @dc42 Although I don't see a statement to the effect, I'm assuming IO0 is meant for the Z probe and IO1 the filament sensor yeah? Can IO1 be used as an X endstop instead?
      afaik the only special function is IO0 needs to be used if connecting a PanelDue, beyond that you can configure any input to be a end stop or z probe or whatever.
      • gtj0undefined
        gtj0 @A Former User
        @bearer said in Duet 3 Tool Board:
        Yeah, that's on the main board but I know in the past there have been restrictions around having an axis's endstop on the same board as the stepper driver(s) so I wanted to make sure that if the axes motors were on the main board that the tool board's IO1 could be used as an X endstop.
        • Danalundefined
          Danal @gtj0
          Verify by trying it, but reading all the release notes, this should work.
          gtj0undefined dc42undefined 2 Replies Last reply Reply Quote 0
          • gtj0undefined
            gtj0 @Danal
            @Danal said in Duet 3 Tool Board:
            I don't have one and can't use one if it doesn't work 🙂
            @Dougal1957 said in Duet 3 Tool Board:
            @timcurtis67 you never worked PDP11's then? Mind I can go back even further to the times of an IBM 1130 which used EBCDIC punched cards or a frantic Argos 500 with handlers and punched tape.
            I have fond memories of the 1130. I can still remember the great sounds the card reader and line printer made in unison when a coldstart card was read. 🙂
            I just remembered the sound of cash registers of that era as well. Things are so damn quiet now.
            • Danalundefined
              Danal
              I have one main board (6HC), two expansions (3HC) and four tool boards (1HC). I'd be happy to give it a try for you. If you don't mind, could you describe the "test cases" you wish to see?
              gtj0undefined deckingmanundefined 2 Replies Last reply Reply Quote 0
              • gtj0undefined
                gtj0 @Danal
                That would be great! In my case, I have all of my motion (CoreXY) motors on the main board and while the Y endstop is fixed on the frame, the X endstop (actually it's a dc42 IR sensor) is on the tool carriage and senses when the tool carriage approaches the far left.
                Right now it's wired back to the main board along with the Z probe, temp sensor, and extruder heater. I just want to make sure that if the IR (or any) sensor was connected to IO1 on a tool board (actually it's just an "I" since there's no "out" pin) that it will work as an X endstop.
                  deckingman @Danal
                  @Danal Similar as @gtj0, I'd be interested to know if any of the inputs on a tool board could be used as an X or Y end stop (simple NC micro switch).
                  • mwolterundefined
                    mwolter
                    To work for me would need to connect a BLTouch, Duet Magnetic Filament Sensor, 50w heater, PT1000 RTD and an endstop. Curious to know if this is possible. Thanks!
                    Danalundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    • Danalundefined
                      Danal @gtj0
                      I have a fairly similar setup, so I truly understand the 'test case'. I won't be able to get to it tonight; should only be a day or two... he said...
                      • Danalundefined
                        Danal @mwolter
                        @mwolter said in Duet 3 Tool Board:
                        I'm about to convert my tools from thermistors to PT100s (like a PT1000, but no amp board needed). And I have a BLt. I can test this as well. Filament sensor will work on an IO port, and heater will work, those are pretty inherent to a tool board. Again, may be a day or two.
                        Would the BLt be your Z Probe? The switch endstop, for what axis is this?
                          dc42 administrators @gtj0
                          Yes to all.
                            dc42 administrators @mwolter
                            It should be possible to use the temp1 pins to connect a switch-type endstop, but I'll need to check whether the firmware supports that.
                              dc42 administrators @Danal
                              The combination that doesn't yet work is using an endstop switch connected to the main board to stop a motor connected to an expansion or tool board, when the same axis doesn't also have a motor connected to the main board. This will be fixed in firmware 3.02.
                              • gtj0undefined
                                gtj0 @dc42
                                @dc42 said in Duet 3 Tool Board:
                                Ah, the reverse case. Thanks David.
                                @Danal If you still have time to test that'd be great but not so urgent, for me anyway.
                                mundsenundefined 1 Reply Last reply Reply Quote 0
                                • mundsenundefined
                                  mundsen @gtj0
                                  Designed and printed mount for the tool board on my core xy - wireing next!4B7662FB-F941-4932-ADC3-9A4E60D7F14D.jpeg
                                  • Danalundefined
                                    Danal
                                    Looks nice.
                                    We are working on mounts for the tool board on a Hermera on a toolchanging printer, over on the Jubilee discord. I'll cross post when we have something working.
                                    We plan to mount it on the open bosses opposite the tool lock plate, and protect it so it won't get crushed if the tool is accidentally "overparked".
                                    Danalundefined 1 Reply Last reply Reply Quote 1
                                    • oliofundefined
                                      oliof
                                      the hole pattern on the tool board matches the Hemera mount points by the way, so you could just mount it to the front of the Hemera if you are not using that space. Photographic evidence on dc42's blog.
                                      • Danalundefined
                                        Danal @Danal
                                        We plan to mount it on the open bosses on the hermera opposite the tool lock plate
                                        @oliof said in Duet 3 Tool Board:
                                        Perhaps I should have included the words in italics... we are saying the same thing. One side of the Hemera mounts are occupied by the kinematic tool plate; the other by the tool board.
                                        • Danalundefined
                                          Danal
                                          Early effort, we may change this. Decided NOT to mount on the hermera itself, because it is already pushing "thickness" on that axis for "parking row" on this printer.
                                          At the moment, this little test article is on my Jubilee, being slung around, it it seems OK.
                                            A Former User @Danal
                                            I too was encountering "Packaging" issues with the tool board mounted on the extruder, my solution.
