    CR10 S5 upgrade to Duet 2 Wifi
    2.5k
    • NexxCatundefined
      NexxCat @GT1Za
      @GT1Za
      Was it doing this prior to us changing stuff to get the BLTouch working? or hadn't it been tested?
      GT1Zaundefined 1 Reply Last reply Reply Quote 0
      • GT1Zaundefined
        GT1Za @NexxCat
        @NexxCat never tested it, I had just checked that there was movement.
        NexxCatundefined 1 Reply Last reply Reply Quote 0
        • NexxCatundefined
          NexxCat @GT1Za
          @GT1Za
          I've just compared my config to yours and can't see anything wrong 😞 I'm afraid I can't help further on this one, I've absolutely no idea why the axis is moving more than it should be when everything is configured correctly.
          Hopefully someone else can chime in with some ideas, but as far as I'm aware now, once this is solved, the BLTouch should work correctly.
          I'll keep this thread in mind and if I come up with anything, I'll pop back and reply. Sorry I couldn't solve this for you!
          • GT1Zaundefined
            GT1Za
            @NexxCat thanks man! you have been amazing. Ill keep googling to see if I can get anything. Hopefully someone else can maybe assist.
            NexxCatundefined 1 Reply Last reply Reply Quote 1
            • NexxCatundefined
              NexxCat @GT1Za
              @GT1Za
              Hey, just had a thought. Maybe try swapping the X and Y motor connections on the Duet, then update config.g like so:
              Change:
              to
              M584 Y0 X1 Z2 E3 ; set drive mapping
              It would be interesting to know if the issue moves to the X axis, or if it continues on Y. If it moves, I'd be inclined to talk to one of the mods / admins if the board is in warranty and see what input they have. If it stays on the Y axis, then I'm back to being stumped 😛
                Phaedrux Moderator @GT1Za
                @GT1Za said in CR10 S5 upgrade to Duet 2 Wifi:
                @NexxCat
                not sure if that helps. Pretty tough getting to the back of this printer.
                The motor is about double the height of the normal ones, but its the standard S5 motor.
                https://3dprinting.stackexchange.com/questions/7692/stepper-motor-for-cr10-s5-y-axis
                Belt looks kind of loose to me.
                Your E steps for the extruder is still set to the stock 93ish. The Hemera is 415ish.
                Ive always liked the idea of keeping the z stop incase the BLtouch fails. Is there no way to keep both?
                No, unfortunately it doesn't work like that. But when configured and wired correctly the BLtouch is pretty reliable as an endstop. As a safety precaution it's a good idea to drop motor current during homing so that if the probe does fail it will just stall the motor without causing damage.
                Can you do a quick test of your Y axis? Send G92 Y0 to mark it as homed. Then jog it 10mm and measure the actual distance moved. That will help us verify if your steps per mm is correct.
                  G31 P500 X-3 Y0 Z3
                  Your X Y offsets for the probe are improbable. It must be measured. https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Measuring_Probe_X_Y_Offset
                  • GT1Zaundefined
                    GT1Za @Phaedrux
                    @Phaedrux Thanks, I had already adjusted the esteps on the extruder to 409. This seems to be the recommended starting point, but I will adjust this when the machine is finished in the testing phase and correctly wired with wire management in place. But again thanks for the reminder!
                    I will take measurements now, but Im pretty certain its going just over double length.
                    • GT1Zaundefined
                      GT1Za
                      @Phaedrux
                      I am now completely confused... I did as you asked.
                      Homed the Y
                      issued command to move 100, and the plate has moved exactly 10cm
                      • PaulHewundefined
                        PaulHew
                        @GT1Za Sounds right. 100mm is 10cm.
                        Or am I missing something?
                        P.
                        • GT1Zaundefined
                          GT1Za @PaulHew
                          @PaulHew haha thats why I am so confused!! if that is right then why am I getting an issue and it only going to 220 and not 500 before reaching the end of the bed??
                          • PaulHewundefined
                            PaulHew
                            @GT1Za Please send details of M115
                            P.
                            • GT1Zaundefined
                              GT1Za @PaulHew
                              @PaulHew Ill get it up soon as I can. I have dismantled a lot to start with cable management.
                              PaulHewundefined 1 Reply Last reply Reply Quote 0
                              • PaulHewundefined
                                PaulHew @GT1Za
                                @GT1Za No worries.
                                I was trying to help someone last night and everything looked right but I forgot to check his firmware version!
                                P.
                                  Can you also repost your config and homing files as they currently are?
