    CR10 S5 upgrade to Duet 2 Wifi
    2.5k
    • NexxCatundefined
      NexxCat @GT1Za
      @GT1Za
      I'm assuming when you home Y, it does home correctly and the Y co-ordinate is reported as 0?
      • GT1Zaundefined
        GT1Za
        @NexxCat yes the homing works fine and reports 0
        NexxCatundefined 1 Reply Last reply Reply Quote 0
        • NexxCatundefined
          NexxCat @GT1Za
          @GT1Za
          and just so I've got this right in my head. Starting from Y home, you move the bed using the jog controls and when Y is reported at 220, the bed is actually at the end of it's travel (IE, at 510)?
          • GT1Zaundefined
            GT1Za
            @NexxCat
            thats correct
            I havent homed the other axis so they are reporting 0 here.
            • NexxCatundefined
              NexxCat @GT1Za
              @GT1Za
              The only explanation I have for that is that the Y axis steps/mm aren't correct. Can you take a photo of the Y axis motor and pulley? I'll see if I can tell whether it's a 20T or not.
              GT1Zaundefined 1 Reply Last reply Reply Quote 0
              • GT1Zaundefined
                GT1Za @NexxCat
                @NexxCat
                not sure if that helps. Pretty tough getting to the back of this printer.
                The motor is about double the height of the normal ones, but its the standard S5 motor.
                https://3dprinting.stackexchange.com/questions/7692/stepper-motor-for-cr10-s5-y-axis
                NexxCatundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                • NexxCatundefined
                  NexxCat @GT1Za
                  @GT1Za
                  I'm afraid I'm stumped on this one. That looks like a normal 20 tooth pulley and I've checked the Marlin source for the CR10 S5. It definitely uses 80 steps/mm.
                  If the bed was moving an insufficient distance, I'd say maybe the stepper was skipping, or the belt was loose, but it's moving too much which doesn't make sense.
                  Probably a stupid question, but have you tried powering the Duet off and on again, letting it re-load config.g?
                  • GT1Zaundefined
                    GT1Za @NexxCat
                    @NexxCat Ill give it a shot now
                    • GT1Zaundefined
                      GT1Za
                      @NexxCat Restart made no difference.
                      • NexxCatundefined
                        NexxCat @GT1Za
                        @GT1Za
                        Was it doing this prior to us changing stuff to get the BLTouch working? or hadn't it been tested?
                        • GT1Zaundefined
                          GT1Za @NexxCat
                          @NexxCat never tested it, I had just checked that there was movement.
                          • NexxCatundefined
                            NexxCat @GT1Za
                            @GT1Za
                            I've just compared my config to yours and can't see anything wrong 😞 I'm afraid I can't help further on this one, I've absolutely no idea why the axis is moving more than it should be when everything is configured correctly.
                            Hopefully someone else can chime in with some ideas, but as far as I'm aware now, once this is solved, the BLTouch should work correctly.
                            I'll keep this thread in mind and if I come up with anything, I'll pop back and reply. Sorry I couldn't solve this for you!
                            • GT1Zaundefined
                              GT1Za
                              @NexxCat thanks man! you have been amazing. Ill keep googling to see if I can get anything. Hopefully someone else can maybe assist.
                              NexxCatundefined 1 Reply Last reply Reply Quote 1
                              • NexxCatundefined
                                NexxCat @GT1Za
                                @GT1Za
                                Hey, just had a thought. Maybe try swapping the X and Y motor connections on the Duet, then update config.g like so:
                                Change:
                                to
                                M584 Y0 X1 Z2 E3 ; set drive mapping
                                It would be interesting to know if the issue moves to the X axis, or if it continues on Y. If it moves, I'd be inclined to talk to one of the mods / admins if the board is in warranty and see what input they have. If it stays on the Y axis, then I'm back to being stumped 😛
                                  Phaedrux Moderator @GT1Za
                                  @GT1Za said in CR10 S5 upgrade to Duet 2 Wifi:
                                  @NexxCat
                                  Belt looks kind of loose to me.
                                  Your E steps for the extruder is still set to the stock 93ish. The Hemera is 415ish.
                                  Ive always liked the idea of keeping the z stop incase the BLtouch fails. Is there no way to keep both?
                                  No, unfortunately it doesn't work like that. But when configured and wired correctly the BLtouch is pretty reliable as an endstop. As a safety precaution it's a good idea to drop motor current during homing so that if the probe does fail it will just stall the motor without causing damage.
                                  Can you do a quick test of your Y axis? Send G92 Y0 to mark it as homed. Then jog it 10mm and measure the actual distance moved. That will help us verify if your steps per mm is correct.
                                    G31 P500 X-3 Y0 Z3
                                    Your X Y offsets for the probe are improbable. It must be measured. https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Measuring_Probe_X_Y_Offset
                                    • GT1Zaundefined
                                      GT1Za @Phaedrux
                                      @Phaedrux Thanks, I had already adjusted the esteps on the extruder to 409. This seems to be the recommended starting point, but I will adjust this when the machine is finished in the testing phase and correctly wired with wire management in place. But again thanks for the reminder!
                                      I will take measurements now, but Im pretty certain its going just over double length.
                                      • GT1Zaundefined
                                        GT1Za
                                        @Phaedrux
                                        I am now completely confused... I did as you asked.
                                        Homed the Y
                                        issued command to move 100, and the plate has moved exactly 10cm
                                        • PaulHewundefined
                                          PaulHew
                                          @GT1Za Sounds right. 100mm is 10cm.
                                          Or am I missing something?
                                          P.
                                          • GT1Zaundefined
                                            GT1Za @PaulHew
                                            @PaulHew haha thats why I am so confused!! if that is right then why am I getting an issue and it only going to 220 and not 500 before reaching the end of the bed??
