    Bimodal layer shift
    2.0k
    • JamesMundefined
      JamesM @mrehorstdmd
      @mrehorstdmd
      The BLV cube is a corexy printer....I have built one myself and don't have these issues.
      @spudaddict
      If you have a duet board in your printer(which I assume since you posted here) I would run an M122 command during a print that is having these issues and look to see if any "hiccups" are reported which could translate into missed steps.
      I would post up your config.g file so people here could review it and see if anything sticks out.
      I do agree with the others who have posted that it seems more like a mechanical issue since it is worse in different locations on the print bed.
      mrehorstdmdundefined spudaddictundefined 2 Replies Last reply Reply Quote 0
      • mrehorstdmdundefined
        mrehorstdmd @JamesM
        @JamesM Thanks, but I'd still like to hear what @spudaddict has to say. Self built printers are seldom identical, even if they start from the same set of plans/BOM. People make part substitutions and design changes all the time. Print quality varying with bed position is exactly the sort of problem you would expect from belts being improperly laid out, evidence of which is varying belt tension as the extruder carriage moves around.
        NitroFreakundefined spudaddictundefined 2 Replies Last reply Reply Quote 0
        • NitroFreakundefined
          NitroFreak @mrehorstdmd
          @mrehorstdmd said in Bimodal layer shift:
          Thats a good point, thats true.
          However belt tension would have a very sloppy effect on print quality, but just check the first red tower, the sections that are shifted within themselves are very properly aligned
          spudaddictundefined 1 Reply Last reply Reply Quote 0
          • spudaddictundefined
            spudaddict @mrehorstdmd
            @mrehorstdmd As James M said, it is a CoreXY. I am not sure how I would measure tension variation on a moving belt - open to suggestions. IF the x and y rails are orthogonal there should be no tension variation. The strange thing is that in between the red tube print and the drag chain print, the printer made a perfect moai (Thingiverse: 144668). Its at work so I cant pull up a photo. Also, the "good" zones seem to move around the bed.
              spudaddict @Danal
              @Danal The belt is new, but I will do as you suggest. There are 2 belts on a CoreXY so I can easily check between them when I tear it down this weekend. I also have a new set of belts I may try as well.
                spudaddict @DigiD
                @DigiD The belts are new, but I will definitely look them over. I also have a new set of belts I may try this weekend as well.
                  spudaddict @NitroFreak
                  @NitroFreak I absolutely agree, which is why I ruled out most layer shifting "fixes." The pattern varies by location on the bed, is at random heights, but has two endpoints and then reverses back to the first layer origin. Very strange but specific.
                    spudaddict @JamesM
                    @JamesM I will run a print tonight and try the M122 command. I too think it is mechanical, but I cant wrap my head around what it could be.
                      @mrehorstdmd See my reply to you above. A fellow 3D enthusiast from work built the same printer in tandem as I built mine. His BLV cube does not have this issue either. I'm not sure how to measure belt tension - maybe put a spring on the end and measure an elongation?
                        @NitroFreak Thats what is killing me! How is it so perfectly sloppy? 🙂
                          spudaddict @spudaddict
                          @spudaddict Here is a photo of the best and the worst pieces from the drag chain print. They were in diagonally opposite corners... which seems to indicate a mechanical issue due to the CoreXY configuration.IMG_0924[1].JPG
                          These were printed at the same time just 150mms or so apart.
                            @spudaddict Config.g
                            ; generated by RepRapFirmware Configuration Tool v2.0.4 on Wed Oct 02 2019 19:29:38 GMT-0600 (Mountain Daylight Time)
                            M550 P"Wyrm Forge" ; set printer name
                            M667 S1 ; select CoreXY mode
                            M552 S1 ; enable network
                            M586 P0 S1 ; enable HTTP
                            M586 P1 S0 ; disable FTP
                            M586 P2 S0 ; disable Telnet
                            M569 P0 S0 ; physical drive 0 goes 0=backwards, 1=forwards
                            M569 P1 S0 ; physical drive 1 goes
                            M569 P2 S1 ; physical drive 2 goes
                            M569 P3 S1 ; physical drive 3 goes
                            M92 X79 Y158.88 Z809.21 E108.90 ; set steps per mm X is 158.88 with 0.9 stepper replaced
                            M203 X18000.00 Y18000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                            M201 X3000.00 Y3000.00 Z100.00 E9000.00 ; set accelerations (mm/s^2)
                            M906 X1700 Y1700 Z800 E1400 I30 ; set motor currents (mA) and motor idle factor in per cent
                            M84 S30 ; Set idle timeout
                            M208 X-28.0 Y-6.0 Z0 S1 ; set axis minima
                            M208 X320 Y320 Z460 S0 ; set axis maxima
                            M574 X1 Y1 S1 ; set active high and disabled endstops
                            M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                            M558 P9 H4 F120 T9000 ; set Z probe type to bltouch and the dive height + speeds
                            G31 P500 X8.1 Y-61.1 Z1.36 ; set Z probe trigger value, offset and trigger height
                            M557 X30:250 Y30:250 P7
                            ;M557 X10:320 Y10:360 P7 ; define mesh grid
                            M143 H0 S140 ; set temperature limit for heater 0 to 140C
                            M307 H1 A987.5 C204.5 D8.4 S0.85 V24.1 B0 ; set A=gain, C=heat time, D=dead time, S=power %, V=voltage, B0=bang bang
                            M563 P0 S"Right" D0 H1 F0 ; define tool 0
                              mrehorstdmd
                              Belt tension doesn't have to be checked while it's moving. Simply move the extruder carriage around manually- you'll feel any variations in tension.
                              How about some photos or your BLV cube?
                              Are you, by any chance, using steel core belts?
                                @mrehorstdmd I tried steel belts on a modified Anet A8, they were terrible. Currently have fiberglass backed belts on it and have a coupe nylon corded rubber ones to try out.
                                I reprinted my tubes design. The offsets are much smaller. I was able to force the front right tube to offset by pressing and pulling the print head. Still troubleshooting...
                                My BLV is a bit hacked up since I have been swapping out motors, moving wires, inspecting belts and cannibalizing my A8 bed parts... but here ya go.
                                  mrehorstdmd @spudaddict
                                  @spudaddict That first photo at the top of this thread looks like something is shifting by a mm or two. There has to be something loose. Can you detect any play at all in the bearing blocks on the linear guides? Are the pulley axles solidly mounted? Grab the heater block on the hot-end and try to wiggle it.
                                  Try pushing on the bed and see if you can make it wiggle.
                                  The frame has an open front in that design for some reason. Does it flex when you push the two top corners toward each other?
                                  spudaddictundefined Danalundefined 2 Replies Last reply Reply Quote 0
                                  • JamesMundefined
                                    JamesM
                                    Did my eyes deceive me or do you have a 1.8deg stepper on X and a 0.9deg stepper on Y looking at your config.g and the steps/mm??? I'm guessing by the heatsinks on the stepper drivers that it is a clone duet board since the standard duets don't come with them. If that's the case I would put some active cooling on that board since the clones generally have only 1/2 the amount of copper in the pcb compared to the real duet boards.
                                      @mrehorstdmd Yes, this last round seems to have much less shift.
                                      I can detect some rotating on the "Y" bridge, but takes some force. (pushing forward on the left end, pulling on the right at the same time - and visa versa) I tried doing that during a print with long lines (a large box) and it didn't seem to have an effect. The open front has bothered me since before I began the build. They will flex a little if the Y bridge is near the back, less flex when it is near the front.
                                      I DO get some wiggling on the nozzle in the Y direction. Not sure how that can create a diagonal offset, but I plan on reprinting the head assembly today/tomorrow with stiffer supports. The X and Y MGN carriages seem solid.
                                      Thank you for your continued suggestions. I will see what reducing the print head wiggle brings.
                                        spudaddict @JamesM
                                        @JamesM lol... yes. Sharp eyes.
                                        My only spare 2A stepper motor is for the 2nd filament driver(1.8deg). I swapped it into both the X and Y positions to see if there was a motor issue and need to pull it back out. I tried the M121 command near the end of the gray tube print and there were zero errors and zero hiccups - so likely a mechanical issue.
                                        When the back cover is on, the 4x120 fans move a lot of air across the Duet board, but I have had the cover off since I started troubleshooting. I will put a fan on and under it next.
                                        Thank you for your help and suggestions.
                                        • Danalundefined
                                          Danal @mrehorstdmd
                                          Good catch. That looks REALLY suspicious. Given the nature of the layer shift, specifically that a few layers are "this way" and a few more "that way", it would seem that something is flexing or stretching, ONLY when some part of the printer is at "one end" vs the other, AND that the slicer is doing a few layers with all "strokes" moving in one direction... and then a few more layers the opposite way.
                                          And... all of that would fit VERY well with that open front moving, when the crossbar is not there to brace it.
                                          Perhaps try bolting a temporary brace across that opening, and reprint?
                                            spudaddict @Danal
                                            @Danal Morning Danal. I am not ruling anything out at this point, but a couple considerations:
                                            There are two cross bars near the bottom (not ideal) that are rigid - so any flexing would require the vertical 2040 extrusions to actually bend against the 40mm width. Im not sure there is anything that happens during normal operation of the printer that can generate that much force.
                                            Also, the Y bridge works to hold the width steady since it cannot get longer/shorter as it travels front to back... as long as the MGN rail alignment is correct.
                                            I am going to put a temp brace on as you suggested, but I suspect what I will get is confirmation that my MGN alignment is either right or wrong. If it is wrong and the top is now absolutely rigid - the Y bridge should bind up. Badly.
