    BLTouch doesnt
    822
    • synergy41undefined
      synergy41
      Good morning all,
      Since I installed the update "RepRapFirmware for Duet 2 WiFi / Ethernet 3.01-RC6 (2020-04-03b3)", I can no longer operate my Bltouch.
      however this one is well to feed it lights up in red, and no error on Z-Probe which is well at 0.
      My Bltouch work well before the update,
      I am attaching my current config file.
      " new file " config .g
      As well as my old config file which works fine.
      " Old file " config.g
      Thank you for your help.
      I LOVE MY DUET WIFI
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.1 (2022-06-01)
      Duet WiFi Server Version: 1.26
      Duet Web Control 3.4.1
      Cura 4.10
      DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 0
      • DIY-O-Sphereundefined
        DIY-O-Sphere @synergy41
        @synergy41
        Does the probe deploy and retract by sending M401 and M402?
          synergy41
          @DIY-O-Sphere said in BLTouch doesnt:
          No it shows me this:Capture d'écran 2020-04-04 23.39.01.png
          I LOVE MY DUET WIFI
          Cura 4.10
            This post is deleted!
            synergy41undefined 1 Reply Last reply Reply Quote 0
              synergy41 @DIY-O-Sphere
              @DIY-O-Sphere
              The H10 was the trigger height of the probe.
              You mean I have to replace P9 with P5?
              I LOVE MY DUET WIFI
              Cura 4.10
              DIY-O-Sphereundefined 3 Replies Last reply Reply Quote 0
                @synergy41
                The trigger height is set by G31
                  @DIY-O-Sphere
                  I just tried removing H10 and replacing P9 with P5, but nothing changes
                  I LOVE MY DUET WIFI
                  Cura 4.10
                  DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                    @synergy41
                    Also remove the "M280 P0 S10" from the config.g that would trigger the probe.
                    Maybe you have set it for testing....
                        DIY-O-Sphere @DIY-O-Sphere
                          @DIY-O-Sphere
                          You mean
                          M558 P5 C "^ zprobe.in + zprobe.mod" H5 F300 T3000
                          I LOVE MY DUET WIFI
                          Cura 4.10
                          DIY-O-Sphereundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                            @synergy41
                            Sorry I missed this that is not the trigger height, that is the dive height. That is not the issue...
                              @synergy41
                              M558 P9 C"^zprobe.in+zprobe.mod" H10 F300 T3000 is o.k.
                              We have to check other things.....
                                @synergy41
                                Can you comment "M307 H3 A-1 C-1 D-1" out
                                  What do you have in your deployprobe and retractprobe?
                                  synergy41undefined DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 0
                                    @DIY-O-Sphere
                                    he tells me this:
                                    I LOVE MY DUET WIFI
                                    Cura 4.10
                                      synergy41 @Phaedrux
                                      @Phaedrux
                                      deployprobe.g
                                      retractprobe.g
                                      I LOVE MY DUET WIFI
                                      Cura 4.10
                                        DIY-O-Sphere @Phaedrux
                                        @Phaedrux
                                        I think the heater channnel is disabled by the M307
                                          Was this generated by the configurator or did you create it?
                                          M950 P3 S90 I1
                                          It should be M280 not M950
                                            droftarts administrators @synergy41
                                            @synergy41
                                            Your Old config:
                                            M307 H3 A-1 C-1 D-1                                ; Disable heater on PWM channel for BLTouch
                                            M558 P9 H10 F300 T3000                             ; Set Z probe type to bltouch and the dive height + speeds
                                            G31 P500 X0 Y25 Z2.45                              ; Set Z probe trigger value, offset and trigger height 2.235 ; 2.40
                                            M557 R140 S25                                      ; Define mesh grid
                                            Your New config
                                            Z-Probe
                                            M558 P9 C"^zprobe.in+zprobe.mod" H10 F300 T3000    ; P9 ESSAI M558 Set Z probe type to bltouch and the dive height + speeds M558 P9 C"zprobe.in+zprobe.mod" H10 F300 T3000
                                            M950 S0 C"exp.heater3"                             ; ESSAI create servo pin 0 for BLTouch M950 S0 C"exp.heater3"
                                            M280 P0 S10                                        ; envoyer le signal de contrôle à BLTouch via servo / gpio 0
                                            See https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3
                                            M558 should be set with P9. You don't need '+zprobe.mod'. You don't need to disable PWM channel with M307.
                                            If probing is too fast, F60 (which is the speed of probing) is a good place to start. Turn of heaters during probing (reduce magnetic interference) with B1. Also a good idea to set probe recovery time of R1. You can also decrease the trigger value in G31 to improve sensitivity, eg P50
                                            So change to:
                                            M558 P9 C"^zprobe.in" H10 F300 T3000    ; P9 ESSAI M558 Set Z probe type to bltouch and the dive height + speeds
                                            G31 P50 X0 Y25 Z2.45                              ; Set Z probe trigger value, offset and trigger height 2.235 ; 2.40
                                            To extend and retract probe, see https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe?revisionid=HEAD#Section_Commissioning_Testing_RepRapFirmware_Num_3. You should use:
                                            M280 P0 S10 ; extend pin
                                            M280 P0 S90 ; retract pin
