    Enhancing pressure advance
    92
    6.4k
    • Edgars Batnaundefined
      Edgars Batna @bot
      @bot I'm testing something on my side. Would you share a test gcode that demonstrates your use case, preferably with many layers. I sorta implemented what you suggested, but it's not that simple in the grand scheme of the firmware, so I would like to make sure I got it right before sharing code and firmware file.
      Basically, I took your formula and added some averaging to the computations, since the whole thing has to be time-based to accommodate both long and short moves. Maybe I'm thinking too far, anyways, here are my test results:
      Before:
      After:
      And I'm using a constant value of 0.5 - 0.4 (plus some other time constants because I think I had to).
      On the side note: 2.05.1 is so much smoother when running near max step rate and high PA. Good work!
      botundefined 1 Reply Last reply Reply Quote 2
      • botundefined
        bot @Edgars Batna
        @Edgars-Batna Nice work. Are you modifying only the unretract move or are you injecting movement somewhere else? The results look promising!
        I can definitely share a gcode file that I am using to troubleshoot this. It's the top part of a real-world print I'm attempting. The problem occurs at the very first move after the skirt (which made it convenient for testing), but it also happens at other spots in the file where a slow perimeter is preceded by a fast print move like support or infill, namely on layers form about 94 and up, where the tops of the letters are being formed as individual islands.
        Gcode here.
        *not actually a robot
        Edgars Batnaundefined 1 Reply Last reply Reply Quote 0
          dc42 administrators @deckingman
          @deckingman said in Enhancing pressure advance:
          In theory, PA should mean that one move finishes with zero residual pressure and the next one starts at that same residual pressure of zero.
          Only if extrusion stops completely between moves.
          Essentially, pressure advance is a filament extrusion distance advance, such that the extra extrusion distance is a function of the current extrusion speed. That distance is currently proportional to extrusion speed; but I think it needs to be a nonlinear function.
          Does anyone have the time to do the pressure advance vs speed tests that I outlined in my earlier post? https://forum.duet3d.com/post/138461
          botundefined deckingmanundefined 3 Replies Last reply Reply Quote 1
          • botundefined
            bot @dc42
            @dc42 I'll perform those tests today. I think people have performed similar tests in the past. @deckingman has previously determined that linearity is acceptable, but I'll see what I can set up to test again to see if we can reproduce similar findings.
              I can't help but notice the words non-newtonian haven't come up yet.
                Edgars Batna @bot
                @bot said in Enhancing pressure advance:
                The unretract move acts as you described it, but the extrusion rate of last move and the created underextrusion were also a factor that required some more implementation or it ended up ugly. I think I implemented it this way:
                1. The average extrusion rate of last 5 seconds is stored.
                2. Unretraction move applies your formula.
                3. The remainder of extrusion is stored for later.
                4. The next moves are adjusted by the remainder, factored by move time. 5 second moves get the most of the extrusion remainder. Remainder is passed on from move to move.
                Result is a small fixed amount of total underextrusion. There you see the time constants that could also be adjustable.
                Gcode here.
                I'll try it as soon as my other test is finished.
                @Phaedrux said in Enhancing pressure advance:
                You mean we'll need a GUI to plot a graph when tuning filament by hand? Jokes aside, you mean that there might be no PA required up to a certain pressure or from a certain pressure depending on material and such? Honestly, I'm as good as Google on this topic, because I have to Google it all.
                • botundefined
                  bot @dc42
                  @dc42 Print 1 of 20 is underway of the test. I will be printing a single wall cube with sudden speed changes in the middle of the faces, with no speed changes at the corners, and the speed change going from V1 to V2 then V2 to V1.
                  XY Accel: 300 mm/s/s
                  XY Jerk: 1.5 mm/s
                  4 mm/s to 40 mm/s and vice versa
                  8 mm/s to 40 mm/s and vice versa
                  16 mm/s to 40 mm/s and vice versa
                  32 mm/s to 40 mm/s and vice versa
                  The 4 different prints will each have the following PA variations:
                  S0.0
                  S0.1
                  S0.2
                  S0.3
                  S0.4
                  Total 20 prints.
                  Results tonight or tomorrow (Pacific Time).
                    Edgars Batna @bot
                    @bot My printer chirps like a bird when I print this file. Is it supposed to go super fast?
                    • botundefined
                      bot @Edgars Batna
                      @Edgars-Batna Hmm the 100 mm/s parts go fast and the 6 mm/s parts go slow! There are only those two feedrates. Also, I think I have the retraction speed and the travel speed ten times higher than normal so I can scale down the speed of the print without slowing those moves down.
                      Check the gcode and adjust the speeds as needed or whatever! Its a 0.2 mm line width and a 0.04 layer height (after the first layer) so I'm not sure if you'll be able to print it anyway.
                      • botundefined
                        bot
                        I'm changing the test prints to be one layer only. This makes observations easier. I will simply photograph the result from the top and then move on to the next. This will be faster.
                          deckingman @dc42
                          @dc42 said in Enhancing pressure advance:
                          I know. That's why, I went on to say (quote)...... "But what might balls that up is "jerk", because the print head doesn't come to a standstill between print moves, and so neither does the extruder."
                            Edgars Batna @bot
                            Unable to print with 2.05.1 official at all. Getting just loud extruder motor chirps. My other, normal, test print went fine, tho.
                            If you feel adventurous, here's modified firmware (rename to .zip): Duet2CombinedFirmware.txt
                            Usage: M207 C[your constant]. For multiple extruders specify a list: A:B:C...
                            M207 reports the values as "compensation".
                            Only tried on 2 extruder mixing CoreXY setup.
                            Only works with firmware retraction (G10/G11).
                            Looking at your GCode, steps with E0.0000x just plain won't work and steps with E0.000x will have tons of error because the computations in the firmware are not this precise. Maybe you are chasing a completely different beast... Could you create a test with reasonable extrusion rate?
                            I'd post source code but git is getting on my nerves regarding newlines, so this will need to wait until tomorrow.
                            • botundefined
                              bot @Edgars Batna
                              @Edgars-Batna Unfortunately, this is a reasonable extrusion rate and the areas I need to tune. Low resolution prints don't really need the extra attention, at least for my uses.
                              But, I suggest you generate a g-code yourself that just uses the top print speed you can achieve with a move that comes after that is the slowest speed you can achieve.
                              Also, what do you mean by the firmware doesn't compute that precise? AFAIK, the firmware uses 6 digits of precision. No?
                                Edgars Batna @bot
                                Don't get me wrong. I want this to work too! But, the chirping on my printer are lost extruder steps. I'm talking from experience from digging around for weeks in the firmware a year ago.
                                Excerpt from your file:
                                G1 X20.514 Y12.885 E0.0004
                                G1 X20.514 Y12.767 E0.0004
                                G1 X20.627 Y12.767 E0.0004
                                G1 X22.028 Y14.168 E0.0066
                                G1 X22.036 Y14.168 E0.0000
                                G1 X22.036 Y14.104 E0.0002
                                G1 X22.106 Y14.104 E0.0002
                                G1 X22.124 Y14.026 E0.0003
                                So, just at a basic glance, there is like nan% up to inf% of compensation required. KABOOM the computations go.
                                • botundefined
                                  bot @Edgars Batna
                                  @Edgars-Batna Nah dude. It works fine. Trust me, it's been tested thoroughly.
                                  My extruder microstep resolution is about 0.00025 mm
                                  [Edit: I mean, everything else works fine and there are no hugely obvious errors. For PA, I dunno maybe this messes it up but it doesnt seem like it.]
                                    Edgars Batna @bot
                                    Alright, my extruders go at 0.00236 mm, but be warned. I also didn't understand why S3D only outputs 4 digits after comma...
                                    I'd also be interested to see if my implementation does anything for you. For me it greatly reduced blobbing/stringing at the start of a move with C0.4, but I only ran two tests.
                                    • botundefined
                                      bot @Edgars Batna
                                      @Edgars-Batna I also hate that s3d outputs only 4 decimal places, but it seems precise enough. Even though I can microstep 0.00025 mm, it wouldn't be accurate. Also, a single microstep is never going to be an issue at this scale. A tiny blob of filament is many microsteps so it evens out.
                                      As for trying the firmware, I'd love to but I'm scared!!! This is my only printer right now and if I mess it up I'll be crying more than covid-19 has be crying already.
                                      • botundefined
                                        bot
                                        I extended the testing up to PA value S0.8. I may need to go further.
                                        My initial reaction is that the values of PA required for different XY acceleration values seems different. I wonder if, when the firmware slows down the XY acceleration to accomodate extruder jerk, if the PA is not being scaled with the new acceleration but instead uses the un-slowed-down acceleration to calculate PA? (But this doesn't have to do with the topic at hand. I'm using the same acceleration value for all these tests, I'm just reacting based on tests I did earlier with different XY accel.)
                                        I'll post picture comparisons later.
                                          Edgars Batna @bot
                                          Understandable, I usually have the hard power button in my hands when testing new stuff. Most of it is no longer new to me due to extensive trial & crash through my other topics, so I feel comfortable implementing this part of the firmware and the printer has enough flex already to not break entirely, but, yeah, every line of code is a bug.
                                          @dc42 Could you please take a look if there is something hugely illegal:
                                          https://github.com/mdealer/RepRapFirmware/commit/841e38d9ad39dc408d785f6b75ab3e6182344f02
                                          0 mdealer committed to mdealer/RepRapFirmware
                                          Implement dynamic unretraction.
                                          https://forum.duet3d.com/topic/14927/enhancing-pressure-advance/76?_=1584866367558
                                            dc42 administrators @Edgars Batna
                                            @Edgars-Batna said in Enhancing pressure advance:
                                            Please explain what the changes are intended to do.
