    Fusion 360 FDM/FFF Slicing
    3D Printing General Chat
    10
    28
    3.1k
    • littlehobbyshopundefined
      littlehobbyshop
      I posted my post-processor. You can find it here:
      https://github.com/LittleHobbyShop/RRFPostProcessor
      Early changes to generic fff example:
      • Removed all pre-print homing, these should be added to start.g.
      • Replace deprecated M107 with M106 S0.
      • Replace deprecated M104 & M109 with G10 commands (untested for tool changes).
      • Removed other functions start and end scripts.
      • Append M0 to execute stop.g at end of job.
      BLV MGN Cube w/Hemera, K8200, Sunlu S8
      • gtj0undefined
        gtj0
        Nice!
        For best compatibility, you might want to add H1 to the M0 to keep the heaters on. This way cancel.g or stop.g can decide whether to turn them off or not.
        littlehobbyshopundefined dc42undefined 2 Replies Last reply Reply Quote 1
          littlehobbyshop @gtj0
          @gtj0 Good shout, I'll update it later.
            littlehobbyshop
            Update 11/03/2020
            Added post-processor properties
            • Optional layer change macro property. Executes a macro at start of each layer. Insert full path to macro as per M98 in post-processing properties window. Useful for timelapses etc.
            • Minimum layer to run layer change macro, default 2. Layer change macro will execute at the start of this layer and every layer thereafter.
            • Optional post-heat macro property. Executes a macro after heating but before print start. Insert full path to macro as per M98 in post-processing properties window. Useful for additional wipe or purge routines.
            @gtj0 Unfortunately adding H1 to M0 is pointless at the moment, the heaters are turned off automatically by the toolpath generator at the end of the routine which can't be edited. Much like the purge line. There may be a workaround, I'll keep at it.
            gtj0undefined 1 Reply Last reply Reply Quote 3
            • gtj0undefined
              gtj0 @littlehobbyshop
              @littlehobbyshop Great update! I guess we can always turn the heaters back on in a stop script if needed. When conditional gcode gets to the point where we can set global variables via Mcodes, maybe there can be an option to pass things like that to the stop script (and other) scripts.
              • zaptaundefined
                zapta
                Is the expectation that it will result in better prints because it has the exact model rather than STL approximation?
                gtj0undefined littlehobbyshopundefined 2 Replies Last reply Reply Quote 0
                • gtj0undefined
                  gtj0 @zapta
                  @zapta You would think so but it's gonna take some work to figure out whether that's the case or not.
                    littlehobbyshop @zapta
                    @zapta The big difference will hopefully come on curves. At the moment Fusion is breaking up curves into linear segments for FFF printing, much like you would get from an STL. Hopefully this will change in future as Fusion already has proper curve generation in the machining CAM. I'm yet to work out whether this is limited by the toolpath generation or whether it's something to do with the machine definition, documentation is non-existent right now.
                      littlehobbyshop
                      UPDATE 12/03/2020
                      Workaround for disabling generated toolpath control of extruder and bed heaters. Enable Heater Control (Default: Yes) decides whether the slicer should include commands to control initial warmup of the extruder and bed, followed by shut off at completion of the print. Enable for simplicity, disable if you want to use other methods (eg. the filament system) to control extruder and bed temps. The post-heat macro property remains but is not necessary if heater control is disabled, in that case any methods that would otherwise go here can be moved to start.g.
                      Re-instated M0 H1 at end of print
                      Right now this is probably as far as I can go functionality wise. the idea was always to strip out any excess gcode commands and so far that has been done so it will stay as it is until the next Fusion update or they release more documentation.
                      gtj0undefined 1 Reply Last reply Reply Quote 4
                      • gtj0undefined
                        @littlehobbyshop said in Fusion 360 FDM/FFF Slicing:
                        UPDATE 12/03/2020
                        Wait, IT'S DECEMBER ALREADY??? 🙂
                        • jens55undefined
                          jens55
                          I have never been able to understand why there are two different notations for dates.
                          Personally I think it should be 2020/3/12 🙂
                          • gtj0undefined
                            gtj0
                            Full ISO please... 2020-03-12T16:47:31-06:00
                            • jens55undefined
                              jens55
                              My bad 😞
                              Apologies all around!
                              • botundefined
                                bot
                                We should just count milliseconds since the big bang if we wanna get precise.
                                *not actually a robot
                                • jens55undefined
                                  jens55
                                  Would we be able to do that with 64 bits or do we need to go with 128 bits instead ?
                                  Maybe we should all standardize on the 'Stardate' system ?
                                  • DaBitundefined
                                    DaBit
                                    Someone stretching his neck to create an optimal RRF post for F360, and you guys start a date notation discussion?
                                    • botundefined
                                      bot @DaBit
                                      @DaBit said in Fusion 360 FDM/FFF Slicing:
                                      We paid the man his upvotes, let us have some fun.
                                      • DaBitundefined
                                        DaBit
                                        OK, granted 😁
                                        • gtj0undefined
                                          gtj0
                                          Tom just did a video on Fusion 360 Slicing...
                                          https://www.youtube.com/watch?v=J_0lLZg4JkY
                                            A Former User @gtj0
                                            @gtj0 said in Fusion 360 FDM/FFF Slicing:
                                            https://www.youtube.com/watch?v=J_0lLZg4JkY&t=338s
                                            time code to the middle deliberate? (the &t=338s bit)
