    Ender 5 Pro Hemera Bltouch upgrade to Duet Wifi Firmware 3
    2.1k
    • Danielundefined
      Daniel
      @Phaedrux
      However in our machine specific configuration, the end stops continue to show like this when the head is in the middle of the bed....
      Is this right?
        Phaedrux Moderator @Daniel
        @Daniel said in Ender 5 Pro Hemera Bltouch upgrade to Duet Wifi Firmware 3:
        M574 X2 S2 P"xstop" ; configure active-high endstop for high end on X via pin xstop
        M574 Y2 S2 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
        Did you get a full new config set from the configurator? At this point it may be easier (for me anyway) if you stick with one config and we manually alter it. If you keep changing things in the configurator it makes it a lot harder to notice everything that's changed.
        For instance the config now has Y2 X2, which would be the high end of travel. That's fine, it would be the more traditional way of doing it.
        @Phaedrux
        Is this right?
        Can you post a photo of the endstops and how you have them wired?
        • Danielundefined
          Daniel
          @Phaedrux
          Sorry Phaedrux,
          I was trying to get this to show more like your logic, so the alignment on the Bltouch later comes easier to you.
          Let me take the pictures and return to you.
          • Danielundefined
            Daniel
            @Phaedrux
            Here are the pictures of the motherboard and the Y endswitch
            • Danielundefined
              Daniel
              @Phaedrux
              I have oriented the colors to match the letters for Signal Ground and Voltage in the printer run end sensor and in the motherboard. Double Checked.
              The original wire on the Ender 5 is a 2 wire cable. Just connected in both ends of the run end sensor = S and V
              The instructions on the Duet 2 page mention the 2 wires from the ender connector should be connected on the outer two of the three connectors on the motherboard (leave the center empty). That would mean that S and V from the ender should be connected to S and G in the motherboard.
              That did not seem right to me, so I preferred to keep the convention matched on both circuits and made my own cable.
              Phaedrux, Whatever they pay you to do this job (if any) is too little.... please let me know how can I compensate all this help and assistance. Best regards. Daniel
              jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
                Ok, those 3 wire endstops might need to be wired a little differently, I'm not sure because I'm having a hard time orienting your photo against the wiring diagram.
                But hopefully based on this info and the wiring diagram you can verify it.
                https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Makerbot_Mechanical_Endstop_v1_Num_2
                https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Microswitch
                https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
                  Nope, sorry, disregard that. You only need the 2 wires for that endstop connected to the outer two pins on the endstop port. Doesn't matter which way.
                  https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37#s119
                  • bricorundefined
                    bricor
                    I found this in the endstop documentation not sure if it applies.
                    If using RepRapFirmware 3, invert the polarity by putting a ! character in front of the pin name.
                    • jumpedwithbothfeetundefined
                      jumpedwithbothfeet @Daniel
                      @Daniel don’t wish to muddy the water as I don’t have a great deal of knowledge, however I also have an ender 5 but running a duet 3, both my end-stops configured using 2 wires only as the they are only normally closed micro switches, I’d hazard a guess your issue is the center wire that’s been added for 3.3v it maybe holding the switch closed, I’ve added my config hopefully it will help 🙂
                      config.g
                      Regards Jim
                      6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
                      • Danielundefined
                        Daniel
                        @Phaedrux, @bricor, @jumpedwithbothfeet ... Gentlemen. What a feast of knowledge in this trail. Wow...Thank you all. Sometimes the forest does not let you see the tree....
                        Each one of you hold a piece of the puzzle...
                        @Phaedrux, thanks for Ockham’s razor application: The simplest solution is the right one. I re-wired using the 2 wire cable connected to the ends of the motherboard endstop connector.
                        @Bricor, inverting the polarity of the connection by software was brilliant. The RRF equivalent selection was x-stop inverse.
                        @jumpedwithbothfeet, Ender 5 end stops are normally closed!!!. You see the little metal lever open...but when you test it....the circuit is closed... Thanks for the config file. I don’t know how did you assign I04 and I05 to the end stops, so I am still far away form your level of illumination
                        Now, after all this, standing in front of the printer 0,0 is on the nearest left corner. The end stops are on the far right corner.
                        From the center of the bed:
                        Negative values of x move the head left
                        Negative values of Y move the head towards me
                        Positive values of Z move the bed downwards
                        I still have questions on the z-stop and BLTouch proper nomenclature.
                        Basics of Gcoding with the differences between S1 or S2.... But the printer works....so I will try to give you a free Sunday.
                        Thank you guys!
                          Glad it's working out now. Come back with any questions any time.
                          Danielundefined 1 Reply Last reply Reply Quote 0
                          • Danielundefined
                            Daniel @Phaedrux
                            Would you welcome a summary page doccument for ender 5 users?
                              Absolutely.
                                @Daniel the pins were assigned during the config build but I obviously had to re-pin the end stop plugs, you can also manually change the config file in DWC however I’m using the duet 3 board I’m not sure if you can configure/assign pins on the duet 2, I’m sure @Phaedrux would be able to confirm that.
                                Glad to hear you want to create a guide for the ender 5 if I can help let me know 🙂
                                Regards Jim
                                  Phaedrux Moderator @jumpedwithbothfeet
                                  @jumpedwithbothfeet said in Ender 5 Pro Hemera Bltouch upgrade to Duet Wifi Firmware 3:
                                  In RepRapFirmware 3 pins can be re-defined in software. That applies to Duet 3 and Duet 2 boards.
                                  • Danielundefined
                                    Daniel @Phaedrux
                                    @Phaedrux
                                    I have not posted in a while and I wanted to thank for all the help received, by posting the latest config for the machine.
                                    Best configuration (so far) working with Simplify 3D. Please uncheck the boxes as per this picture to let the firmware control the printing.
                                    The config is below
                                    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Apr 19 2020 17:01:43 GMT-0400 (Eastern Daylight Time)
                                    M550 P"Daniel Ender 5 Duet 2 Wifi" ; set printer name
                                    M552 S1 ; enable network
                                    M586 P0 S1 ; enable HTTP
                                    M586 P1 S0 ; disable FTP
                                    M586 P2 S0 ; disable Telnet
                                    M569 P0 S0 ; physical drive 0 goes backwards
                                    M569 P2 S0 ; physical drive 2 goes backwards
                                    M92 X80.00 Y80.00 Z811.00 E409.00 ; set steps per mm
                                    M566 X900.00 Y900.00 Z60.00 E4000.00 ; set maximum instantaneous speed changes (mm/min)
                                    M201 X6000.00 Y6000.00 Z60.00 E4000.00 ; set accelerations (mm/s^2)
                                    M203 X15000.00 Y15000.00 Z600.00 E8000.00 ; set maximum speeds (mm/min)
                                    M204 P800 T2000 ; set accel for XY print (P) and travel moves (T).
                                    M207 S0.85 R-0.000 F3200 T2600 Z0.0 ; set firmware retraction
                                    M572 D0 S0.050 ; set pressure advance
                                    M906 X850 Y850 Z850 E850 I30 ; set motor currents (mA) and motor idle factor in per cent
                                    M84 S30 ; set idle timeout
                                    M208 X220 Y220 Z300 S0 ; set axis maxima
                                    M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
                                    M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
                                    M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                                    M558 P9 C"zprobe.in" H5 F120 T12000 ; set Z probe type to bltouch and the dive height + speeds
                                    G31 P500 X-45 Y3 Z1.95 ; set Z probe trigger value, offset and trigger height
                                    M557 X15:160 Y15:200 S20 ; define mesh grid
                                    M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin bedtemp
                                    M307 H0 A88.4 C265.5 D2.0 S1.00 V23.9 B0 ; disable bang-bang mode for the bed heater and set PWM limit (Values copied from auto tune D corrected from 0.9 to 2 by Phaedrux)
                                    M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp
                                    M143 H1 S300 ; set temperature limit for heater 1 to 300C
                                    M307 H1 A390.6 C153.8 D3.5 S1.00 V23.9 B0 ; disable bang-bang mode for heater and set PWM limit (Values copied from auto tune)
                                    M563 P0 S"E3D V6 Nozzle X" D0 H1 F0 ; define tool 0
                                    Enjoy printing!!!
