    Ender 5 Pro Hemera Bltouch upgrade to Duet Wifi Firmware 3
    2.1k
    • Danielundefined
      Daniel
      @Phaedrux
      You also said my logic was inverted 180 degrees. How should I look at all this (I am left handed and brain washed) 😉
      • Danielundefined
        Daniel
        @Phaedrux
        I believe we should choose in this last screen, Active low, High end to reverse the screen and finally change the direction of the motors by selecting reverse direction in X and Y.
        What say you? I am going to give it a try....
        Then - X would be with the motor moving to the left and -Y would be with the motor moving towards the front....and it will match the deviation of the bltouch probe in -x (45 and 3) +y
          Sorry for the delay.
          For the endstops we can change them in config.g
          Change the S1 to S2 for both. Then test the endstops again.
            Doing high end for both would give you the 180 degree rotation we discussed earlier.
            This is normally how the coordinate system would appear when looking at your printer from the front. The homing location is irrelevant. Instead of homing to 0 it would home to 280 or whatever.
            Danielundefined 1 Reply Last reply Reply Quote 0
            • Danielundefined
              Daniel @Phaedrux
              @Phaedrux
              Ok, I tried changing the configuration without success on the RRF to try to get those S2 values to show. I finally changed it on the config and we are like this
              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Apr 18 2020 22:46:43 GMT-0400 (Eastern Daylight Time)
              M550 P"Daniel Ender 5" ; set printer name
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M569 P0 S0 ; physical drive 0 goes backwards
              M569 P2 S0 ; physical drive 2 goes backwards
              M92 X80.00 Y80.00 Z779.00 E409.00 ; set steps per mm
              M566 X900.00 Y900.00 Z12.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X18000.00 Y18000.00 Z900.00 E1200.00 ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z50.00 E5000.00 ; set accelerations (mm/s^2)
              M84 S30 ; Set idle timeout
              M208 X220 Y220 Z300 S0 ; set axis maxima
              M574 X2 S2 P"xstop" ; configure active-high endstop for high end on X via pin xstop
              M574 Y2 S2 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
              M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
              M558 P9 C"zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X-45 Y3 Z2.5 ; set Z probe trigger value, offset and trigger height
              M557 X15:160 Y15:200 S20 ; define mesh grid
              M143 H1 S300 ; set temperature limit for heater 1 to 300C
              M563 P0 S"E3D V6 Nozzle X" D0 H1 F0 ; define tool 0
              • Danielundefined
                Daniel
                @Phaedrux
                However in our machine specific configuration, the end stops continue to show like this when the head is in the middle of the bed....
                Is this right?
                  Phaedrux Moderator @Daniel
                  @Daniel said in Ender 5 Pro Hemera Bltouch upgrade to Duet Wifi Firmware 3:
                  Did you get a full new config set from the configurator? At this point it may be easier (for me anyway) if you stick with one config and we manually alter it. If you keep changing things in the configurator it makes it a lot harder to notice everything that's changed.
                  For instance the config now has Y2 X2, which would be the high end of travel. That's fine, it would be the more traditional way of doing it.
                  @Phaedrux
                  Is this right?
                  Can you post a photo of the endstops and how you have them wired?
                  • Danielundefined
                    Daniel
                    @Phaedrux
                    Sorry Phaedrux,
                    I was trying to get this to show more like your logic, so the alignment on the Bltouch later comes easier to you.
                    Let me take the pictures and return to you.
                    • Danielundefined
                      Daniel
                      @Phaedrux
                      Here are the pictures of the motherboard and the Y endswitch
                      • Danielundefined
                        Daniel
                        @Phaedrux
                        I have oriented the colors to match the letters for Signal Ground and Voltage in the printer run end sensor and in the motherboard. Double Checked.
                        The original wire on the Ender 5 is a 2 wire cable. Just connected in both ends of the run end sensor = S and V
                        The instructions on the Duet 2 page mention the 2 wires from the ender connector should be connected on the outer two of the three connectors on the motherboard (leave the center empty). That would mean that S and V from the ender should be connected to S and G in the motherboard.
                        That did not seem right to me, so I preferred to keep the convention matched on both circuits and made my own cable.
                        Phaedrux, Whatever they pay you to do this job (if any) is too little.... please let me know how can I compensate all this help and assistance. Best regards. Daniel
                        jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
                          Ok, those 3 wire endstops might need to be wired a little differently, I'm not sure because I'm having a hard time orienting your photo against the wiring diagram.
                          But hopefully based on this info and the wiring diagram you can verify it.
                          https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Makerbot_Mechanical_Endstop_v1_Num_2
                          https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Microswitch
                          https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
                            Nope, sorry, disregard that. You only need the 2 wires for that endstop connected to the outer two pins on the endstop port. Doesn't matter which way.
                            https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37#s119
                            • bricorundefined
                              bricor
                              I found this in the endstop documentation not sure if it applies.
                              If using RepRapFirmware 3, invert the polarity by putting a ! character in front of the pin name.
                              • jumpedwithbothfeetundefined
                                jumpedwithbothfeet @Daniel
                                @Daniel don’t wish to muddy the water as I don’t have a great deal of knowledge, however I also have an ender 5 but running a duet 3, both my end-stops configured using 2 wires only as the they are only normally closed micro switches, I’d hazard a guess your issue is the center wire that’s been added for 3.3v it maybe holding the switch closed, I’ve added my config hopefully it will help 🙂
                                config.g
                                Regards Jim
                                6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
                                • Danielundefined
                                  Daniel
                                  @Phaedrux, @bricor, @jumpedwithbothfeet ... Gentlemen. What a feast of knowledge in this trail. Wow...Thank you all. Sometimes the forest does not let you see the tree....
                                  Each one of you hold a piece of the puzzle...
                                  @Phaedrux, thanks for Ockham’s razor application: The simplest solution is the right one. I re-wired using the 2 wire cable connected to the ends of the motherboard endstop connector.
                                  @Bricor, inverting the polarity of the connection by software was brilliant. The RRF equivalent selection was x-stop inverse.
                                  @jumpedwithbothfeet, Ender 5 end stops are normally closed!!!. You see the little metal lever open...but when you test it....the circuit is closed... Thanks for the config file. I don’t know how did you assign I04 and I05 to the end stops, so I am still far away form your level of illumination
                                  Now, after all this, standing in front of the printer 0,0 is on the nearest left corner. The end stops are on the far right corner.
                                  From the center of the bed:
                                  Negative values of x move the head left
                                  Negative values of Y move the head towards me
                                  Positive values of Z move the bed downwards
                                  I still have questions on the z-stop and BLTouch proper nomenclature.
                                  Basics of Gcoding with the differences between S1 or S2.... But the printer works....so I will try to give you a free Sunday.
                                  Thank you guys!
                                    Glad it's working out now. Come back with any questions any time.
                                    • Danielundefined
                                      Daniel @Phaedrux
                                      Would you welcome a summary page doccument for ender 5 users?
                                        Absolutely.
                                          @Daniel the pins were assigned during the config build but I obviously had to re-pin the end stop plugs, you can also manually change the config file in DWC however I’m using the duet 3 board I’m not sure if you can configure/assign pins on the duet 2, I’m sure @Phaedrux would be able to confirm that.
                                          Glad to hear you want to create a guide for the ender 5 if I can help let me know 🙂
                                          Regards Jim
                                            Phaedrux Moderator @jumpedwithbothfeet
                                            @jumpedwithbothfeet said in Ender 5 Pro Hemera Bltouch upgrade to Duet Wifi Firmware 3:
                                            In RepRapFirmware 3 pins can be re-defined in software. That applies to Duet 3 and Duet 2 boards.
