    Setting tool offset using USB microscope
    4.4k
      dc42 administrators @TC
      @TC said in Setting tool offset using USB microscope:
      @wilriker Maybe I have understanding problems but as far as I understood the G10 in combination with a L2 or L20 does not relate to a tool.
      "Pnnn Tool number if L=1, coordinate system number if L=2 or L=20"
      How does it know which tool is meant?
      Correct, G10 with L2 or L20 is for setting workplace coordinates systems, and nothing to do with tool offsets. It's unfortunate that G10 is used for so many functions.
      • wilrikerundefined
        wilriker @TC
        @TC I'm sorry I mixed it up. 🤦
        @dc42 Would a G10 L10 to set tool offsets relative to current position desirable (making G10 even more complex OTOH)?
        Manuel
        My Tool Collection
        • Danalundefined
          Danal
          The NIST standard defines only L2. Any other L values are "proprietary" extensions of one firmware or another. Including Duet/RepRap's use of "No L parameter at all, with Ptool" to offset a tool.
          So... L10 could certainly be used... but... would make Duet/Reprap even further from the NIST standard. Given that G92 accomplishes the exact same thing in an NIST standard way... (and can become "part of the tool" by putting G92 in the pre/post files)... well... you asked DC42 and not me... but you can tell where I'm going with this: I'd say just use G92.
          Extract from NIST standard:
          3.5.5 Set Coordinate System Data — G10
          The RS274/NGC language view of coordinate systems is described in Section 3.2.2.
          To set the coordinate values for the origin of a coordinate system, program G10 L2 P … X… Y… Z… A… B… C…, where the P number must evaluate to an integer in the range 1 to 9 (corresponding to G54 to G59.3) and all axis words are optional. The coordinates of the origin of the coordinate system specified by the P number are reset to the coordinate values given (in terms of the absolute coordinate system). Only those coordinates for which an axis word is included on the line will be reset.
          It is an error if:
          • the P number does not evaluate to an integer in the range 1 to 9.
          If origin offsets (made by G92 or G92.3) were in effect before G10 is used, they will continue to be in effect afterwards.
          The coordinate system whose origin is set by a G10 command may be active or inactive at the time the G10 is executed.
          Example: G10 L2 P1 x 3.5 y 17.2 sets the origin of the first coordinate system (the one selected by G54) to a point where X is 3.5 and Y is 17.2 (in absolute coordinates). The Z coordinate of the origin (and the coordinates for any rotational axes) are whatever those coordinates of the origin were before the line was executed.
          • tekstyleundefined
            tekstyle @Danal
            @Danal
            Tool offset with limit switches would be great. I was thinking of using a camera and manually doing it, but maybe making a rig with a piezo sensor in X and another piezo sensor in Y both feed into the same module might be a better more automated solution. But is it possible to assign the result to different axis or do you have to get a module for each axis?
            Let's say I have 1 module with 3 piezo disc. 1 for Z that's used for homing Z. 1 for X and 1 for Y that's not part of the homing process. It's off in the corner away from the bed. I want T0 as referral point so I tell firmware to go to the corner for tool offset calibration to define 0,0 offset for t0. It goes to home Z for the Z offset. Then it proceeds with T1 picks it up, go to the same corner, it should show a different value for x,y that's the difference between it and T0. Then go to homeZ for z offset and does the math as well. Is this possible?
            For this to work, the side of the nozzle would have to be the trigger. If there is gunk on it, it would throw it off for obvious reasons.
            • Danalundefined
              Danal
              Couple of things:
              1) My goal is complete automation. Click one button, no touch, align all tools. I do have camera scripts that involve the human for now... but I intend to make this all work with machine vision. I have samples of that as well. See:
              https://github.com/DanalEstes/DuetPython for both human and automated scripts.
              2) Piezo is one way, but I really don't believe it adds anything that can't be also be done with a simple touchplate. See the scripts https://github.com/DanalEstes/PythonDSF and the touchplate looks like the photo below. Touch the open flat area first to get Z, then put the nozzle 1.5mm down in the hole and touch (several times) to find exact center. As you say, repeat with each tool. Then do the math and set G10 offsets. See: https://github.com/DanalEstes/PythonDSF for examples.
              Note this plate is in the corner of the bed... that was a hack just to experiment... final would be off the edge of the bed.
              As you mention, plastic is an issue. Nozzle must be heated and wiped.
              tekstyleundefined TCundefined 2 Replies Last reply Reply Quote 1
              • tekstyleundefined
                tekstyle @Danal
                @Danal that is brilliant! Didnt think of using the z piezo probe to do x and y offset. I will look to impliment something like this.
                • TCundefined
                  TC @Danal
                  @Danal Are you sure you can get the X/Y offset that precise. I am asking because it really depends on where you hit such a nozzle tip.
                  • Danalundefined
                    Danal @tekstyle
                    @tekstyle said in Setting tool offset using USB microscope:
                    There is no piezo involved. It is simple make/break a circuit between the brass nozzle and the touchplate.
                    • Danalundefined
                      Danal @TC
                      XY hits the conical side of the nozzle, not the tip. The exact taper doesn't matter, because the algorithm touches both sides. It only needs to be symmetric with itself. It does not need to be the same as the "next" or "prior" tool.
                      TCundefined 1 Reply Last reply Reply Quote 0
                      • TCundefined
                        TC @Danal
                        @Danal interesting but that requires the nozzle to be perfectly perpendicular, because otherwise you get an additional offset you dont detect, right?
                        • Danalundefined
                          Danal @TC
                          "Perfectly" is pretty strong... you are correct. it does need to be close to 90 to the surface. Eyeball of the whole hot end seems to work.
                          • TCundefined
                            TC @Danal
                            @Danal ok^^ did you already test this procedure? I find it very inspiring.
                            • Danalundefined
                              Danal @TC
                              Yes. I've been aligning this way.
                              Although... I am starved for time... and I've also been testing cameras. So I wouldn't claim any of this is perfected. Both touchplate and camera look promising.
                              • TCundefined
                                TC @Danal
                                @Danal I am working with a USB microscope right now but so far allways have to do manual fine tuning be printing test objects...
                                • Danalundefined
                                  Danal @TC
                                  My final target is full automation. I've found that the various microscopes have such a narrow field of view that "starting from scratch" with no offsets (yet), it is often true that if you put T0 over the scope, write down the coordinates (or script capture them), and put T1 in that same position, it won't even be in the field of view.
                                  Therefore, I've switched to the Logitech C270. That specific one because it has a threaded lens held captive by a dot of hot-melt (or similar). It is easy to open up, turn the lens, and get it to close focus.
                                  Anyway, using this camera, and an overlay circle (placed there with openCV), I've found that I can be repeatable to better than the tool-tool repeatability of the printer.
                                  So, yeah, no printing test objects.
                                  C270 image:
                                  1 Reply Last reply Reply Quote 4
                                  • Danalundefined
                                    Danal
                                    While this looks like the other pic, this is machine vision "finding" the end of the nozzle. This also produces a coordinate (in pixels), and you can see that averaging these over a bunch of reads can get it nailed down:
                                    316.0 240.0
                                    316.0 240.0
                                    315.88 239.88
                                    316.0 239.75
                                    316.0 240.0
                                    316.0 240.0
                                    316.0 240.0
                                    I moved the nozzle 0.1mm, and the readings (in pixels) changed to:
                                    312.0 238.0
                                    312.0 238.0
                                    appears to be about -4 x -2 pixels, so about 4.472 on the diagonal. Part of the work that needs to be done is figuring out how to "calibrate" movement in Pixels to movement in MM, when this is installed on a bunch of peoples printers, with different focus, and maybe even different cameras.
                                    timcurtis67undefined 1 Reply Last reply Reply Quote 2
                                    • tekstyleundefined
                                      tekstyle
                                      i have a raspberry pi that i used to run octoprint with marlin. i might pick up a c270 to get this to work if i can't use the current raspberry pi camera with a phone macro lens.
                                      • Danalundefined
                                        Danal
                                        My github has a script that interfaces with a Duet, that is it MUST run on a D3/Pi combo connected with SPI cable... and it has another script that will work for (almost) any printer, because that script asks you to type in the coordinates as it steps you through the alignment. Meaning the Pi need not be connected to anything (beyond the camera).
                                        So you can use whichever, if you wish.
                                        On the C270, take it apart and screw the lens in (or was it out?) until it focuses within a few inches. Works great.
                                        tekstyleundefined 1 Reply Last reply Reply Quote 0
                                        • tekstyleundefined
                                          tekstyle @Danal
                                          @Danal
                                          i got installopencv.sh installed on my raspberry pi. i have a Geany under programming. what do I do wiht the.py files? i have a duet2wifi
                                          • Danalundefined
                                            Danal
                                            For duet 2, the only one that will really work is DuetPython/toolAlignImage.py
                                            You will need either a physical console, or VNC. It has to be a screen that can display a video window. There are tons of tutorials on how to set those up. Once you have a session running on the graphics screen (not via ssh), change into that directory and enter:
                                            python3 toolAlignImage.py
                                            Within a few seconds, an image from your USB camera will appear (USB only, not PiCam). This camera should be a "close focus", and I still recommend the Logitech C270, removed from its case, and the lens screwed in (or out, I don't remember) until it focuses about 3 to 4 cm (inch and a half in barbarian units) from the lens. You can fine tune this once the camera is mounted.
                                            Once you have an image up, follow the prompts in the script. It will have you do things, and enter numbers from the web console. In reality, this will work with ANY printer that mounts tools, you can jog, and it displays positions.
                                            Roughly, it will have you jog each tool into place, and center it exactly, and enter the X and Y shown on the screen.
                                            IMPORTANT: At the beginning, it will have you enter G10 Px X0Y0 for each tool. DO NOT SKIP THIS, it is easy to miss.
                                            At the end, it will give you your G10 commands. NOTE: I MAY NEED TO UPDATE THE CALCULATIONS, I made some interesting discoveries lately. It might work... I will look at it tomorrow and let you know. (or update GIT).
                                            Example camera mount. This really should be narrower, I quickly re-used it from another project.
                                            STLs for that camera mount:
                                            upper_lid 2020 mount.stl
                                            cam_holder.stl
                                            inner_lid.stl
                                            tekstyleundefined 1 Reply Last reply Reply Quote 1
