    Cambio elettronica
    124
    6.4k
      droftarts administrators @Leblond
      @Leblond It sounds like you have connected the stepper motors to the wrong pins! See the wiring diagram here for the motor connections: https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
      If your wiring is correct, post your config.g file. Also send M115 and post the response.
      • Leblondundefined
        Leblond
        0:/sys/config.g.bak
        ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Mar 31 2020 13:40:08 GMT+0200 (Ora legale dell’Europa centrale)
        M550 P"X5SA PRO" ; set printer name
        M667 S1 ; select CoreXY mode
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M569 P2 S0 ; physical drive 2 goes backwards
        M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
        M84 S30 ; Set idle timeout
        M208 X330 Y330 Z400 S0 ; set axis maxima
        M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
        M557 X60:300 Y50:300 S20 ; define mesh grid
        M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
        droftartsundefined 2 Replies Last reply Reply Quote 0
          @Leblond said in Cambio elettronica:
          config.g.bak
          That's the backup file. Post 'config.g'.
            M584 X0 Y1 Z2 E3
            That looks okay. Note that the order of the driver pins on the board, from left to right, is E1, E0, X, Y, Z.
            • Leblondundefined
              Leblond
              ;M667 S1 ; select CoreXY mode
              M669 K1
              M558 P5 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
              • Leblondundefined
                Leblond
                sicuramente e' tutto sbagliato ma l'ho fatto con il configuratore reprap
                • Leblondundefined
                  Leblond
                  • Leblondundefined
                    Leblond
                    l'unico problema elettrico che ho riscontrato e' il colore dei fili
                    2b rosso
                    2a blu
                    1a verde
                    1b nero
                    ma la connessione dei fili dei motori sono invertiti le fasi 1a e 1b
                    che sia quello?
                    • Leblondundefined
                      Leblond
                      cioe' i cavi dei motori che dovrebbero essere 2b-R 2a-B 1a-V 1b-N sui fili 1a e 1b sono invertiti
                      • Leblondundefined
                        Leblond
                        G28
                        Error: Z probe already triggered at start of probing move
                        • Leblondundefined
                          Leblond
                          Ragazzi ho realmente bisogno di voi, non ce ne salto fuori, mi continua a dare come errore Z probe already triggered at start of probing move
                          • Leblondundefined
                            Leblond
                            Non so come fargli cambiare stato
                            • Leblondundefined
                              Leblond
                              smanettando qualcosa e' cambiato non so il perche' ma nel file home x e y invece di sondare a 0 sondava a 335
                              adesso l'errore e' cambiato dicendomi G0/G1: insufficient axes homed
                                https://duet3d.dozuki.com/Wiki/FAQ#Section_I_get_this_error_message_Error_G0_G1_insufficient_axes_homed
                                Leblondundefined 1 Reply Last reply Reply Quote 0
                                • Leblondundefined
                                  Leblond @Phaedrux
                                  @Phaedrux ; homeall.g
                                  ; called to home all axes
                                  ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Mar 31 2020 22:19:23 GMT+0200 (Ora legale dell’Europa centrale)
                                  G91 ; relative positioning
                                  G1 H2 Z10 F3000 ; lift Z relative to current position
                                  G1 H1 X0 Y0 F500 ; move quickly to X or Y endstop and stop there (first pass)
                                  G1 H1 X0 ; home X axis
                                  G1 H1 Y0 ; home Y axis
                                  G1 X-5 Y-5 F500 ; go back a few mm
                                  G1 H1 X0 F360 ; move slowly to X axis endstop once more (second pass)
                                  G1 H1 Y0 ; then move slowly to Y axis endstop
                                  G90 ; absolute positioning
                                  G1 X60 Y50 F500 ; go to first bed probe point and home Z
                                  ;G91 ; relative positioning
                                  ;G1 Z10 F50 ; lift Z relative to current position
                                  ;G90 ; absolute positioning
                                  • Leblondundefined
                                    Leblond
                                    ; homez.g
                                    ; called to home the Z axis
                                    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Mar 31 2020 22:19:24 GMT+0200 (Ora legale dell’Europa centrale)
                                    G1 H2 Z-9999 F3000 ; lift Z relative to current position
                                    G1 X60 Y50 F3000 ; go to first probe point
                                    • Leblondundefined
                                      Leblond
                                      a sembra tutto ok, ma posso anche sbagliarmi
                                      • Leblondundefined
                                        Leblond
                                        ok ho fatto esperimento, ho mandato gli assi in home mettendo una parte mettalica sotto il sensore ma questo pur segnando 0 partendo da 1000 non si ferma
                                          Phaedrux Moderator @Leblond
                                          You need a distance for X and Y movement. 0 is no movement.
                                          Leblondundefined 2 Replies Last reply Reply Quote 0
                                          • Leblondundefined
                                            Leblond @Phaedrux
                                            @Phaedrux ho appena appurato che il sensore funziona ma che sia innescato o meno il piatto non si ferma ho usato anche questo parametro e credo sia corretto
                                            M558 P5 C"! zprobe.in" H10 F120 T500
