Which endstop. Microswitch or stall detection?
@Danal Photography is/was one of my other hobbies. I think that the difference you perceived may be just due to the fact that they are different photographs. In one picture, the item is positioned in such a way that more of the light coloured back wall is visible. This would mean that the overall exposure might be different. Which means that the camera aperture setting would be different. This in turn means that the depth of field is different, so parts of the object close to the camera would be either more or less sharply focused than parts of the object that are further away. All of this also assumes that there was zero camera shake. If Mark hand held the camera, then it is also possible that there might have been some slight blurring due to this (note that I am not implying that Mark has any underlying health issues)
@deckingman Photos were taken with a Canon 50 mm macro lens on my Samsung NX500 camera, print held in a vise, camera on a short tripod, both on top of a pool table, 5 second timer used to let shake settle out, manual exposure - both shots at ISO 400, f11, 0.3 sec.
I think the difference in the angle of the print/lighting accounts for most of the miniscule difference in the appearance.
@mrehorstdmd Oh well done. I'm impressed! If I was in a pedantic mood, I would say that the angle of the parts in relation to the background shows some sort of positional difference between pictures. But I'm not in a pedantic mood, so I won't say that.
Edit. What I'm trying to say is that there may be differences in the photos, so your opinion based on your observations of the real objects, will be more valid than other peoples opinions based on the images.
Aren't the three of us funny?
So back to the OP's question, based on my test results, I think I prefer optical endstops over snap-switches and stall detection.
Stall has two things that determine where/when to use it:
It is very likely to need tuning and occasional re-tuning. Because of mechanical differences, you can't just turn it on and it will work now and forever. (Which is true of a switch or optical).
It is not as accurate as even the cheapest of switches.
Those two things then lead to:
Non-Delta XY doesn't need to be very precise, so optical, snap switch, stall detect all work. Z needs to be optical or a good switch.
Delta needs good switches, either optical or reasonable quality snap switch. Exception: Deltas that probe the bed at the start of every print can use stall, they effectively override the switches when they probe.
I agree with that, with one caveat:
@Danal said in Which endstop. Microswitch or stall detection?:
If you want to use the resume-after-power-fail functionality, then you need to be able to re-home X and Y (and ideally Z) to the same positions as before you started the print; so then you do need repeatable endstops.
I guess we ought to add a couple more options to complete the list. Firstly there are these which is what I currently use for Z homing https://www.metrol.co.jp/ec/contact-switch_cs?gclid=CjwKCAjwvOHzBRBoEiwA48i6Aia0mpbKJrQVI626sR3oOE8VQCsAjM_hfVqfWi002W6rRRY8-M05nRoCT68QAvD_BwE
The way I do it is a bit tricky to implement from a mechanical point of view because the switch is connected to the nozzle mount, so the nozzle itself is the Z probe. It's a bit tricky because the nozzle must be constrained from any movement in X or Y but free to move (albeit only by 0.3mm or so) in Z.
These switches aren't cheap though and would be overkill for X or Y (but they do come with optional LEDs which as Mark said, are handy).
Another option is two insulated contacts coming together to complete a circuit, which is as simple as it gets. One contact on the carriage, the other on the frame. The contacts need to be non corroding - so gold or silver plated.
I'm currently working on another variant for my Z axis using that technique. I've just spent the princely sum of £1.26 on these https://www.ebay.co.uk/itm/Flat-Disc-and-Post-Earring-Findings-Pack-of-10-Make-your-Own-Earrings/112606214351?ssPageName=STRK%3AMEBIDX%3AIT&var=413683787505&_trksid=p2060353.m2749.l2649 which might make suitable contacts. It's still a bit tricky to implement from a mechanical point of view but if it works, then in theory the Z offset will be zero (although in practice it might be a few um).
To that last point, I'm working on multi tool alignment on tool-changing printers. Right now, the simplest way to measure Z seems to be to wire the nozzle and a touchplate. Metal-to-metal contact.
How do you plan to clean any filament debris from the nozzle?
@dc42 said in Which endstop. Microswitch or stall detection?:
The toolchanger wipes the nozzle when it mounts it, as a normal part of printing, to avoid blobs and such. So far, debris has been a very low failure rate.
@jens55 said in Which endstop. Microswitch or stall detection?:
Consensus seens to be that stall detection is not as accurate as s switch.
Super accuracy of x/y homing is not a goal for my Core X/Y since I don't need to resume from power outrages. As for Z, the printer has a BlTouch which works great also for Z homing. This minimalist approach simplifies the hardware and works great for me.
The case may be different for other kinematics such as Deltas where a tower homing errors may tilt their plan and invalidate their previously acquired compensation mesh.
I'm using opto switches in all three axes. The Z=0 is adjusted using a differential screw so small tweaks to the bed position can easily be made. It much simpler than putting a sensor on the extruder carriage, and since the printer is stable, like the bed leveling, it doesn't have to be readjusted.
@mrehorstdmd said in Which endstop. Microswitch or stall detection?:
Do you use a sensor for mesh compensation or is your mechanical frame accurate enough as is?
@zapta No sensors, no mesh compensation. Built like a tank and very stable. Bed is flat and leveled on a kinematic mount. On numerous occasions I have dragged it up basement stairs, loaded it into my car, taken it back out and started printing with no adjustments.
Any way we can use the "dual" sensor for homing? I'd like to do the switch (opto or mechanical) + stall detection as a backup. During the homing process, if something goes wrong (print left on the bed is a good example), it would be cool to "cancel" homing on stall detection.
