    WIP CoreXY with heated chamber
    My Duet controlled machine
    13
    68
    5.9k
    • DaBitundefined
      DaBit
      So far I am having decent results using a Chimaera for different support material. I placed the support nozzle ~30u higher than the main nozzle, which prevents dragging. Extensive cooling and wiping during a toolchange takes care of the ooze.
      It is slow as hell though. Idex or toolchanger would be way better.
      felt342undefined 1 Reply Last reply Reply Quote 0
      • felt342undefined
        felt342 @DaBit
        @DaBit
        Can you post your tool change files, please? 🙂
        Industrial 3D printing service in the Netherlands - gagatstudio.com
        • DaBitundefined
          DaBit
          Sure: https://www.icecoldcomputing.com/directlink/3dprinter/Dabit3D_config_10feb2020.zip
          Mind you, these files are a work-in-progress also. I reworked the tpostX.g files yesterday to improve the wiping process, and did not test them yet.
          felt342undefined 1 Reply Last reply Reply Quote 1
          • felt342undefined
            felt342 @DaBit
            @DaBit
            Thank you! I will give a try to it.
            • felt342undefined
              felt342
              Some updates on work in progress machine 🙂
              IMG_6333.JPEG IMG_6332.JPEG IMG_6331.JPEG IMG_6330.JPEG IMG_6325.JPEG IMG_6320.JPEG
              At this moment I am - working on lighting, sealing the chamber with aluminum foil, figuring out the door mechanism, wheels, and feet! Eventually, it became direct drive extruder, much happier with results!
              https://www.icloud.com/photos/#07fyEOQcG_z7WxKabaN22UowA
              • mrehorstdmdundefined
                mrehorstdmd
                Nice! Looks like you're getting great print quality, too.
                Does that center frame member on the top of the machine interfere with the extruder carriage cables/hoses? It looks like it might depending on the position along the X axis.
                • felt342undefined
                  felt342 @mrehorstdmd
                  @mrehorstdmd
                  Thank you!
                  Yes indeed it looks like it might, but I moved it to the right so it does not interfere. In the end, I will remove it, otherwise, the cable hose and liquid hose will be in touch with top cover and probably will mount cable chain.
                  The big thing I want to mount and test is a heated bed, but with this world situation of Corona I am already in a delay of 3 months...
                  There is my latest benchy 🙂
                  • felt342undefined
                    felt342
                    A bit of safety first! Kids around...
                    • felt342undefined
                      felt342
                      https://youtu.be/TYQHQd6ypSA
                      Its also visible how cantilevered bed is quite stable.
                      Print test - 100mm/s internal perimeters, exterior got 77 mm/sec.
                      • felt342undefined
                        felt342
                        And there is lighting, and top covered. Still waiting for a heated bed to come... 😐
                          mrehorstdmd
                          Do those print cooling fans actually move any air? Axial fans don't usually work against the back pressure that any sort of flow restrictor produces.
                          • felt342undefined
                            felt342
                            They do seems enough, but I must say they always on 75% to make me desirable result, meaning very loudly also :)).
                            Will you suggest to change on something else? I fully am open to comments and experience!
                              mrehorstdmd
                              Radial blowers move more air against the pressure produced by flow restrictors. This type of thing usually works better: https://www.amazon.com/FYSETC-Cooling-50x50x15mm-Radiator-Accessories/dp/B07NTKG9K4/ref=sr_1_15?crid=O279YCVTBA45&dchild=1&keywords=radial+fan+24v+for+3d+printer&qid=1585683940&sprefix=radial+fan%2Caps%2C168&sr=8-15
                              • felt342undefined
                                @mrehorstdmd
                                Thanks! Ordered! Need to figured out the connection method, as I want to place watercooling block later on the extruder motors... It doest not matter the position of how I can place radial fans?
                                  mrehorstdmd @felt342
                                  @felt342 I don't think the orientation of the blower matters, but probably best to check a data sheet if there is one.
                                  • felt342undefined
                                    @mrehorstdmd
                                    I see! I will design something and will post here to have a look.
                                    Turboundefined 1 Reply Last reply Reply Quote 0
                                    • Turboundefined
                                      Turbo @felt342
                                      @felt342 The cyclops hotend by E3D may be a good option for IDEX since you already have a chimera. you can also water-cool that.
                                      Cant stop tuning wont stop tuning.
                                      Dbot, Custom i3, Voron 0&2
                                      • Turboundefined
                                        Turbo @felt342
                                        @felt342 I'm looking forward to the finished build! Ive also got a corexy with a chimera hotend, although I'm not going as balls to the wall as you lol. Also i like your direct drive setup. is that your design or was that available online?
                                        Old picture. Linear rails added and different carriage design, not my design
                                        Phaedruxundefined felt342undefined 2 Replies Last reply Reply Quote 1
                                          Phaedrux Moderator @Turbo
                                          @Turbo Is that a dbot with a belted z axis? Link?
                                          • Turboundefined
                                            Turbo @Phaedrux
                                            @Phaedrux It was a custom design my friend made. I got this printer from him. I could see about putting them somewhere if hes cool with it, as he also gave me the files, but id have to make instructions or something.
                                            mrehorstdmdundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
