    RepRapFirmware 3.01-RC5 available
    Beta Firmware
    12
    37
    1.9k
      I've just added version 3.01-RC5 firmware binaries for Duet 3 tool boards and expansion board to this release.
      • SIamundefined
        SIam @dc42
        i have printet now the same thing (a little bit faster) and have this result
        29.3.2020, 12:09:45: Datei covid19_headband_rc3(6).gcode erfolgreich nach 13s hochgeladen
        29.3.2020, 12:09:46: M32 "0:/gcodes/covid19_headband_rc3(6).gcode": File 0:/gcodes/covid19_headband_rc3(6).gcode selected for printing
        29.3.2020, 12:20:46: : Leadscrew adjustments made: -0.076 -0.079 -0.066, points used 3, (mean, deviation) before (-0.073, 0.005) after (-0.000, 0.000)
        Auto kalibrierung erfolgreich, Abweichung von:  0.005mm
        Happy Printing
        29.3.2020, 13:54:23: : Finished printing file 0:/gcodes/covid19_headband_rc3(6).gcode, print time was 22h 12m
        This print is ca. 13 hours later as the first one (the printer was not switched off), if i calculate the first print time response from duet 9h 11m + 13 hours then the result is 22h 11 so i think the start time of a print will not set the printing time to zero.
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
          I confirm the problem with incorrect print time. It will report the time since the Duet was last powered up or reset.
          • TCundefined
            TC
            I am not sure if this is a new issue but can you checck the multiplication operator. It seems not to work at all
              dc42 administrators @TC
              @TC said in RepRapFirmware 3.01-RC5 available:
              It works if you enclose the expression in { } but not otherwise. That's because * normally introduces an end-of-line checksum.
              • TCundefined
                TC
                Ah ok. Maybe that is also something that could be mentioned in the documentation 😉
                • Dr_Ju_Juundefined
                  Dr_Ju_Ju
                  Has anything changed in the heating routines ? as since I've updated to RC5 my hot-end heater keeps throwing this error:
                  "Error: Heating fault on heater 1, temperature rising much more slowly than the expected 1.7°C/sec"
                  which I've never had on the previous RC's & RRF2x. nothing has changed on the hardware side & I've even power cycled, in case it was just an anomaly....
                  M115
                  FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.01-RC5 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2020-03-27b3
                  M122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC5 running on Duet Ethernet 1.02 or later
                  Board ID: 08DGM-95BNL-MGPSJ-6J1F2-3SD6L-9JZHX
                  Used output buffers: 1 of 24 (10 max)
                  Static ram: 28052
                  Dynamic ram: 93204 of which 44 recycled
                  Exception stack ram used: 256
                  Never used ram: 9516
                  Tasks: NETWORK(ready,748) HEAT(blocked,1244) MAIN(running,1844) IDLE(ready,76)
                  Owned mutexes:
                  Last reset 00:00:55 ago, cause: software
                  Last software reset at 2020-03-31 11:27, reason: User, spinning module GCodes, available RAM 9516 bytes (slot 2)
                  Error status: 0
                  Free file entries: 10
                  MCU temperature: min 29.9, current 31.2, max 31.6
                  Supply voltage: min 24.2, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                  Cache data hit count 108426845
                  Slowest loop: 6.93ms; fastest: 0.11ms
                  Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                  === MainDDARing ===
                  Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                  === AuxDDARing ===
                  Heater 0 is on, I-accum = 0.0
                  Heater 1 is on, I-accum = 0.0
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 10.03ms; fastest: 0.02ms
                  Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                  HTTP sessions: 2 of 8
                  Interface state active, link 100Mbps full duplex
                  Julian,
                  Old goat, learning new things….
                    No, nothing has changed since the previous 3.01 RCs. Is the hot end heating up at all?
                    • Dr_Ju_Juundefined
                      Dr_Ju_Ju
                      Yes, its heating that's why I was surprised....but fyi, I've just run an M303\M500 sequence and that at least lets me get to the working temp of 235 for my Petg...
                      Julian,
                      • jbarrosundefined
                        jbarros
                        I'm having the same issue on 3.01-RC5:
                        30/03/2020, 23:50:03 Cancelled printing file 0:/gcodes/20mm_calibration_cube.gcode, print time was 0h 36m
                        Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                        30/03/2020, 23:48:35 Printing paused at X34.9 Y44.1 Z8.1
                        30/03/2020, 23:48:35 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                        30/03/2020, 23:48:32 Error: Temperature reading fault on heater 1: short-circuit in sensorResume state saved
                        30/03/2020, 23:48:31 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                        30/03/2020, 23:48:27 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                        30/03/2020, 23:48:23 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                        30/03/2020, 23:48:18 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                        30/03/2020, 23:48:15 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                        30/03/2020, 23:48:11 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                        I'm using a PT100 with an official Duet PT100 temperature sensor board
                        My sensors config:
                        M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
                        I happened the 3 times I tried to print.
                        Since I just finished building this printer I was afraid I had some cable, plug, sensor, board issue but was unable to reproduce any errors by flexing the cables.
                        Edit: the temperature reading I got was 2000, the same I get on open circuit
                        tobias_munichundefined 1 Reply Last reply Reply Quote 0
                        • tobias_munichundefined
                          tobias_munich @jbarros
                          @jbarros have you tuned your heaters?
                          https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                          Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
                          Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
                          Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
                          jbarrosundefined 1 Reply Last reply Reply Quote 0
                          • jbarrosundefined
                            jbarros @tobias_munich
                            @tobias_munich
                            indeed I have:
                            ; config-override.g file generated in response to M500 at 2020-03-30 01:58
                            ; Heater model parameters
                            M307 H0 A154.3 C287.0 D3.0 S1.00 V24.3 B0
                            M307 H1 A467.5 C123.2 D5.5 S1.00 V24.2 B0
                              I think either you have a genuine a short circuit, or you have very severe interference on the PT100 leads. Please post a photo of the top of your daughter board so that I can see whether it is the latest version with extra filter capacitors.
                              • jbarrosundefined
                                jbarros @dc42
                                Mine is v0.4
                                I have 2 AWG24 UTP cables running to my hotend
                                The cable with the PT100 wires also serves 2 fans. Does that fit your "severe interference" suspicion?
                                  dc42 administrators @jbarros
                                  Usually it's only adjacent stepper motor wiring that causes enough interference to be problematic, and only on boards without the extra filter capacitors.
                                  • zorro_66undefined
                                    zorro_66
                                    I'm trying to upgrade the firmware on my maestro card but am getting the following error
                                    M997 S0
                                    Error: M997: In-application programming binary "DuetMaestroIAP.bin" not found
                                    DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                                    • DIY-O-Sphereundefined
                                      DIY-O-Sphere @zorro_66
                                      @zorro_66
                                      From witch version. If you are on RRF 2 you must upgrade to 3. 0 first.
                                      (UTC+1)
                                      • zorro_66undefined
                                        zorro_66
                                        i´m on Firmware: RepRapFirmware for Duet 2 Maestro 3.01-RC4 (2020-03-16b1)
                                          Download DuetMaestroIAP.bin from the 3.0 release and upload it to /sys on your Duet.
                                          • zorro_66undefined
                                            zorro_66
                                            Worked perfectly thanks ...
