    Compiled Firmware with 5bar-Scara / Dual-Arm-Scara
    Firmware installation
    8
    67
    3.7k
      dc42 administrators @Enpixa
      @Enpixa said in Compiled Firmware with 5bar-Scara / Dual-Arm-Scara:
      Is it bad configuration, bad hardware or maybe a failure in math fo firmware ?
      I think as there is a trinsmission now that 71.1 steps / mm is too low now, could this cause this behavior ?
      If the firmware is know to work on another machine, then most likely bad calibration and/or incorrect steps/degree IMO.
      • JoergS5undefined
        JoergS5 @Enpixa
        @Enpixa I checked your config, I don't see an error.
        Please tell me your stepper types (200 or 400 steps), pulley and big wheel teeth count, I'll setup the same configuration like you and process your tests.
        • bondusundefined
          bondus
          @Enpixa , those bends moving along X sure looks like your steps/mm (actually steps/deg in this case) is wrong. The arms are in a totally different place than what the kinematics thinks.
          Here is a very small google calc sheet to do the calculation: https://docs.google.com/spreadsheets/d/1BcMlqXXdEnmlkF_0ODQ4IW8XYK3qm9ZIXIymVJUUBbo/edit?usp=sharing
          • Enpixaundefined
            Enpixa
            Hello All,
            I disassembled the prototype and checked the steppers. It needs 200 steps per Revolution
            ( checked it by setting microsteps to Fullstep (1) and set it to 200steps per mm )
            M350 X1
            M92 X200
            and did a G1 X1 and it was exactly on complete Turn for the stepper. (Did the test for both Steppers to be sure)
            Small Pulley got 20 teeth. large Pulley got 90 teeth.
            I used Bondus formula-Sheet and came to 320steps
            Part of Config.g
            ;---------------- AXIS LIMIT ---------------------------------------
            M208 X-1300 Y-1300 Z-1000 S1 ; Set axis minima
            M208 X1300 Y1300 Z1000 S0 ; Set axis maxima
            ;---------------- MAIN SETTINGS -------------------------------------------------------
            M669 K9 L2 X0:70 Y0:0 P262:262 D262:262:40:0 B143:37 A10:170:0:360:0:360 C-90:270:-90:270
            M350 X128 Y128 Z128 E16 I1 ;S3 ; Configure microstepping with interpolation
            M92 X320 Y320 Z320 E95.2 ; Set steps per mm*
            used this home5barscara.g
            G91 ; relative positioning
            G1 H1 X-500 F1000 ; move quickly to endstop and stop there (first pass)
            G1 H1 Y500 F1000 ; move quickly to endstop and stop there (first pass)
            G92 X0
            G92 Y-285
            G92 Z0
            When i run this simple Square.gcode
            G1 X30 Y-160 F2000
            G1 X30 Y-160 F2000
            G1 X30 Y-100 F2000
            G1 X-30 Y-100 F2000
            G1 X-30 Y-160 F2000
            i get this result:
            It seems like i get some kind of 2:1 ratio for X:Y ( Did a different test with Moving G1 Y100 it was about 10cm and Moving G1 X30 was about 6cm )
            Also this "Square" looks like a 2:1 rectangle (some kind of 😊 :))
            I am not sure about the Home5barscara value for the G92 Y ( tried many different. often gives me not reachable area when starting from different Y-Positions. When homed the hotend-spot is 285 mm away from the Rods along Y-axes.
            Also tried instead of M669 K9 L2 X0:70 a different version with M669 K9 L2 X-32.5:32.5 (measured again it is 65mm apart) the "rectangle was centered better to the X-Homepoint but basically the same result. Also checked the angle of the arms again when homed. B143:37 ( i think this should sum up to 180 as it is symmetrically on X,please let me know if i am wrong )
            • bondusundefined
              bondus
              G92 X0
              G92 Y-285
              I did a quick test, and as I suspected the kinematics does not handle G92 X and Y as expected. Try removing them from your homing script. Keep the G92 Z0. The firmware will calculate X and Y of the actuator on it's own. If you want to move the world coordinates X0 Y0 use M669 X and Y to move the inner proximal joints instead .
              This might bug in the kinematics, I'm not sure how the firmware kinematics is supposed to handle this. It could be that the non-linear kinematics, deltas and scaras, assumes that you have actually moved the motors to the position given in G92.
              And BTW, Y coordinates are positive towards the front of the machine (the arm side). Your G92 Y-285 told the machine it's arms were on the backside. The, in practice unreasonable, work mode 2 position for that would be: X0Y-285.png
              It's a fun kinematics 🙂
              • Enpixaundefined
                Enpixa
                Hello Bondus,... thx alot.....
                i removed the G92 X & Y from home5barscara.gcode
                and changed in config.g to:
                M669 K9 L2 X-32.5:32.5 Y285:285 P262:262 D262:262:25:0 B143:37 A10:170:0:360:0:360 C-90:270:-90:270
                in that case, as i would expect to be a "normal" situation, -X moves left and +X moves right (looking from steppers in direction to hotend) and +Y moves the hotend away from stepper. But doesnt solve the problem. Still looks like a 2:1 ratio.
                If i negate the M669 Y Value (to -285:-285) the directions of the whole machine invert.
                Maybe this information helps to find what is causing the problems 🙂
                JoergS5undefined 4 Replies Last reply Reply Quote 0
                • bondusundefined
                  bondus
                  @Enpixa , I think your motors run in the wrong direction. Looking at your homing file I see that you home X(left arm) using a move towards negative, but that arm homes at a big angle. Same for Y, but opposite.
                  Modify your M569s and the homing file.
                  • JoergS5undefined
                    JoergS5 @Enpixa
                    @Enpixa I am confused why you set Y285:285, this sets your actuators into the print bed.
                    • JoergS5undefined
                      JoergS5 @Enpixa
                      @Enpixa I will setup my Scara with your parameters at the weekend, please tell me which configuration you have right now und the G-Code of your test "prints".
                      • bondusundefined
                        bondus
                        Here are some parts of my configuration file if it helps:
                        M350 X128 Y128 Z16 E16 I1        ; Configure microstepping with interpolation
                        ; Left homes at 180deg, Right at 0deg
                        M669 K9 X-93:93 Y-205:-205 L2 A10:170:0:360:0:360 C-90:270:-90:270   P134:134 D205.00:205.00:0:0 B180:0
                        ; Old machine, more sensible limits. Right homing sensor is between arms
                        ; M669 K9 X-54:54 Y-192:-192 L2 A10:170:-90:360:-90:360 C34:251:-71:146   P161.00:162.00 D206.00:208.00 B226.01:152.21
                        ; 400/360 * 128 * 263 / 16
                        M92  X2337.777778  Y2337.777778  Z800.00 E420.00   ; Set steps per mm/deg, 128micro
                        M208 X-350 Y-350  Z0  S1                 ; Set axis minima
                        M208 X350 Y350 Z188.2 S0                 ; Set axis maxima
                        M569 P0 S1   ; X Drive 0
                        M569 P1 S1   ; Y Drive 1
                        • JoergS5undefined
                          JoergS5 @bondus
                          @bondus Thank you.
                          I changed the documentation by some of the items discussed here. After resolving this issue here I want to implement work mode 3 also, and I am looking for a solution how to change work modes automatically.
                          bondusundefined 1 Reply Last reply Reply Quote 0
                          • bondusundefined
                            bondus @JoergS5
                            @JoergS5 Work mode 3 is implemented. It is a pretty strange work mode, you will need very specialised arm lengths to get any reasonable work space.
                            I tried work mode 1 and 4 or my new machine yesterday, they work perfectly fine.
                            I experimented a few weeks ago with some work mode switching on a toy scara machine run by a Teensy board. I had copy-paste ported our code to run outside RRF.
                            I think that switching can safely be done if done in the right order. Mode 1 can move to mode 2 or 3, mode 2 can move to mode 1 or 4, mode 4 can move to mode 1 or 3. Basic rule is that if you flip one proximal-distal arm joint at a time it will be safe. By flip I mean to change from the range 0-180 deg to 180-360 deg.
                            The work mode switching order would be 1-2-4-3-1-... , any direction is allowed.
                            Exactly when, how and why to do a switch I'm not sure. Except that it's fun.
                            If you want to be very brave and flip the actuator joint with a dynamic move that's a very different story 😉 The firmware does not support the other 4 work modes you have on the other "side".
                            I'll dig up some old pics I made a long time ago ...
                            • JoergS5undefined
                              JoergS5 @bondus
                              @bondus I expect work mode 3 not supported because in the source for L:
                              if (!(workmode == 1 || workmode == 2 || workmode == 4))
                              error = true;
                              return true;
                              so for workmode == 3 will be an error. (My fault, I excluded it, because of missing testing).
                              For changing work modes, my thoughts are:
                              every workmode has a safe print area which can be defined for given allowed angles and arm lengths. When changing work mode, a moving path through overlapping areas is a safe path. Moving without printing is safe, but printing while changing workmode is unresolved (the print move must be splitted, either from firmware or in the G-Code). When changing the workmode, all singularity areas must be avoided.
                              My wish to use workmode 3 is:
                              below = below printbed, above = above, perpendicular = steering bars.
                              The reason is to save space in x-y dimension.
                              (To explain: perpendicular is not the proximal arm, but a vertical bar, rigidly connected to the distal arm. The proximal arm is the big plate with a ball bearing inlcuded at the edge. The big plate get a 1:30 gear ratio with the stepper)
                              I want to include your formula and spreadsheet for calculating the stepper setting into the documentation, I'll do that in the next update.
                              • bondusundefined
                                bondus
                                An interesting idea, thinking out of the box.
                                For a work mode change to work today you would have to move the arms as close to the switch point as possible, use a G0 H2 to nudge the arm over to the other side and then reconfigure with an M669. It will lose homing though. We could (ab)use M666 instead, with different parameters. A bit hacky, but it will work for testing.
                                I'm working a bit with IsContinuousRotationAxis() and related angle logic. As it is today the firmware may select to take the "back route" with the motors, totally ignoring all angle limits. Some machines can do that, others can not.
                                We are kidnapping @Enpixa's thread.
                                • JoergS5undefined
                                  JoergS5 @bondus
                                  @bondus Nice protoype, and yes, we can start a new thread for "freedom of workmodes". => I'll start a thread for workmode 3, describing my prototype
                                  • JoergS5undefined
                                    JoergS5 @Enpixa
                                    @Enpixa I expect I've found a configuration error: the M574 settings seem to be wrong: according to your setup image and https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_Set_endstop_configuration the left X actuator is a high endstop, the right Y one is a low end endstop.
                                    So the commands should be:
                                    M574 X2 S1...
                                    M574 Y1 S1... (today in your config set to Y2).
                                    With printing outside of the print area (angle is outside of the max endstop if Y2 is set), if it behaves like a scara printer, it would make G0 unsegmented moves = curved, which would explain your curved moves. (like in https://forum.duet3d.com/topic/13018/scara-problem)
                                    Could you try this please? And the other possible problem are the steppers which are face down, changing the direction.
                                    • JoergS5undefined
                                      JoergS5 @Enpixa
                                      @Enpixa I found an additonal possible cause:
                                      from https://duet3d.dozuki.com/Wiki/Gcode#Section_G0_G1_Move
                                      RepRapFirmware treats G0 and G1 in the same way 'except as follows:
                                      On SCARA and similar architectures that normally require linear motion to be approximated by short segments, a single continuous non-segmented movement will be used if this can be done without the print head dropping below the current Z height. (My understanding is: for a non-extrusion move it uses an unsegmented move, curved in case of a Scara, if there is no danger to destroy something already printed. In general it would be no problem because the move simply wants to go from A to B, without interest which path it uses - i.e. no pen attached... With your pen you extrude without an extrusion command)
                                      Proposal: try simulating extruding with E and Z parameters (E may be sufficient. Whether you need a dummy E stepper, I don't know).
                                      In case you don't know what is meant by segmentation: a curve is not printed as curve, but split into little segments and printed every segment as a line. The better the hardware, the more segments are used (Duet 3 best, Duet 2 good, depending on the memory available). The Delta/Scara printers have non-linearity of X and Y, so they need segmentation. Otherwise there will be a curve, because the calculation of x-y-relation at the start of the line doesn't fit the situation in the middle or end. For Scara it is even worse: not only the movement path, but also the speed varies (resulting in uneven extrusion if not segmented). Both effects are corrected if the movement is split into small segments.
                                      • Phospherusundefined
                                        Phospherus
                                        Is 5bar still be developed or worked on?
                                        • oliofundefined
                                          oliof @Phospherus
                                          @Phospherus quickly checking the source code, it looks like it's included in 3.4.5 and 3.5beta at least for all supported Duet boards, including Duet2. See also https://forum.duet3d.com/topic/30523/5-bar-scara-on-duet3/14 for a more recent discussion.
                                          Phospherusundefined 1 Reply Last reply Reply Quote 0
                                            Phospherus @oliof
                                            @oliof Thank you. I went ahead and tried 3.4.5 and have my Morgan style moving and all looks correct. Still need to install bed and hot end.
                                            oliofundefined 1 Reply Last reply Reply Quote 1
