    U axis don't print
    1.9k
    • Danalundefined
      Danal
      @noisettetbou said in U axis don't print:
      I've put M579 U-1 ; set U mirror of X in my tpost3.g
      And, I'd assume, M579 U1 in tpost2.g (and maybe tpost0.g ?? couldn't hurt anything).
      • Danalundefined
        Danal
        These are your current definitions, lined up where we can read them more easily:
        M584 X0 Y1:2 U5 Z6:7:8:9 E3:4 ; Mapping drivers
        M563 P0 D0 H1           F1    S"X" ; define tool X
        M563 P1 D1 H2     X5    F4    S"U" ; define tool U
        M563 P2 D0:1 H1:2 X5    F1:4  S"XU" ; define tool X+U copy mode
        M563 P3 D0:1 H1:2 X0:5  F1:4  S"XU" ; define tool X+U mirror mode
        Any reason why line 5 is X5 and line 6 is X0:5? The example in the documentation shows it more like X5. I'd set them both that way.
        • noisettetbouundefined
          noisettetbou
          Hello. Thanks for yours answers.
          I've applied the changes but I've got the same result.
          In fact, U don't want to be mapped. All the rest works.
          I've tried various M563 in the console but no mapping.
          • Danalundefined
            Danal
            I am going to recap some things here, because I have never done an IDEX and I am not 100% sure how they work.
            The X Y Z and E axis are defined, and the E, like any other cartesian printer, and if T0 is selected, and G1 commands are used, the X Y Z motors will respond like any other cartesian printer.
            In addition another axis is defined, usually U, and the motor driver for that physically drives the another carriage that travels just like the X part of the first carriage. It also has an extruder, defined in the tool. This can be used for copy, or mirror, prints.
            To use this, the printer would home the XYZ axis, which effectively positions the main carriage, and then home U, effectively positioning the alternate carriage in XYZ as well, and a few G1 moves might be needed to position the main and U carriage a set distance apart. After that, switch to the tool that is appropriate for copy or mirror, and print.
            Every Y and Z move affects both carriages equally, via the mechanics. Every X move is copied (or mirrored) by the firmware to the U motor.
            Correct so far?
            I happen to have a Duet 2 sitting here in a test setup for another project. Let me config it and do some experimentation.
            noisettetbouundefined 2 Replies Last reply Reply Quote 0
            • Danalundefined
              Danal
              OK, I think I've got it. Try this:
              M563 P1 D1 H2     X3    F4    S"U" ; define tool U
              M563 P2 D0:1 H1:2 X0:3  F1:4  S"XU" ; define tool X+U copy mode
              M563 P3 D0:1 H1:2 X0:3  F1:4  S"XU" ; define tool X+U mirror mode
              The "3" seems to be the logical number of the axis to be mapped. That is X=0,Y=1, Z=2,U=3, etc. And the lines that map the copy or mirro do seem to need both the 'base' axis and the 'extra' axis.
              Let me know if this works.
              sebkritikelundefined 1 Reply Last reply Reply Quote 1
              • sebkritikelundefined
                sebkritikel @Danal
                @Danal said in U axis don't print:
                I'm running an IDEX machine (albeit on RRF2) but this should do the trick.
                X3 instead of X5 is correct - X (0), Y (1), Z (2), U(3)
                I have not tried mirror mode. The documentation refers to M579 (Scale Cartesian axes), however where would the best place for that be? In the start GCODE of a print file? "M579 U-1" is needed to "scale" the U axis in the negative direction.
                Large(ish?) IDEX - 6HC, 1HCL
                Stratasys Dimension 1200es to 6HC Conversion
                noisettetbouundefined 1 Reply Last reply Reply Quote 0
                  noisettetbou @Danal
                  @Danal
                  It's a good recap. Only the moves aren't not needed because the offsets can be defined by G10 Pxxx in config.g.
                  I'm waiting your come back.
                  Thanks again.
                    noisettetbou @sebkritikel
                    @sebkritikel
                    It works ! Thanks a lot. It's strange I need to map the driver 5 with the number 3 but the essential is that it works.
                    For mirror, I've put the M579 U-1 in tpost3.g and M579 U1 in tfree3.g for return to normal direction when T3 is unloaded.
                    Thanks again.
                      noisettetbou @Danal
                      @Danal it is no longer worth to search the solution, @sebkritikel found it. Thank you
                        sebkritikel @noisettetbou
                        @sebkritikel
                        Thanks again.
                        Nice, glad to help! Good idea on M579 in tpost3.g and tfree3.g!
                        To understand why it is X3 instead of X5, reread M584 https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
                        3 or 5 does not mean driver, it means axis. The axis value is from XYZUVWABC, with X starting at '0'
                        droftartsundefined noisettetbouundefined 2 Replies Last reply Reply Quote 0
                          droftarts administrators @sebkritikel
                          @sebkritikel @noisettetbou @Danal Thanks for your work on this thread! I really didn't have much of a clue where to start with IDEX. If you have any comments to update the IDEX page in the wiki here , or specifically this section , can you let me know and I'll update it?
                          Actually, looking at the IDEX wiki page, most of the info seems to be there?! Perhaps just a bit about the X parameter mapping using the order XYZUVWABC, where X=0, Y=1, Z=2, U=3 etc?
                          sebkritikelundefined 1 Reply Last reply Reply Quote 0
                            sebkritikel @droftarts
                            @droftarts said in U axis don't print:
                            I would agree that most of the info is there, but adding additional clarification on the X parameter mapping would be great, as well as a small section on M579 for mirror printing in the area discussing tool generation. Thanks!
                            droftartsundefined 1 Reply Last reply Reply Quote 1
                              @sebkritikel I've added a bit to the X and Y parameter description in https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M563_Define_or_remove_a_tool
                              I've added a similar note here: https://duet3d.dozuki.com/Wiki/ConfiguringMultipleIndependentXcarriagesCartesian?revisionid=HEAD#Section_Creating_a_tool_that_uses_more_than_one_carriage_to_print_multiple_copies_of_an_object
                              And described how to set up the mirror tool, and M579, here: https://duet3d.dozuki.com/Wiki/ConfiguringMultipleIndependentXcarriagesCartesian?revisionid=HEAD#Section_Sample_IDEX_tool_configuration
                              noisettetbouundefined 1 Reply Last reply Reply Quote 2
                                @sebkritikel OK. It's good to know the M594 means axis because I've got a project of printer with 2 X and 2 Y. Thank you
                                optisoftundefined 1 Reply Last reply Reply Quote 0
                                  noisettetbou @droftarts
                                  @droftarts It's cool you've got added this notes for the futures IDEX users. Thank you.
                                  • optisoftundefined
                                    optisoft @noisettetbou
                                    @noisettetbou You probably meant M584 and not M594.
                                    • VA3Dnimersundefined VA3Dnimers referenced this topic
