    Enhancing pressure advance
    92
    6.4k
      I can't help but notice the words non-newtonian haven't come up yet.
      • Edgars Batnaundefined
        Edgars Batna @bot
        @bot said in Enhancing pressure advance:
        @Edgars-Batna Nice work. Are you modifying only the unretract move or are you injecting movement somewhere else? The results look promising!
        The unretract move acts as you described it, but the extrusion rate of last move and the created underextrusion were also a factor that required some more implementation or it ended up ugly. I think I implemented it this way:
        1. The average extrusion rate of last 5 seconds is stored.
        2. Unretraction move applies your formula.
        3. The remainder of extrusion is stored for later.
        4. The next moves are adjusted by the remainder, factored by move time. 5 second moves get the most of the extrusion remainder. Remainder is passed on from move to move.
        Result is a small fixed amount of total underextrusion. There you see the time constants that could also be adjustable.
        I can definitely share a gcode file that I am using to troubleshoot this. It's the top part of a real-world print I'm attempting. The problem occurs at the very first move after the skirt (which made it convenient for testing), but it also happens at other spots in the file where a slow perimeter is preceded by a fast print move like support or infill, namely on layers form about 94 and up, where the tops of the letters are being formed as individual islands.
        Gcode here.
        I'll try it as soon as my other test is finished.
        @Phaedrux said in Enhancing pressure advance:
        You mean we'll need a GUI to plot a graph when tuning filament by hand? Jokes aside, you mean that there might be no PA required up to a certain pressure or from a certain pressure depending on material and such? Honestly, I'm as good as Google on this topic, because I have to Google it all.
        • botundefined
          bot @dc42
          @dc42 Print 1 of 20 is underway of the test. I will be printing a single wall cube with sudden speed changes in the middle of the faces, with no speed changes at the corners, and the speed change going from V1 to V2 then V2 to V1.
          XY Accel: 300 mm/s/s
          XY Jerk: 1.5 mm/s
          4 mm/s to 40 mm/s and vice versa
          8 mm/s to 40 mm/s and vice versa
          16 mm/s to 40 mm/s and vice versa
          32 mm/s to 40 mm/s and vice versa
          The 4 different prints will each have the following PA variations:
          S0.0
          S0.1
          S0.2
          S0.3
          S0.4
          Total 20 prints.
          Results tonight or tomorrow (Pacific Time).
          *not actually a robot
          Edgars Batnaundefined 1 Reply Last reply Reply Quote 0
            Edgars Batna @bot
            @bot My printer chirps like a bird when I print this file. Is it supposed to go super fast?
            • botundefined
              bot @Edgars Batna
              @Edgars-Batna Hmm the 100 mm/s parts go fast and the 6 mm/s parts go slow! There are only those two feedrates. Also, I think I have the retraction speed and the travel speed ten times higher than normal so I can scale down the speed of the print without slowing those moves down.
              Check the gcode and adjust the speeds as needed or whatever! Its a 0.2 mm line width and a 0.04 layer height (after the first layer) so I'm not sure if you'll be able to print it anyway.
              • botundefined
                bot
                I'm changing the test prints to be one layer only. This makes observations easier. I will simply photograph the result from the top and then move on to the next. This will be faster.
                  deckingman @dc42
                  @dc42 said in Enhancing pressure advance:
                  @deckingman said in Enhancing pressure advance:
                  In theory, PA should mean that one move finishes with zero residual pressure and the next one starts at that same residual pressure of zero.
                  Only if extrusion stops completely between moves.
                  I know. That's why, I went on to say (quote)...... "But what might balls that up is "jerk", because the print head doesn't come to a standstill between print moves, and so neither does the extruder."
                    Edgars Batna @bot
                    Unable to print with 2.05.1 official at all. Getting just loud extruder motor chirps. My other, normal, test print went fine, tho.
                    If you feel adventurous, here's modified firmware (rename to .zip): Duet2CombinedFirmware.txt
                    Usage: M207 C[your constant]. For multiple extruders specify a list: A:B:C...
                    M207 reports the values as "compensation".
                    Only tried on 2 extruder mixing CoreXY setup.
                    Only works with firmware retraction (G10/G11).
                    Looking at your GCode, steps with E0.0000x just plain won't work and steps with E0.000x will have tons of error because the computations in the firmware are not this precise. Maybe you are chasing a completely different beast... Could you create a test with reasonable extrusion rate?
                    I'd post source code but git is getting on my nerves regarding newlines, so this will need to wait until tomorrow.
                    • botundefined
                      bot @Edgars Batna
                      @Edgars-Batna Unfortunately, this is a reasonable extrusion rate and the areas I need to tune. Low resolution prints don't really need the extra attention, at least for my uses.
                      But, I suggest you generate a g-code yourself that just uses the top print speed you can achieve with a move that comes after that is the slowest speed you can achieve.
                      Also, what do you mean by the firmware doesn't compute that precise? AFAIK, the firmware uses 6 digits of precision. No?
                        Edgars Batna @bot
                        Don't get me wrong. I want this to work too! But, the chirping on my printer are lost extruder steps. I'm talking from experience from digging around for weeks in the firmware a year ago.
                        Excerpt from your file:
                        G1 X20.514 Y12.885 E0.0004
                        G1 X20.514 Y12.767 E0.0004
                        G1 X20.627 Y12.767 E0.0004
                        G1 X22.028 Y14.168 E0.0066
                        G1 X22.036 Y14.168 E0.0000
                        G1 X22.036 Y14.104 E0.0002
                        G1 X22.106 Y14.104 E0.0002
                        G1 X22.124 Y14.026 E0.0003
                        So, just at a basic glance, there is like nan% up to inf% of compensation required. KABOOM the computations go.
                        • botundefined
                          bot @Edgars Batna
                          @Edgars-Batna Nah dude. It works fine. Trust me, it's been tested thoroughly.
                          My extruder microstep resolution is about 0.00025 mm
                          [Edit: I mean, everything else works fine and there are no hugely obvious errors. For PA, I dunno maybe this messes it up but it doesnt seem like it.]
                            Edgars Batna @bot
                            Alright, my extruders go at 0.00236 mm, but be warned. I also didn't understand why S3D only outputs 4 digits after comma...
                            I'd also be interested to see if my implementation does anything for you. For me it greatly reduced blobbing/stringing at the start of a move with C0.4, but I only ran two tests.
                            • botundefined
                              bot @Edgars Batna
                              @Edgars-Batna I also hate that s3d outputs only 4 decimal places, but it seems precise enough. Even though I can microstep 0.00025 mm, it wouldn't be accurate. Also, a single microstep is never going to be an issue at this scale. A tiny blob of filament is many microsteps so it evens out.
                              As for trying the firmware, I'd love to but I'm scared!!! This is my only printer right now and if I mess it up I'll be crying more than covid-19 has be crying already.
                              • botundefined
                                bot
                                I extended the testing up to PA value S0.8. I may need to go further.
                                My initial reaction is that the values of PA required for different XY acceleration values seems different. I wonder if, when the firmware slows down the XY acceleration to accomodate extruder jerk, if the PA is not being scaled with the new acceleration but instead uses the un-slowed-down acceleration to calculate PA? (But this doesn't have to do with the topic at hand. I'm using the same acceleration value for all these tests, I'm just reacting based on tests I did earlier with different XY accel.)
                                I'll post picture comparisons later.
                                  Edgars Batna @bot
                                  Understandable, I usually have the hard power button in my hands when testing new stuff. Most of it is no longer new to me due to extensive trial & crash through my other topics, so I feel comfortable implementing this part of the firmware and the printer has enough flex already to not break entirely, but, yeah, every line of code is a bug.
                                  @dc42 Could you please take a look if there is something hugely illegal:
                                  https://github.com/mdealer/RepRapFirmware/commit/841e38d9ad39dc408d785f6b75ab3e6182344f02
                                  0 mdealer committed to mdealer/RepRapFirmware
                                  Implement dynamic unretraction.
                                  https://forum.duet3d.com/topic/14927/enhancing-pressure-advance/76?_=1584866367558
                                    dc42 administrators @Edgars Batna
                                    @Edgars-Batna said in Enhancing pressure advance:
                                    Please explain what the changes are intended to do.
                                      Edgars Batna @dc42
                                      2. Unretraction move applies your formula: Adjusted_Unretract_Distance = Nominal_unretract_distance + (Target_Extruder_Speed_of_Second_Move - Target_Extruder_Speed_of_First_Move) * New_Constant
                                      It's basically what @bot suggested plus my implementation. I think it's just another variable for relieving or building up pressure in the hotend but bound to the unretraction move. Sorry, no hard facts or theory. This might well be just backlash of my own printer in the pics above, it only helped in that particular case and significantly reduced stringing in another test with a real print. I just ran some tests with more or less bot's problem, but it appears it just makes it worse without further investigations. I'm analyzing and will post some more pics soon.
                                      • botundefined
                                        bot
                                        Sorry, I got a little delayed trying to find ass wipe to buy anywhere... I'm almost finished post-processing the images of all the prints so they can easily be compared. I'll post them in a matter of hours.
                                        • botundefined
                                          bot
                                          @dc42 I have finished the test and uploaded the results.
                                          They are here.
                                          The photos are all there, there is a readme.txt file with additional info about the tests, and the gcodes used for the tests are there.
                                          I'll refrain from stating any opinion. I'd like to hear your thoughts raw. Read the readme.txt file, though, because I do mention a note about the bed level during the tests.
                                          I realize you also wanted me to vary the V2 speed, which in this test is always 40 mm/s. If you wish I can repeat these tests with 80 mm/s instead of 40 mm/s as the top speed, and then repeat once again a test but with the slow speeds doubled and 80 mm/s as the top speed. Let me know if you would find this useful.
                                          Here is an example of one of the images. They are all formatted this way:
                                          • Marius Breuerundefined
                                            Marius Breuer @bot
                                            @bot regarding the pressure inside the melt chamber:
                                            The new e3d Hermera extruder can push filament with up to 10ish kg (100N).
                                            1,75mm Filament has a cross section of roughly 2,4mm^2.
                                            100N / 2,4mm^2 = 40N/mm^2
                                            Hence the pressure inside the hotend can't exceed 40N/mm^2 = 40MN/m^2 = 40MPa = 400bar
                                            This is the maximum pressure based on the design of the gearing. The NEMA17 Motor can't produce the torque to reach that pressure. There is insufficient information about the real-world pushing force of this extruder.
                                            https://e3d-online.dozuki.com/Document/H4JSEgZEtxEsa5oE/Hemera-Datasheet-(Edition-1).pdf
                                            If the viscocity of molten plastics in the hotend is known one could calculate the pressure needed to uphold a given materialflow through the nozzle. Such calculation can also correct for the nozzle shape and material (friction), making comparison between brass and non-stick coated nozzles possible.
                                            BR, Marius
