    Cambio elettronica
    124
    6.4k
    • Danalundefined
      Danal
      Good afternoon everybody.
      After two years of absence and inactivity I decided to return.
      Some time ago I purchased the X5SA PRO printer from Tronxy which mounts a 24v electronic "CXY-V8-190729" with self leveling.
      The mechanics is a Corexy with industrial linear guides.
      The Firmware is of the chitu adapted to the tronxy and therefore cannot be modified.
      Four days ago the electronics got stuck in the sense that it no longer accepted the commands, so I decided
      to change the card with the duet2 wifi that I already had and mounted on another Cartesian printer with plastic frame "I3 Pro B from geeetech"
      Since the original i3 pro b printer was 12v then added a 24v power supply and mounted the duet2 wifi card.
      After looking and looking at the wiring, I decided to change the card, so far so good.
      Yesterday I turn on the printer with the new card, fantastic it turned on without any problem
      Now there are the configuration problems, having read several treed translated into Italian "I don't know English 😥" and with various confusion because it is not that the translation makes it clear what the interlocutor writes. So I decided to join here and help out all of you as best I can by describing what I did and how I did it.
      Let's start with order:
      Firmware to be updated
      controlweb to update
      Z probe model (XY-08N NPN NO - DC6-36v 3 wires + / - / S)
      Point 1: I updated the firmware from 2.05 to version 3 but it was not successful, that is, after updating it it always gave me the FW 2.05 so from webcontrol I deleted the FW 2.05 from the SD card and reinstalled the 3.0 now works, here of then I put the log.
      console.txt
      Point 2: no problem here, I uploaded via webcontrol in "system / upload system files" once uploaded the file asks you to reset everything, gives the ok and everything is done.
      As for point 1, someone found problems with the "2000 C" off-scale temperatures, I also had the same problem but solved it as described in point 1.
      Step 3: how to connect the probe z of the tronxy, I connected the positive and negative to the output of the fan always running having 24v as power supply therefore also the fans work at 24v, the signal cable I connected it with a diode to the Z_Probe_in, with a tester I checked the output voltage of the probe that gave me 0.650 v in active mode, so it seems to work well (BEWARE of the voltage being at 24v also the sensor output will have 24 but having put a diode will have 'a voltage drop when active, the sensor in question detects aluminum, iron, steel, but NOT glass.
      I hope I have been of help to all those who have purchased a tronxy x5sa pro and want to change electronics, I also hope to be in the right tread.
      • Danalundefined
        Danal
        @Leblond Grazie!
        Questo è molto utile
        Per favore, contribuisci di più, in qualsiasi momento.
        Leblondundefined 1 Reply Last reply Reply Quote 0
        • Leblondundefined
          Leblond @Danal
          @Danal said in Cambio elettronica:
          @Leblond Grazie!
          ti ringario faro' il possibile
            droftarts administrators @Leblond
            @Leblond Thanks for your report!
            • Leblondundefined
              Leblond
              Ragazzi una domanda, dato che devo vedere se i motori girino nel verso giusto mi chiedevo se esisteva un modo per bypassare l'home di tutti gli assi, non vorrei che andassero a sbattere o peggio ancora rovinarmi il piatto di stampa.
                @Leblond Send M564 S0 H0 to allow moves without homing, and outside the limits of the print volume.
                • Leblondundefined
                  Leblond
                  @droftarts grazie
                  • Leblondundefined
                    Leblond
                    @droftarts said in Cambio elettronica:
                    M564 S0 H0
                    ho lanciato il comando M564 S0 H0, poi G1 X50 F200 non funziona, quindi ho provato a mandare l'asse x in home, ma mi si e' alzato l'asse Z, forse qualcosina non quadra
                      @Leblond It sounds like you have connected the stepper motors to the wrong pins! See the wiring diagram here for the motor connections: https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
                      If your wiring is correct, post your config.g file. Also send M115 and post the response.
                      • Leblondundefined
                        Leblond
                        0:/sys/config.g.bak
                        ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Mar 31 2020 13:40:08 GMT+0200 (Ora legale dell’Europa centrale)
                        M550 P"X5SA PRO" ; set printer name
                        M667 S1 ; select CoreXY mode
                        M552 S1 ; enable network
                        M586 P0 S1 ; enable HTTP
                        M586 P1 S0 ; disable FTP
                        M586 P2 S0 ; disable Telnet
                        M569 P2 S0 ; physical drive 2 goes backwards
                        M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
                        M84 S30 ; Set idle timeout
                        M208 X330 Y330 Z400 S0 ; set axis maxima
                        M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                        M557 X60:300 Y50:300 S20 ; define mesh grid
                        M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                        droftartsundefined 2 Replies Last reply Reply Quote 0
                          @Leblond said in Cambio elettronica:
                          config.g.bak
                          That's the backup file. Post 'config.g'.
                            M584 X0 Y1 Z2 E3
                            That looks okay. Note that the order of the driver pins on the board, from left to right, is E1, E0, X, Y, Z.
                            • Leblondundefined
                              Leblond
                              ;M667 S1 ; select CoreXY mode
                              M669 K1
                              M558 P5 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                              • Leblondundefined
                                Leblond
                                sicuramente e' tutto sbagliato ma l'ho fatto con il configuratore reprap
                                • Leblondundefined
                                  Leblond
                                  • Leblondundefined
                                    Leblond
                                    l'unico problema elettrico che ho riscontrato e' il colore dei fili
                                    2b rosso
                                    2a blu
                                    1a verde
                                    1b nero
                                    ma la connessione dei fili dei motori sono invertiti le fasi 1a e 1b
                                    che sia quello?
                                    • Leblondundefined
                                      Leblond
                                      cioe' i cavi dei motori che dovrebbero essere 2b-R 2a-B 1a-V 1b-N sui fili 1a e 1b sono invertiti
                                      • Leblondundefined
                                        Leblond
                                        G28
                                        Error: Z probe already triggered at start of probing move
                                        • Leblondundefined
                                          Leblond
                                          Ragazzi ho realmente bisogno di voi, non ce ne salto fuori, mi continua a dare come errore Z probe already triggered at start of probing move
                                          • Leblondundefined
                                            Leblond
                                            Non so come fargli cambiare stato
