    BLTouch doesnt
    825
    • DIY-O-Sphereundefined
      DIY-O-Sphere @synergy41
      @synergy41
      Also remove the "M280 P0 S10" from the config.g that would trigger the probe.
      Maybe you have set it for testing....
        This post is deleted!
        DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
          DIY-O-Sphere @DIY-O-Sphere
          synergy41undefined 1 Reply Last reply Reply Quote 0
          • synergy41undefined
            synergy41 @DIY-O-Sphere
            @DIY-O-Sphere
            You mean
            M558 P5 C "^ zprobe.in + zprobe.mod" H5 F300 T3000
            I LOVE MY DUET WIFI
            Board: Duet 2 WiFi (2WiFi)
            Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.1 (2022-06-01)
            Duet WiFi Server Version: 1.26
            Duet Web Control 3.4.1
            Cura 4.10
            DIY-O-Sphereundefined droftartsundefined 2 Replies Last reply Reply Quote 0
              @synergy41
              Sorry I missed this that is not the trigger height, that is the dive height. That is not the issue...
                @synergy41
                M558 P9 C"^zprobe.in+zprobe.mod" H10 F300 T3000 is o.k.
                We have to check other things.....
                  @synergy41
                  Can you comment "M307 H3 A-1 C-1 D-1" out
                    What do you have in your deployprobe and retractprobe?
                    synergy41undefined DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 0
                      @DIY-O-Sphere
                      he tells me this:
                      I LOVE MY DUET WIFI
                      Cura 4.10
                        synergy41 @Phaedrux
                        @Phaedrux
                        deployprobe.g
                        retractprobe.g
                        I LOVE MY DUET WIFI
                        Cura 4.10
                          DIY-O-Sphere @Phaedrux
                          @Phaedrux
                          I think the heater channnel is disabled by the M307
                            Was this generated by the configurator or did you create it?
                            M950 P3 S90 I1
                            It should be M280 not M950
                              droftarts administrators @synergy41
                              @synergy41
                              Your Old config:
                              M307 H3 A-1 C-1 D-1                                ; Disable heater on PWM channel for BLTouch
                              M558 P9 H10 F300 T3000                             ; Set Z probe type to bltouch and the dive height + speeds
                              G31 P500 X0 Y25 Z2.45                              ; Set Z probe trigger value, offset and trigger height 2.235 ; 2.40
                              M557 R140 S25                                      ; Define mesh grid
                              Your New config
                              Z-Probe
                              M558 P9 C"^zprobe.in+zprobe.mod" H10 F300 T3000    ; P9 ESSAI M558 Set Z probe type to bltouch and the dive height + speeds M558 P9 C"zprobe.in+zprobe.mod" H10 F300 T3000
                              M950 S0 C"exp.heater3"                             ; ESSAI create servo pin 0 for BLTouch M950 S0 C"exp.heater3"
                              M280 P0 S10                                        ; envoyer le signal de contrôle à BLTouch via servo / gpio 0
                              See https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3
                              M558 should be set with P9. You don't need '+zprobe.mod'. You don't need to disable PWM channel with M307.
                              If probing is too fast, F60 (which is the speed of probing) is a good place to start. Turn of heaters during probing (reduce magnetic interference) with B1. Also a good idea to set probe recovery time of R1. You can also decrease the trigger value in G31 to improve sensitivity, eg P50
                              So change to:
                              M558 P9 C"^zprobe.in" H10 F300 T3000    ; P9 ESSAI M558 Set Z probe type to bltouch and the dive height + speeds
                              G31 P50 X0 Y25 Z2.45                              ; Set Z probe trigger value, offset and trigger height 2.235 ; 2.40
                              To extend and retract probe, see https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe?revisionid=HEAD#Section_Commissioning_Testing_RepRapFirmware_Num_3. You should use:
                              M280 P0 S10 ; extend pin
                              M280 P0 S90 ; retract pin
                                @DIY-O-Sphere
                                I uncomment the command M307, and now
                                M401 and M402 work.
                                But I still can't get Bltouch "M280 P3 S120 I1" commands to work
                                I LOVE MY DUET WIFI
                                Cura 4.10
                                  @Phaedrux
                                  Also the deploy.g should be M280 P0 S10....
                                    @synergy41 said in BLTouch doesnt:
                                    Try "M280 P0 S120" instead
                                      synergy41
                                      thank you all
                                      I replaced with P0 in my Bltouch orders and it works.
                                      Thanks again to you 3
                                      I LOVE MY DUET WIFI
                                      Cura 4.10
                                        deployprobe.g
                                        retractprobe.g
                                        Are the old files.....
                                        deploy.g
                                        M280 P0 S10
                                        retract.g
                                        M280 P0 S90
                                        Please check also the homing files.....
                                          @DIY-O-Sphere
                                          thank you
                                          I LOVE MY DUET WIFI
                                          Cura 4.10
