    RepRapFirmware 3.01-RC5 available
    Beta Firmware
    12
    37
    1.9k
    • Dr_Ju_Juundefined
      Dr_Ju_Ju
      Yes, its heating that's why I was surprised....but fyi, I've just run an M303\M500 sequence and that at least lets me get to the working temp of 235 for my Petg...
      Julian,
      Old goat, learning new things….
      • jbarrosundefined
        jbarros
        I'm having the same issue on 3.01-RC5:
        30/03/2020, 23:50:03 Cancelled printing file 0:/gcodes/20mm_calibration_cube.gcode, print time was 0h 36m
        Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
        30/03/2020, 23:48:35 Printing paused at X34.9 Y44.1 Z8.1
        30/03/2020, 23:48:35 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
        30/03/2020, 23:48:32 Error: Temperature reading fault on heater 1: short-circuit in sensorResume state saved
        30/03/2020, 23:48:31 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
        30/03/2020, 23:48:27 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
        30/03/2020, 23:48:23 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
        30/03/2020, 23:48:18 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
        30/03/2020, 23:48:15 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
        30/03/2020, 23:48:11 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
        I'm using a PT100 with an official Duet PT100 temperature sensor board
        My sensors config:
        M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
        I happened the 3 times I tried to print.
        Since I just finished building this printer I was afraid I had some cable, plug, sensor, board issue but was unable to reproduce any errors by flexing the cables.
        Edit: the temperature reading I got was 2000, the same I get on open circuit
        tobias_munichundefined 1 Reply Last reply Reply Quote 0
        • tobias_munichundefined
          tobias_munich @jbarros
          @jbarros have you tuned your heaters?
          https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
          Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
          Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
          Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
          jbarrosundefined 1 Reply Last reply Reply Quote 0
          • jbarrosundefined
            jbarros @tobias_munich
            @tobias_munich
            indeed I have:
            ; config-override.g file generated in response to M500 at 2020-03-30 01:58
            ; Heater model parameters
            M307 H0 A154.3 C287.0 D3.0 S1.00 V24.3 B0
            M307 H1 A467.5 C123.2 D5.5 S1.00 V24.2 B0
              I think either you have a genuine a short circuit, or you have very severe interference on the PT100 leads. Please post a photo of the top of your daughter board so that I can see whether it is the latest version with extra filter capacitors.
              • jbarrosundefined
                jbarros @dc42
                Mine is v0.4
                I have 2 AWG24 UTP cables running to my hotend
                The cable with the PT100 wires also serves 2 fans. Does that fit your "severe interference" suspicion?
                  dc42 administrators @jbarros
                  Usually it's only adjacent stepper motor wiring that causes enough interference to be problematic, and only on boards without the extra filter capacitors.
                  • zorro_66undefined
                    zorro_66
                    I'm trying to upgrade the firmware on my maestro card but am getting the following error
                    M997 S0
                    Error: M997: In-application programming binary "DuetMaestroIAP.bin" not found
                    DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                    • DIY-O-Sphereundefined
                      DIY-O-Sphere @zorro_66
                      @zorro_66
                      From witch version. If you are on RRF 2 you must upgrade to 3. 0 first.
                      (UTC+1)
                      • zorro_66undefined
                        zorro_66
                        i´m on Firmware: RepRapFirmware for Duet 2 Maestro 3.01-RC4 (2020-03-16b1)
                          Download DuetMaestroIAP.bin from the 3.0 release and upload it to /sys on your Duet.
                          • zorro_66undefined
                            zorro_66
                            Worked perfectly thanks ...
                            • bbergerundefined
                              bberger
                              Is there any documentation on how the object cancellation works?
                              I know that there isn't any interface for DWC (yet), but I might just patch that in if I get some spare time and an endpoint documentation.
                                droftarts administrators @bberger
                                @bberger See https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M486_Object_cancellation
                                and @dc42 's thread here: https://forum.duet3d.com/topic/15119/cancel-individual-objects-on-the-build-plate
                                No other documentation as yet. I believe that PrusaSlicer can generate appropriate tags, but haven't tested it yet.
                                @chrishamm was talking about adding it to DWC, but has other priorities at the moment, so I'm sure would be happy if someone else wanted to help out!
                                  dc42 administrators @droftarts
                                  @droftarts said in RepRapFirmware 3.01-RC5 available:
                                  To expand on this:
                                  • The "Label objects" option in PrusaSlicer will generate object labels in the GCode file that RRF 3.01-RC5 and -RC6 understand.
                                  • The list of known objects on the build plate and their XY limits is already included in the object model (send M409 K"job.build.objects" to retrieve it) so that future versions of DWC will be able to offer an interface to select an object to be cancelled.
                                  • Meanwhile, the M486 command can be used to cancel an object.
                                  • bbergerundefined
                                    bberger
                                    Thank you guys for your quick reply! Let's see if I can hack something together shortly.
                                    The switch to Vue and Vuetify greatly helps in my case. Thank you for going down that road!
                                    • jbarrosundefined
                                      jbarros @dc42
                                      Mine being a v0.4 and from reading other threads about this issue does not have the extra filter capacitors.
                                      2 UTP cables for fans and sensors, extruder heater AND extruder stepper cable all running at least 1m alongside each other might explain my issues.
                                      Waiting for proper cables from China, I used a temporary shielded cable just for this sensor.
                                      I'm happy to report the issue has not happened again 🙂
                                      • Pumluxundefined
                                        Pumlux
                                        Bug or feature ?
                                        Temperture is dopping during a long time consuming move / home all .
                                        I'm running a Duet Wifi 1.01 board and ugraded some weeks ago to RRF3.
                                        I noticed that the heater seems to be not heating if a time consuming move is made.
                                        In detail :
                                        I heat up the bed to 50 degrees and the extruder to 200 degrees and than I do homing all.
                                        During the move to home all axes the heater seems to be not heating, the time for homing was aprox. 2 min 30 sec and the extruder temperature drops from 200 to ~140 degrees. (see screenshot below ) when all the moves for homing are completed the temperature is rasing again to targeted 200 degrees.
                                        (I see this temperture drop on the long time z-axis movement, not sure about the x and y axis)
                                        In addtition, If the duet is heating up to the target temperature e.g. from 20 degrees to 200 degrees, I can not do printhead moves until temperture is reached (not always, I don't know what makes the difference here) .
                                        It looks like moves and heating can not be done in parallel, not sure if this behavior comes from the duet firmware or from the web firmware.
                                        I just noticed it on RRF 3.01 RC4 and RC5.
                                        Using a own build of a Mendel Max , Duet Wifi, Bed 8 mm Aluminium PEI 500 x 280 x 400 230 V 850 W, original E3D Chimera hotend with bowden length 700 mm, since short time with a BL-Touch, Steppers : mostly Nema 17 and one Nema 23 for Y-axis
                                          dc42 administrators @Pumlux
                                          @Pumlux said in RepRapFirmware 3.01-RC5 available:
                                          In detail :
                                          That will be because you have your M558 command set up to turn heaters off during bed probing (B1 parameter).
                                          You could avoid it by probing twice. First send M558 B0 to enable heating during probing; then do a G30 command; then raise Z a little; then send M558 B1 to disable heaters during probing (assuming that you need to in order to get accurate results); then do another G30.
                                          • Pumluxundefined
                                            Pumlux
                                            @DC42
                                            David you are fast and you are right. 👍 🙂
                                            Thanks for your helpfull advice.
                                            I had the M558 with B1 parameter (got is from setup example for BL-Touch) and wasn't aware of the impact of the B1 parameter.
                                            Keeping the heater on as default is the better choice. Not sure if the homing will be that much more accurate with heaters switched off. Would need to check this.
                                            With heaters off during homing I run into undertemperture issue with no extruding because of low temperture when the printhead was located very high over the bed. This is solved now.
