    RepRapFirmware 3.01-RC6 released
    Beta Firmware
    27
    165
    12.6k
    • Marco Bonaundefined
      Marco Bona
      Sorry but I was wrong to do something, after turning off and on now point 3 works correctly
      • garyd9undefined
        garyd9
        Updating only DWC to 2.1.0 on a duet3 (SD) with RRF-RC3 results in an inability to use DWC whatsoever. It appears that the DWC page keeps trying to refresh over and over, and the following shows up in the lower-right corner repeatedly:
        @chrishamm
          jay_s_uk
          Bug
          On a duet 2 running RRF3.01-RC6 and DWC 2.1.0 I am unable to retract or extrude filament manually using the buttons.
          Even sending M302 P1 does not allow me to manually retract or extrude the filament.
          T0 is active and up to temperature
          Adrian52undefined dc42undefined 2 Replies Last reply Reply Quote 0
            dc42 administrators @garyd9
            @garyd9 said in RepRapFirmware 3.01-RC6 released:
            @dc42 said in RepRapFirmware 3.01-RC6 released:
            The release notes are at https://github.com/dc42/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md.
            ... If you were using M308 H or L parameters for thermistors attached to a Duet 3 main board, you will need to adjust those values
            ... The M308 thermistor H and L parameters on Duet 3 main boards have been re-scaled to match the scaling used on Duet 3 expansion and tool boards.
            Can you please publish the old scaling in the release notes to make it easier to adjust M308 L/H values? Even better would be a simple equation that people can just plug their old values into to get the new values.
            For example, I have the following M308 (with L/H values carried since using a duet2 on RRF 1.19):
            M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B3950  R4700 L54 H-97
            Thank you
            Gary
            For Duet 3 main board, dividing your old correction by 8 should give the new value.
            garyd9undefined 1 Reply Last reply Reply Quote 0
            • Adrian52undefined
              Adrian52 @jay_s_uk
              @jay_s_uk +1
                dc42 administrators @jay_s_uk
                @jay_s_uk said in RepRapFirmware 3.01-RC6 released:
                Bug
                I confirm this is a bug. Try reverting to DWC 2.0.7.
                • chrishammundefined
                  chrishamm administrators @garyd9
                  @garyd9 RC3 is likely incompatibe, upgrade to RC6. If you have no way to exchange DWC2, enter forceLegacyConnect = true into your JS console (open via F12) and it should connect using the old rr_status requests.
                  I'll look into the other reports.
                  Duet software engineer
                  • garyd9undefined
                    garyd9 @dc42
                    Thank you.
                    @chrishamm said in RepRapFirmware 3.01-RC6 released:
                    I had already pulled the sdcard and copied DWC 2.0.7 when I posted. I wanted to upgrade DWC first to see if the issue with it not prompting for a firmware upgrade on duet3 board was fixed. (Which, by the way, I can confirm as being fixed.)
                    • chas2706undefined
                      chas2706
                      @chas2706 said in RepRapFirmware 3.01-RC6 released:
                      I will try to re-install but not to worry if it fails because I have backup copies.
                      Upgrade failed.
                      Still get message "drive is unmounted so I gave up.
                      Managed to re-install rrf3.01.RC3 but DWC is wrong version for this build. how do I obtain DWC version 2.0.7?
                      • gruenundefined
                        gruen
                        I come from working RC5 on 6HC. After the update works nothing!
                        • ChrisPundefined
                          ChrisP
                          Running a Duet3 with an RPi4 as an SBC. Updated using apt and have ended up with loads of issues. The first was the "drive is unmounted" error everywhere and a screen the same as teh one in the post above which I could only get rid of by power cycling.
                          The web interface now loads but while the extruder is listed under tools, the bed isn't. The status also continually says "Busy" in a yellow box. Pressing emergency stop / M112 results in the Duet crashing and not starting up again (the thermostatic fan runs constantly) until the power is cycled.
                          Allowing a restart after editing config.g results in no tools being shown at all.
                          M122 Dump:
                          RepRapFirmware for Duet 3 MB6HC version 3.01-RC6 running on Duet 3 MB6HC v0.6 or 1.0
                          Board ID: 08DJM-956L2-G43S8-6J1FJ-3SD6M-9S3GF
                          Used output buffers: 1 of 40 (10 max)
                          Static ram: 154084
                          Dynamic ram: 161268 of which 24 recycled
                          Exception stack ram used: 320
                          Never used ram: 77520
                          Tasks: NETWORK(ready,2076) HEAT(blocked,1196) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,216) MAIN(running,4920) IDLE(ready,76)
                          Owned mutexes:
                          Last reset 00:06:48 ago, cause: power up
                          Last software reset at 2020-04-03 21:25, reason: User, spinning module LinuxInterface, available RAM 77760 bytes (slot 3)
                          Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
                          Error status: 0
                          Free file entries: 10
                          MCU temperature: min 43.4, current 46.9, max 47.0
                          Supply voltage: min 11.9, current 12.0, max 12.2, under voltage events: 0, over voltage events: 0, power good: yes
                          12V rail voltage: min 11.2, current 11.2, max 11.5, under voltage events: 0
                          Driver 0: standstill, reads 54044, writes 14 timeouts 0, SG min/max 0/0
                          Driver 1: standstill, reads 54044, writes 14 timeouts 0, SG min/max 0/0
                          Driver 2: standstill, reads 54045, writes 14 timeouts 0, SG min/max 0/0
                          Driver 3: standstill, reads 54046, writes 13 timeouts 0, SG min/max 0/0
                          Driver 4: standstill, reads 54047, writes 12 timeouts 0, SG min/max 0/0
                          Driver 5: standstill, reads 54048, writes 12 timeouts 0, SG min/max 0/0
                          Date/time: 2020-04-03 21:40:44
                          Slowest loop: 3.62ms; fastest: 0.21ms
                          === MainDDARing ===
                          === AuxDDARing ===
                          Segments left: 0
                          Movement lock held by null
                          HTTP* is ready with "M122" in state(s) 0
                          Telnet is idle in state(s) 0
                          File is idle in state(s) 0
                          USB is idle in state(s) 0
                          Aux is idle in state(s) 0
                          Queue is idle in state(s) 0
                          LCD is idle in state(s) 0
                          SBC is idle in state(s) 0
                          Daemon* is idle in state(s) 0
                          Code queue is empty.
                          === Network ===
                          Slowest loop: 0.66ms; fastest: 0.01ms
                          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                          HTTP sessions: 0 of 8
                          - Ethernet -
                          State: disabled
                          Error counts: 0 0 0 0 0
                          === Filament sensors ===
                          Extruder 0: pos 0.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                          === CAN ===
                          Messages sent 1544, longest wait 0ms for type 0
                          === Linux interface ===
                          State: 0, failed transfers: 0
                          Last transfer: 18ms ago
                          RX/TX seq numbers: 12011/12012
                          SPI underruns 0, overruns 0
                          Number of disconnects: 0
                          Buffer RX/TX: 0/0-0
                          === Duet Control Server ===
                          Duet Control Server v1.3.0.0
                          Code buffer space: 4096
                          Full transfers per second: 22.67
                          • chas2706undefined
                            chas2706
                            @ChrisP said in RepRapFirmware 3.01-RC6 released:
                            Glad to hear i'm not alone.
                            I don't know what the issue is. I did a back up of the pi sd a while ago and even when I revert to that and then update It has the same issues. Nothing works because the DWC says "drive is unmounted".
                            ChrisPundefined 1 Reply Last reply Reply Quote 0
                            • ChrisPundefined
                              ChrisP @chas2706
                              @chas2706 Did power cycling fix that issue for you? It did for me. MInd you, even when that works, the printer is still unusable.
                              A colleague of mine is just upgrading an E3D toolchanger to the same Duet3 + SBC setup, has just updated before we saw all this and is now in the same situation. (edit: post below)
                              • elliott.griffithsundefined
                                elliott.griffiths @tobias_munich
                                @tobias_munich I got the same behaviour after updating.
                                tobias_munichundefined 1 Reply Last reply Reply Quote 0
                                  A Former User @ChrisP
                                  drive is unmounted
                                  by the sound of it its unable to load the config.g so that could explain why nothing else works.
                                  could you also try doing ls -l /opt/dsf/sdand ls -l /opt/dsf/sd/sys in an ssh shell to see what permissions you have?
                                  edit: or did the power cycle solve it?
                                  • tobias_munichundefined
                                    tobias_munich @elliott.griffiths
                                    @elliott-griffiths it’s frustrating.
                                    After setting it up from scratch.
                                    Means... downloading the current image, and setup a new sd...
                                    still issues.
                                    Stand-alone with SD, no problem.
                                    But the SBC version.
                                    After starting with the new image the sbc connects to the duet. So far so good.
                                    DWC is able to acces the virtual SD with all folders.
                                    But after uploading the config.g to the sys folder and rebooting,
                                    the system has problems to access to the virtual SD with a lot of error messages .
                                    It’s not able to read and access any folder of the virtual SD
                                    It’s so frustrating
                                    Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
                                    Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
                                    Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
                                    • ChrisPundefined
                                      ChrisP @A Former User
                                      @bearer said in RepRapFirmware 3.01-RC6 released:
                                      drive is unmounted
                                      Thanks for picking this up, but that is not the porblem at this point. I've only seen that error once immediately after update and after power cycle, that hasn't happened again.
                                      Everything now seems to load and I can see all the files on the interface, however, it's still not booting properly. After a reinstall, I'm still getting a persistant "busy" state and no the tools show the bed, but not the extruder, temperature chart still sows both. Pressing emergency stop now seems to work, but then nothing is listed in the tools and it still sits being "Busy" - see image.
                                        A Former User @tobias_munich
                                        @tobias_munich said in RepRapFirmware 3.01-RC6 released:
                                        care to share the file and/or try a empty file?
                                          tobias_munich @A Former User
                                          @bearer I tried a lot of ways ....
                                          And after all the tests I made it seems it’s a problem with the virtual SD.
                                            no doubt about it, just curious if its the content or presence of the config.g file that makes a difference; as it seemed it did make a difference from your earlier post.
