RepRapFirmware 3.01-RC6 released
Beta Firmware
27
165
12.2k
    chrishamm administrators @Dougal1957
    @Dougal1957 The stable list is still in there: sudo rm /etc/apt/sources.list.d/duet3d.list followed by sudo apt-get update should work for you
    Duet software engineer
    ? 1 Reply Last reply 3 Apr 2020, 12:43 Reply Quote 0
      A Former User @chrishamm
      @chrishamm said in RepRapFirmware 3.01-RC6 released:
      is that a problem, more importantly, should it be a problem?
        Dougal1957 @A Former User
        @bearer that sorted it Thanks very much as you probably imagine I am not good with LINUX at all although I am learning some of it
        ? 1 Reply Last reply 3 Apr 2020, 12:47 Reply Quote 0
          A Former User @Dougal1957
          @Dougal1957 i only translated
          @Dougal1957 Sorry, looks like like this file was missing in the RRF package, I've just added it back and uploaded it to another location: http://pkg.duet3d.com/Duet3iap_spi_MB6HC.bin You may need to rename it to Duet3iap_spi.bin.
          into copy/paste; and we all had to learn at some point
          undefined 1 Reply Last reply 3 Apr 2020, 13:53 Reply Quote 0
            @bearer Prob is that I am getting a bit old you know the saying about teaching old Dogs new tricks lol
            ? 1 Reply Last reply 3 Apr 2020, 13:55 Reply Quote 0
              @Dougal1957 you're trying, and succeeding; no-one gonna fault you for that.
                chas2706
                Just upgraded and having issues.
                On the SBC display DWC reports that the sys drive is unmounted:
                But in web browser DWC looks ok but nothing works when clicked:
                Any ideas?
                ? 1 Reply Last reply 3 Apr 2020, 14:00 Reply Quote 0
                  A Former User @chas2706
                  @chas2706 said in RepRapFirmware 3.01-RC6 released:
                  see what ls -l /opt/dsf/sd says in a ssh shell?
                  undefined 1 Reply Last reply 3 Apr 2020, 14:14 Reply Quote 0
                    chas2706
                    @bearer said in RepRapFirmware 3.01-RC6 released:
                    ls -l /opt/dsf/sd
                    I get this:
                    pi@Duet3:~ $ ls -l /opt/dsf/sd
                    total 20
                    drwxr-xr-x 4 pi pi 4096 Mar 6 17:13 filaments
                    drwxr-xr-x 2 pi pi 4096 Apr 3 11:45 firmware
                    drwxr-xr-x 3 pi pi 4096 Apr 3 13:56 gcodes
                    drwxr-xr-x 9 pi pi 4096 Mar 17 09:08 macros
                    drwxr-xr-x 5 pi pi 4096 Apr 3 13:48 sys
                    lrwxrwxrwx 1 pi pi 7 Oct 22 12:00 www -> ../dwc2
                    pi@Duet3:~ $
                    ? 1 Reply Last reply 3 Apr 2020, 14:12 Reply Quote 0
                      not sure if dcs is run as pi instead of root now, i'll leave that to someone else to confirm or correct.
                        Danal
                        Two errors, on a machine that started on RC4. It may be worth noting the machine was built from the Duet (full) image, and the instructions for moving to the unstable feed were followed via copy/paste. I'd be happy to report anything you guys need to see; the point of the above being it should be set up correctly.
                        Anyway, first error:
                        4/3/2020, 8:41:16 AM M997
                        Error: M997: Failed to find IAP file /opt/dsf/sd/sys/Duet3iap_spi.bin
                        As suggested above, wget http://pkg.duet3d.com/Duet3iap_spi_MB6HC.bin -O opt/dsf/sd/sys/Duet3iap_spi.bin fixed this.
                        However, I then received:
                        4/3/2020, 8:42:46 AM M997
                        Error: M997: Failed to find firmware file /opt/dsf/sd/sys/Duet3Firmware.bin
                        I tried to fix this with a symlink, this did not work. ln -s Duet3Firmware_MB6HC.bin Duet3Firmware.bin
                        lrwxrwxrwx 1 pi   pi       23 Apr  3 08:58 Duet3Firmware.bin -> Duet3Firmware_MB6HC.bin
                        I then ran sudo apt install reprapfirmware --reinstall and this did work. Including updating the main board to RC6. The symlink was still in place; this may or may not have made a difference.
                        Expansion board updates worked, and report RC5.
                        4/3/2020, 9:12:59 AM M115 B0
                        FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.01-RC6 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-04-03b3
                        4/3/2020, 9:12:55 AM M115 B2
                        Board EXP3HC firmware 3.01-RC5 (2020-03-29b1)
                        4/3/2020, 9:12:45 AM M115 B1
                        Board: Duet 3 MB6HC (MB6HC)
                        DSF Version: 1.3.0.0
                        Firmware: RepRapFirmware for Duet 3 MB6HC 3.01-RC6 (2020-04-03b3)
                        Duet Web Control 2.1.0
                          Danal @A Former User
                          I had this for a few moments. An "emergency stop" restart fixed it, and/or a sudo service duetcontrolserver restart I'm not sure which.
                            chas2706
                            @Danal said in RepRapFirmware 3.01-RC6 released:
                            I had this for a few moments. An "emergency stop" restart fixed it.
                            My estop doesn't work either on DWC web page or SBC display.
                              Danal
                              Just remembered, it may have been a sudo service duetcontrolserver restart I'm not sure which really fixed it.
                                chas2706
                                Just applied that and now I get this on SBC display:
                                  Danal
                                  It looks like something didn't upgrade, either the board or the DSF, and they won't connect. I'd try a power cycle first. Just to be sure everything that is there has an opportunity to connect.
                                  If that does not work, then I'd start re-installing things, such as:
                                  sudo apt install duetsoftwareframework --reinstall
                                  The full dependency list for DSF is:
                                  Depends: duetcontrolserver
                                  Depends: duetsd
                                  Depends: duettools
                                  Depends: duetwebserver
                                  Depends: duetwebcontrol
                                  Depends: reprapfirmware
                                  Re-Installs can't really hurt anything; if it gets beyond that, it may take @DC42 or @chrishamm to advise how to fix.
                                    chas2706
                                    I will try to re-install but not to worry if it fails because I have backup copies.
                                    Thanks for your help.
                                      jay_s_uk
                                      My duet 3 + pi updated without issue
                                        garyd9 @dc42
                                        @dc42 said in RepRapFirmware 3.01-RC6 released:
                                        The release notes are at https://github.com/dc42/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md.
                                        ... If you were using M308 H or L parameters for thermistors attached to a Duet 3 main board, you will need to adjust those values
                                        ... The M308 thermistor H and L parameters on Duet 3 main boards have been re-scaled to match the scaling used on Duet 3 expansion and tool boards.
                                        Can you please publish the old scaling in the release notes to make it easier to adjust M308 L/H values? Even better would be a simple equation that people can just plug their old values into to get the new values.
                                        For example, I have the following M308 (with L/H values carried since using a duet2 on RRF 1.19):
                                        M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B3950  R4700 L54 H-97
                                        Thank you
                                        Gary
                                        undefined 1 Reply Last reply 3 Apr 2020, 17:37 Reply Quote 0
                                          Marco Bona
                                          After updating my Duet Wifi I report three problems that I am having:
                                          1_ I continue to have the problem with the correct visualization of the Layers (yesterday @droftarts said it would be solved with the new build)
                                          2_When I load the filament from DWC I cannot see the list of saved filaments and it seems that the tool change is being performed.
                                          3_After restarting the emergency button, the restart is not performed.
                                          droftartsundefined 1 Reply Last reply 3 Apr 2020, 23:14 Reply Quote 0
                                          30 out of 165
