    Bimodal layer shift
    2.0k
    • spudaddictundefined
      spudaddict @NitroFreak
      @NitroFreak I pulled both stepper motors in my initial troubleshooting and verified they are solid. I extended the "D cut" on one of them to make sure the set screw was hitting the flat. At this point I am not discounting anything, but I did pull and verify tight fit on both motors. I will try pulling them again this weekend.
      • NitroFreakundefined
        NitroFreak
        @spudaddict said in Bimodal layer shift:
        Try marking the side of the pulley to the stepper shaft with a marker and observe during the print if the line shifts.
        Especially observe the stepper that is responsible of the 45 degree motion that is in the direction of the shift.
        I´m 100% sure that this is not a normal skipped step from the stepper because it is too uniform and back and forth to the exact same space, does not happen.
        spudaddictundefined 1 Reply Last reply Reply Quote 0
        • Danalundefined
          Danal
          Carefully check the entire length of the belts. I've found stretched spots that are REALLY hard to see, and if they were in "one end" vs. "the other" it could explain the good/bad pattern across the bed.
          • DigiDundefined
            DigiD
            Check that the ribs on the belts are not worn more in one section vs another , look for rubber dust as a sign of wear .
            I had that happen on my delta and it caused all kinds of mysterious issues with travel being ok then not ok .
            I actually saw the belt ribs ( the 3/4 worn ones ) riding on top of the drive pulley teeth rather than in between !
            • mrehorstdmdundefined
              mrehorstdmd
              Is this a corexy printer? Do the belt tensions vary with the extruder position in the XY plane?
              JamesMundefined spudaddictundefined 2 Replies Last reply Reply Quote 0
              • JamesMundefined
                JamesM @mrehorstdmd
                @mrehorstdmd
                The BLV cube is a corexy printer....I have built one myself and don't have these issues.
                @spudaddict
                If you have a duet board in your printer(which I assume since you posted here) I would run an M122 command during a print that is having these issues and look to see if any "hiccups" are reported which could translate into missed steps.
                I would post up your config.g file so people here could review it and see if anything sticks out.
                I do agree with the others who have posted that it seems more like a mechanical issue since it is worse in different locations on the print bed.
                mrehorstdmdundefined spudaddictundefined 2 Replies Last reply Reply Quote 0
                  mrehorstdmd @JamesM
                  @JamesM Thanks, but I'd still like to hear what @spudaddict has to say. Self built printers are seldom identical, even if they start from the same set of plans/BOM. People make part substitutions and design changes all the time. Print quality varying with bed position is exactly the sort of problem you would expect from belts being improperly laid out, evidence of which is varying belt tension as the extruder carriage moves around.
                  NitroFreakundefined spudaddictundefined 2 Replies Last reply Reply Quote 0
                    NitroFreak @mrehorstdmd
                    @mrehorstdmd said in Bimodal layer shift:
                    Thats a good point, thats true.
                    However belt tension would have a very sloppy effect on print quality, but just check the first red tower, the sections that are shifted within themselves are very properly aligned
                      spudaddict @mrehorstdmd
                      @mrehorstdmd As James M said, it is a CoreXY. I am not sure how I would measure tension variation on a moving belt - open to suggestions. IF the x and y rails are orthogonal there should be no tension variation. The strange thing is that in between the red tube print and the drag chain print, the printer made a perfect moai (Thingiverse: 144668). Its at work so I cant pull up a photo. Also, the "good" zones seem to move around the bed.
                        spudaddict @Danal
                        @Danal The belt is new, but I will do as you suggest. There are 2 belts on a CoreXY so I can easily check between them when I tear it down this weekend. I also have a new set of belts I may try as well.
                          spudaddict @DigiD
                          @DigiD The belts are new, but I will definitely look them over. I also have a new set of belts I may try this weekend as well.
                            @NitroFreak I absolutely agree, which is why I ruled out most layer shifting "fixes." The pattern varies by location on the bed, is at random heights, but has two endpoints and then reverses back to the first layer origin. Very strange but specific.
                              spudaddict @JamesM
                              @JamesM I will run a print tonight and try the M122 command. I too think it is mechanical, but I cant wrap my head around what it could be.
                                @mrehorstdmd See my reply to you above. A fellow 3D enthusiast from work built the same printer in tandem as I built mine. His BLV cube does not have this issue either. I'm not sure how to measure belt tension - maybe put a spring on the end and measure an elongation?
                                  @NitroFreak Thats what is killing me! How is it so perfectly sloppy? 🙂
                                    spudaddict @spudaddict
                                    @spudaddict Here is a photo of the best and the worst pieces from the drag chain print. They were in diagonally opposite corners... which seems to indicate a mechanical issue due to the CoreXY configuration.IMG_0924[1].JPG
                                    These were printed at the same time just 150mms or so apart.
                                      @spudaddict Config.g
                                      ; generated by RepRapFirmware Configuration Tool v2.0.4 on Wed Oct 02 2019 19:29:38 GMT-0600 (Mountain Daylight Time)
                                      M550 P"Wyrm Forge" ; set printer name
                                      M667 S1 ; select CoreXY mode
                                      M552 S1 ; enable network
                                      M586 P0 S1 ; enable HTTP
                                      M586 P1 S0 ; disable FTP
                                      M586 P2 S0 ; disable Telnet
                                      M569 P0 S0 ; physical drive 0 goes 0=backwards, 1=forwards
                                      M569 P1 S0 ; physical drive 1 goes
                                      M569 P2 S1 ; physical drive 2 goes
                                      M569 P3 S1 ; physical drive 3 goes
                                      M92 X79 Y158.88 Z809.21 E108.90 ; set steps per mm X is 158.88 with 0.9 stepper replaced
                                      M203 X18000.00 Y18000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                                      M201 X3000.00 Y3000.00 Z100.00 E9000.00 ; set accelerations (mm/s^2)
                                      M906 X1700 Y1700 Z800 E1400 I30 ; set motor currents (mA) and motor idle factor in per cent
                                      M84 S30 ; Set idle timeout
                                      M208 X-28.0 Y-6.0 Z0 S1 ; set axis minima
                                      M208 X320 Y320 Z460 S0 ; set axis maxima
                                      M574 X1 Y1 S1 ; set active high and disabled endstops
                                      M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                                      M558 P9 H4 F120 T9000 ; set Z probe type to bltouch and the dive height + speeds
                                      G31 P500 X8.1 Y-61.1 Z1.36 ; set Z probe trigger value, offset and trigger height
                                      M557 X30:250 Y30:250 P7
                                      ;M557 X10:320 Y10:360 P7 ; define mesh grid
                                      M143 H0 S140 ; set temperature limit for heater 0 to 140C
                                      M307 H1 A987.5 C204.5 D8.4 S0.85 V24.1 B0 ; set A=gain, C=heat time, D=dead time, S=power %, V=voltage, B0=bang bang
                                      M563 P0 S"Right" D0 H1 F0 ; define tool 0
                                        mrehorstdmd
                                        Belt tension doesn't have to be checked while it's moving. Simply move the extruder carriage around manually- you'll feel any variations in tension.
                                        How about some photos or your BLV cube?
                                        Are you, by any chance, using steel core belts?
                                          @mrehorstdmd I tried steel belts on a modified Anet A8, they were terrible. Currently have fiberglass backed belts on it and have a coupe nylon corded rubber ones to try out.
                                          I reprinted my tubes design. The offsets are much smaller. I was able to force the front right tube to offset by pressing and pulling the print head. Still troubleshooting...
                                          My BLV is a bit hacked up since I have been swapping out motors, moving wires, inspecting belts and cannibalizing my A8 bed parts... but here ya go.
                                            mrehorstdmd @spudaddict
                                            @spudaddict That first photo at the top of this thread looks like something is shifting by a mm or two. There has to be something loose. Can you detect any play at all in the bearing blocks on the linear guides? Are the pulley axles solidly mounted? Grab the heater block on the hot-end and try to wiggle it.
                                            Try pushing on the bed and see if you can make it wiggle.
                                            The frame has an open front in that design for some reason. Does it flex when you push the two top corners toward each other?
                                            spudaddictundefined Danalundefined 2 Replies Last reply Reply Quote 0
