    RepRapFirmware 3.01-RC5 available
    Beta Firmware
    12
    37
    1.9k
      I'm sorry I forgot about this. I've put a patched verson of 3.01-RC5 for the Maestro at https://www.dropbox.com/s/f4wj6im1nc6curf/DuetMaestroFirmware.bin?dl=0.
      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
      • DIY-O-Sphereundefined
        DIY-O-Sphere @dc42
        Great job. Works like expected. 👍
        (UTC+1)
        • SIamundefined
          SIam
          Is it possible that there is a problem with the print time calculation ?
          The real printing time was 2h and 2min but the log says it was 9h and 11min ?!?
          28.3.2020, 21:51:24: M32 "0:/gcodes/covid19_headband_rc3(6).gcode": File 0:/gcodes/covid19_headband_rc3(6).gcode selected for printing
          28.3.2020, 21:51:46: : Leadscrew adjustments made: -0.112 -0.095 -0.111, points used 3, (mean, deviation) before (-0.106, 0.007) after (-0.000, 0.000)
          Auto kalibrierung erfolgreich, Abweichung von:  0.007mm
          Happy Printing
          28.3.2020, 23:53:34: : Finished printing file 0:/gcodes/covid19_headband_rc3(6).gcode, print time was 9h 11m
          Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
          Duet WiFi 1.02 or later + DueX5
          RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
          Duet WiFi Server: 1.26
          Duet Web Control 3.4.0beta4 (2021-09-27)
            @SIam said in RepRapFirmware 3.01-RC5 available:
            I think I've seen this happen once too. Let me know if it happens again.
            SIamundefined 1 Reply Last reply Reply Quote 0
              I've just added version 3.01-RC5 firmware binaries for Duet 3 tool boards and expansion board to this release.
              • SIamundefined
                SIam @dc42
                i have printet now the same thing (a little bit faster) and have this result
                29.3.2020, 12:09:45: Datei covid19_headband_rc3(6).gcode erfolgreich nach 13s hochgeladen
                29.3.2020, 12:09:46: M32 "0:/gcodes/covid19_headband_rc3(6).gcode": File 0:/gcodes/covid19_headband_rc3(6).gcode selected for printing
                29.3.2020, 12:20:46: : Leadscrew adjustments made: -0.076 -0.079 -0.066, points used 3, (mean, deviation) before (-0.073, 0.005) after (-0.000, 0.000)
                Auto kalibrierung erfolgreich, Abweichung von:  0.005mm
                Happy Printing
                29.3.2020, 13:54:23: : Finished printing file 0:/gcodes/covid19_headband_rc3(6).gcode, print time was 22h 12m
                This print is ca. 13 hours later as the first one (the printer was not switched off), if i calculate the first print time response from duet 9h 11m + 13 hours then the result is 22h 11 so i think the start time of a print will not set the printing time to zero.
                  I confirm the problem with incorrect print time. It will report the time since the Duet was last powered up or reset.
                  • TCundefined
                    TC
                    I am not sure if this is a new issue but can you checck the multiplication operator. It seems not to work at all
                      dc42 administrators @TC
                      @TC said in RepRapFirmware 3.01-RC5 available:
                      It works if you enclose the expression in { } but not otherwise. That's because * normally introduces an end-of-line checksum.
                      • TCundefined
                        TC
                        Ah ok. Maybe that is also something that could be mentioned in the documentation 😉
                        • Dr_Ju_Juundefined
                          Dr_Ju_Ju
                          Has anything changed in the heating routines ? as since I've updated to RC5 my hot-end heater keeps throwing this error:
                          "Error: Heating fault on heater 1, temperature rising much more slowly than the expected 1.7°C/sec"
                          which I've never had on the previous RC's & RRF2x. nothing has changed on the hardware side & I've even power cycled, in case it was just an anomaly....
                          M115
                          FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.01-RC5 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2020-03-27b3
                          M122
                          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC5 running on Duet Ethernet 1.02 or later
                          Board ID: 08DGM-95BNL-MGPSJ-6J1F2-3SD6L-9JZHX
                          Used output buffers: 1 of 24 (10 max)
                          Static ram: 28052
                          Dynamic ram: 93204 of which 44 recycled
                          Exception stack ram used: 256
                          Never used ram: 9516
                          Tasks: NETWORK(ready,748) HEAT(blocked,1244) MAIN(running,1844) IDLE(ready,76)
                          Owned mutexes:
                          Last reset 00:00:55 ago, cause: software
                          Last software reset at 2020-03-31 11:27, reason: User, spinning module GCodes, available RAM 9516 bytes (slot 2)
                          Error status: 0
                          Free file entries: 10
                          MCU temperature: min 29.9, current 31.2, max 31.6
                          Supply voltage: min 24.2, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                          Cache data hit count 108426845
                          Slowest loop: 6.93ms; fastest: 0.11ms
                          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                          === MainDDARing ===
                          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                          === AuxDDARing ===
                          Heater 0 is on, I-accum = 0.0
                          Heater 1 is on, I-accum = 0.0
                          Segments left: 0
                          Movement lock held by null
                          HTTP is idle in state(s) 0
                          Telnet is idle in state(s) 0
                          File is idle in state(s) 0
                          USB is idle in state(s) 0
                          Aux is idle in state(s) 0
                          Trigger is idle in state(s) 0
                          Queue is idle in state(s) 0
                          Daemon is idle in state(s) 0
                          Code queue is empty.
                          === Network ===
                          Slowest loop: 10.03ms; fastest: 0.02ms
                          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                          HTTP sessions: 2 of 8
                          Interface state active, link 100Mbps full duplex
                          Julian,
                          Old goat, learning new things….
                            No, nothing has changed since the previous 3.01 RCs. Is the hot end heating up at all?
                            • Dr_Ju_Juundefined
                              Dr_Ju_Ju
                              Yes, its heating that's why I was surprised....but fyi, I've just run an M303\M500 sequence and that at least lets me get to the working temp of 235 for my Petg...
                              Julian,
                              • jbarrosundefined
                                jbarros
                                I'm having the same issue on 3.01-RC5:
                                30/03/2020, 23:50:03 Cancelled printing file 0:/gcodes/20mm_calibration_cube.gcode, print time was 0h 36m
                                Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                                30/03/2020, 23:48:35 Printing paused at X34.9 Y44.1 Z8.1
                                30/03/2020, 23:48:35 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                                30/03/2020, 23:48:32 Error: Temperature reading fault on heater 1: short-circuit in sensorResume state saved
                                30/03/2020, 23:48:31 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                                30/03/2020, 23:48:27 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                                30/03/2020, 23:48:23 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                                30/03/2020, 23:48:18 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                                30/03/2020, 23:48:15 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                                30/03/2020, 23:48:11 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                                I'm using a PT100 with an official Duet PT100 temperature sensor board
                                My sensors config:
                                M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
                                I happened the 3 times I tried to print.
                                Since I just finished building this printer I was afraid I had some cable, plug, sensor, board issue but was unable to reproduce any errors by flexing the cables.
                                Edit: the temperature reading I got was 2000, the same I get on open circuit
                                tobias_munichundefined 1 Reply Last reply Reply Quote 0
                                • tobias_munichundefined
                                  tobias_munich @jbarros
                                  @jbarros have you tuned your heaters?
                                  https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                                  Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
                                  Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
                                  Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
                                  jbarrosundefined 1 Reply Last reply Reply Quote 0
                                  • jbarrosundefined
                                    jbarros @tobias_munich
                                    @tobias_munich
                                    indeed I have:
                                    ; config-override.g file generated in response to M500 at 2020-03-30 01:58
                                    ; Heater model parameters
                                    M307 H0 A154.3 C287.0 D3.0 S1.00 V24.3 B0
                                    M307 H1 A467.5 C123.2 D5.5 S1.00 V24.2 B0
                                      I think either you have a genuine a short circuit, or you have very severe interference on the PT100 leads. Please post a photo of the top of your daughter board so that I can see whether it is the latest version with extra filter capacitors.
                                      • jbarrosundefined
                                        jbarros @dc42
                                        Mine is v0.4
                                        I have 2 AWG24 UTP cables running to my hotend
                                        The cable with the PT100 wires also serves 2 fans. Does that fit your "severe interference" suspicion?
                                          dc42 administrators @jbarros
                                          Usually it's only adjacent stepper motor wiring that causes enough interference to be problematic, and only on boards without the extra filter capacitors.
                                          • zorro_66undefined
                                            zorro_66
                                            I'm trying to upgrade the firmware on my maestro card but am getting the following error
                                            M997 S0
                                            Error: M997: In-application programming binary "DuetMaestroIAP.bin" not found
