    RepRapFirmware 3.01-RC6 released
    Beta Firmware
    27
    165
    12.7k
      A Former User @chas2706
      @chas2706 said in RepRapFirmware 3.01-RC6 released:
      On the SBC display DWC reports that the sys drive is unmounted:
      see what ls -l /opt/dsf/sd says in a ssh shell?
      • chas2706undefined
        chas2706
        @bearer said in RepRapFirmware 3.01-RC6 released:
        ls -l /opt/dsf/sd
        I get this:
        pi@Duet3:~ $ ls -l /opt/dsf/sd
        total 20
        drwxr-xr-x 4 pi pi 4096 Mar 6 17:13 filaments
        drwxr-xr-x 2 pi pi 4096 Apr 3 11:45 firmware
        drwxr-xr-x 3 pi pi 4096 Apr 3 13:56 gcodes
        drwxr-xr-x 9 pi pi 4096 Mar 17 09:08 macros
        drwxr-xr-x 5 pi pi 4096 Apr 3 13:48 sys
        lrwxrwxrwx 1 pi pi 7 Oct 22 12:00 www -> ../dwc2
        pi@Duet3:~ $
          not sure if dcs is run as pi instead of root now, i'll leave that to someone else to confirm or correct.
          • Danalundefined
            Danal
            Two errors, on a machine that started on RC4. It may be worth noting the machine was built from the Duet (full) image, and the instructions for moving to the unstable feed were followed via copy/paste. I'd be happy to report anything you guys need to see; the point of the above being it should be set up correctly.
            Anyway, first error:
            4/3/2020, 8:41:16 AM	M997
            Error: M997: Failed to find IAP file /opt/dsf/sd/sys/Duet3iap_spi.bin
            As suggested above, wget http://pkg.duet3d.com/Duet3iap_spi_MB6HC.bin -O opt/dsf/sd/sys/Duet3iap_spi.bin fixed this.
            However, I then received:
            4/3/2020, 8:42:46 AM	M997
            Error: M997: Failed to find firmware file /opt/dsf/sd/sys/Duet3Firmware.bin
            I tried to fix this with a symlink, this did not work. ln -s Duet3Firmware_MB6HC.bin Duet3Firmware.bin
            lrwxrwxrwx 1 pi   pi       23 Apr  3 08:58 Duet3Firmware.bin -> Duet3Firmware_MB6HC.bin
            I then ran sudo apt install reprapfirmware --reinstall and this did work. Including updating the main board to RC6. The symlink was still in place; this may or may not have made a difference.
            Expansion board updates worked, and report RC5.
            4/3/2020, 9:12:59 AM	M115 B0
            FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.01-RC6 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-04-03b3
            4/3/2020, 9:12:55 AM	M115 B2
            Board EXP3HC firmware 3.01-RC5 (2020-03-29b1)
            4/3/2020, 9:12:45 AM	M115 B1
            Board: Duet 3 MB6HC (MB6HC)
            DSF Version: 1.3.0.0
            Firmware: RepRapFirmware for Duet 3 MB6HC 3.01-RC6 (2020-04-03b3)
            Duet Web Control 2.1.0
            • Danalundefined
              Danal @A Former User
              I had this for a few moments. An "emergency stop" restart fixed it, and/or a sudo service duetcontrolserver restart I'm not sure which.
              • chas2706undefined
                chas2706
                @Danal said in RepRapFirmware 3.01-RC6 released:
                I had this for a few moments. An "emergency stop" restart fixed it.
                My estop doesn't work either on DWC web page or SBC display.
                • Danalundefined
                  Danal
                  Just remembered, it may have been a sudo service duetcontrolserver restart I'm not sure which really fixed it.
                  • chas2706undefined
                    chas2706
                    Just applied that and now I get this on SBC display:
                    • Danalundefined
                      Danal
                      It looks like something didn't upgrade, either the board or the DSF, and they won't connect. I'd try a power cycle first. Just to be sure everything that is there has an opportunity to connect.
                      If that does not work, then I'd start re-installing things, such as:
                      sudo apt install duetsoftwareframework --reinstall
                      The full dependency list for DSF is:
                      Depends: duetcontrolserver
                      Depends: duetsd
                      Depends: duettools
                      Depends: duetwebserver
                      Depends: duetwebcontrol
                      Depends: reprapfirmware
                      Re-Installs can't really hurt anything; if it gets beyond that, it may take @DC42 or @chrishamm to advise how to fix.
                      • chas2706undefined
                        chas2706
                        I will try to re-install but not to worry if it fails because I have backup copies.
                        Thanks for your help.
                          jay_s_uk
                          My duet 3 + pi updated without issue
                          • garyd9undefined
                            garyd9 @dc42
                            @dc42 said in RepRapFirmware 3.01-RC6 released:
                            The release notes are at https://github.com/dc42/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md.
                            ... If you were using M308 H or L parameters for thermistors attached to a Duet 3 main board, you will need to adjust those values
                            ... The M308 thermistor H and L parameters on Duet 3 main boards have been re-scaled to match the scaling used on Duet 3 expansion and tool boards.
                            Can you please publish the old scaling in the release notes to make it easier to adjust M308 L/H values? Even better would be a simple equation that people can just plug their old values into to get the new values.
                            For example, I have the following M308 (with L/H values carried since using a duet2 on RRF 1.19):
                            M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B3950  R4700 L54 H-97
                            Thank you
                            Gary
                            • Marco Bonaundefined
                              Marco Bona
                              After updating my Duet Wifi I report three problems that I am having:
                              1_ I continue to have the problem with the correct visualization of the Layers (yesterday @droftarts said it would be solved with the new build)
                              2_When I load the filament from DWC I cannot see the list of saved filaments and it seems that the tool change is being performed.
                              3_After restarting the emergency button, the restart is not performed.
                                Marco Bona
                                Sorry but I was wrong to do something, after turning off and on now point 3 works correctly
                                • garyd9undefined
                                  garyd9
                                  Updating only DWC to 2.1.0 on a duet3 (SD) with RRF-RC3 results in an inability to use DWC whatsoever. It appears that the DWC page keeps trying to refresh over and over, and the following shows up in the lower-right corner repeatedly:
                                  @chrishamm
                                    jay_s_uk
                                    Bug
                                    On a duet 2 running RRF3.01-RC6 and DWC 2.1.0 I am unable to retract or extrude filament manually using the buttons.
                                    Even sending M302 P1 does not allow me to manually retract or extrude the filament.
                                    T0 is active and up to temperature
                                    Adrian52undefined dc42undefined 2 Replies Last reply Reply Quote 0
                                      dc42 administrators @garyd9
                                      @garyd9 said in RepRapFirmware 3.01-RC6 released:
                                      Thank you
                                      Gary
                                      For Duet 3 main board, dividing your old correction by 8 should give the new value.
                                      garyd9undefined 1 Reply Last reply Reply Quote 0
                                      • Adrian52undefined
                                        Adrian52 @jay_s_uk
                                        @jay_s_uk +1
                                          dc42 administrators @jay_s_uk
                                          @jay_s_uk said in RepRapFirmware 3.01-RC6 released:
                                          Bug
                                          I confirm this is a bug. Try reverting to DWC 2.0.7.
                                          • chrishammundefined
                                            chrishamm administrators @garyd9
                                            @garyd9 RC3 is likely incompatibe, upgrade to RC6. If you have no way to exchange DWC2, enter forceLegacyConnect = true into your JS console (open via F12) and it should connect using the old rr_status requests.
                                            I'll look into the other reports.
                                            Duet software engineer
