    Inconsitent extrusion - Duet 2 Wifi - Custom CoreXY
    916
    • Ljbleamundefined
      Ljbleam @mrehorstdmd
      @mrehorstdmd I realized after I posted this that I set that value to allow the extruders acceleration to not be limited by jerk settings. Great catch though because that is definitely an absurd value.
      • Ljbleamundefined
        Ljbleam
        I was afraid I would have to rebuild the Z-axis but based on the comments I have received so far that seems like the first step to fixing the inconsistent wall problem.
        Turboundefined 1 Reply Last reply Reply Quote 0
        • Turboundefined
          Turbo @Ljbleam
          @Ljbleam all you should have to do to test for friction is take out the leadscrews and move it by hand
          Also whats your steps/mm for all axis'?
          Have you tried lowering the z microstepping to 16 with interpol?
          Cant stop tuning wont stop tuning.
          Dbot, Custom i3, Voron 0&2
          Ljbleamundefined 1 Reply Last reply Reply Quote 0
          • Ljbleamundefined
            Ljbleam @Turbo
            @Turbo When I first put the thing together I tested the Z axis and it was SUPER jumpy when traveling up and down. Lots of binding happening. I reassembled and it was better (less jumpy) but I had a problem where at a certain height it would bind (squishing the layers together) and then release quickly on the next step down. I put a dial indicator on the bed and stepped it down 0.1mm at a time and got an average error of around 4% per step ([measured step - expected step] / expected step). Curious if that 4% error is enough to create the effects shown in the white test cube. I suppose it must be.
            Microstepping – (X16 Y16 E16 I1) Z256. I have tried interpolation on Z axis as well.
            • Turboundefined
              Turbo @Ljbleam
              @Ljbleam Assuming you used a calculated value for the z axis steps/mm, then the error wouldn't have a great effect, since your cube is still 20.05 tall. If you adjusted it manually, you couldve overcompensated.
              Whats the steps/mm on each axis, not the microstepping config.
              • jens55undefined
                jens55
                Micro stepping produces very low power steps between full steps and any binding whatsoever will cause you nothing but grief!
                Ljbleamundefined 1 Reply Last reply Reply Quote 1
                • Ljbleamundefined
                  Ljbleam @Turbo
                  @Turbo
                  M92 X100.00 Y100.00 Z6400.00 E940.00
                  Thats with 256microstepping. So that is a calculated (non compensated) value.
                  6400/256 = 25 full steps per mm. 25steps * 1.8degrees = 45 degrees / 1mm step. 360 degrees / 45 degrees = 8 mm/revolution
                  • Ljbleamundefined
                    Ljbleam @jens55
                    @jens55 Great input. This is something I did not consider. Before rebuilding Z axis I will try lower microstepping to give the motors more power and hopefully overcome the binding.
                    • jens55undefined
                      jens55 @Ljbleam
                      @Ljbleam, that's the wrong approach! Fix the binding !
                      • Ljbleamundefined
                        Ljbleam @jens55
                        @jens55 said in Inconsitent extrusion - Duet 2 Wifi - Custom CoreXY:
                        I agree it is a bandaid fix. But that would certainly confirm the binding problem 🙂
                        Turboundefined jens55undefined 2 Replies Last reply Reply Quote 0
                        • Turboundefined
                          Turbo @Ljbleam
                          @Ljbleam I would go back to 16 microsteps with interpol on the z axis. Your steps/mm should be 800 with that.
                          • jens55undefined
                            jens55 @Ljbleam
                            @Ljbleam, not necessarily .... each micro step has a certain amount of drive to it. If the stepper is commanded to go 5 steps there is more power there than 1 step. If the problem is stiction then there is a good probability that you can overcome the issue with larger steps. With binding, what's to say that microstep 1 and 2 perform perfectly but that steps 3,4 and 5 are not stepping properly.
                            Let's say you half the microsteping .... Step 1 will work perfectly (previously step 1 and 2) and step 2 binds (previously step 3,4,5).
                            Yes, it might show the issue but then it might not .....
                            • taconiteundefined
                              taconite
                              Mhh interesting ... I have a similar issue.
                              Have you checkt die filament diameter?
                              How is your role of filament guided? Is it hard to turn it?
                              What about the temperature of your extruder (did the change in current do anything?)? is it getting very hot?
                              How is your bowden tube guided? is it twisted (and maybe therefore the filament causing inconsistent extrusion)?
                              How is your part cooling? Maybe you are cooling the heatblock and therefore the extruder having troubles extruding a constant amount of filament?
                              Have you tried playing with the acceleration of the Extruder?
                              The strang thing is, that I ran into this issue just recently. but it looks exactly the same ... in the most part I have constant extrusion but then a bit under and a bit overextrusion causing the walls not being consistant.
                              Custom ANET A8
                              Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
                              All I do here is under this license: CC BY-NC-SA
