    supported code high lighters on forum - add gcode?
    605
      droftarts administrators @A Former User
      @bearer I think weโ€™re at the mercy of what the forum software (I forget what it is, momentarily) chooses to support/
      Include. I tend to use the json code highlighter.
        A Former User
        #WishfullThinking then:)
          Oh that's great. I had no idea ````json was a thing. Looks much better. Even if that was the default that would be great.
          • arhiundefined
            arhi @droftarts
            @droftarts said in supported code high lighters on forum - add gcode?:
            DISCOURSE I think
              droftarts administrators @arhi
              @arhi said in supported code high lighters on forum - add gcode?:
              DISCOURSE I think
              Nope, I finally remembered... NodeBB.
                Just doing some googling for nodeBB and code blocks and it looks like it's fairly customizable. So maybe not impossible. Would be up to @T3P3Tony to dig into it though.
                  A Former User
                  I think someone might have done something? Line numbering seems to be a new thing, or maybe just a side effect of people using various specific language tags as opposed to the default?
                    I just
                    noticed
                    that
                    line numbers are
                    showing up now as well
                    json:
                    M667 S1                                            	; Select CoreXY mode
                    M208 X0 Y0 Z-0.5 S1                                   	; Set axis minima
                    M208 X325 Y273 Z305 S0                             	; Set axis maxima (x has 295 printable reach)
                    M569 P0 S0                                         	; Drive 0 (x) goes backwards
                    M569 P1 S0                                         	; Drive 1 (y) goes backwards
                    M569 P2 S0                                         	; Drive 2 (z) goes backwards
                    M569 P3 S0                                         	; Drive 3 (e) goes backwards
                    default:
                    Html:
                    Js:
                      droftarts administrators @Phaedrux
                      @Phaedrux
                      This is
                      with
                      โ€˜textโ€™
                      set
                        A Former User
                        Someone is being sneaky ... I like it! ๐Ÿ‘‡
                          T3P3Tony administrators
                          Good idea, I have added line numbering but pulling in the custom highlighting for gcode etc is not currently working. Any NodeBB experts out there feel free to DM ๐Ÿ˜
                          Test cases:
                          var s = "JavaScript syntax highlighting";
                          alert(s);
                          s = "Python syntax highlighting"
                          print s
                          G10 X100 ;gcode syntax highlighting (not working)
                          • botundefined
                            bot
                            Line numbering may get confusing
                            when only snippets of a larger file are copied and pasted.
                            This isn't line 3, it's actually line 4250!!
                            *not actually a robot
                              A Former User @bot
                              @bot said in supported code high lighters on forum - add gcode?:
                              I've used ```text since the numbers were introduced as shown by Ian for this very reason. Line numbers will be usefull when referring to posted configs (snippet or not) etc, just not always if referring to source code maybe.
