    rincoglionito io?
    Firmware installation
    996
    • Leblondundefined
      Leblond
      ho provato tutte le procedure del caso per aggiornare il FW ma non riesco ad aggiornarlo sia tramite yat e Stavolta non ho collegato la stampante alla rete elettrica, e ne tramite web control riesce ad aggiornare qui di seguito il log:
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-917NK-F23T0-6JTD0-3S06T-TYAJF
      Used output buffers: 4 of 24 (8 max)
      Static ram: 25680
      Dynamic ram: 93604 of which 456 recycled
      Exception stack ram used: 252
      Never used ram: 11080
      Tasks: NETWORK(ready,788) HEAT(blocked,1236) MAIN(running,3844) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:06:17 ago, cause: software
      Last software reset details not available
      Error status: 0
      Free file entries: 10
      MCU temperature: min 32.8, current 33.8, max 34.0
      Supply voltage: min 0.4, current 0.5, max 0.5, under voltage events: 0, over voltage events: 0, power good: no
      Driver 0: ok, SG min/max not available
      Driver 1: ok, SG min/max not available
      Driver 2: ok, SG min/max not available
      Driver 3: ok, SG min/max not available
      Driver 4: ok, SG min/max not available
      Date/time: 2020-04-22 13:41:49
      Cache data hit count 1384284541
      Slowest loop: 2.08ms; fastest: 0.06ms
      Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === DDARing ===
      Bed heaters = 1 -1 -1 -1, chamberHeaters = -1 -1
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 16.28ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.23
        WiFi MAC address 84:0d:8e:b3:b4:8a
        WiFi Vcc 3.40, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 22872
        WiFi IP address 192.168.178.22
        WiFi signal strength -52dBm, reconnections 0, sleep mode modem
      • Leblondundefined
        Leblond
        yat mi dice:
        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
        • Leblondundefined
          Leblond
          neache aggiornarlo alla 2.05 funziona, mi mantiene sempre quello
          • Leblondundefined
            Leblond
            forse mi sono rincoglionito io?
            • Leblondundefined
              Leblond
              ho seguito la procedura di fallback n. 1 da qui: https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
              • brismaundefined
                brisma
                Ricorda che è un forum inglese.
                A che versione vuoi aggiornare? Se sei su una 2.0x devi prima aggiorare a 3.0, poi aggiornare a 3.0.1.
                Leblondundefined 1 Reply Last reply Reply Quote 0
                • Leblondundefined
                  Leblond @brisma
                  @brisma si lo so che e' un forum inglese ma che ci posso fare se l'inglese non lo so? come te uso il traduttore di google, comunque dalla 2.03 voglio il fw 3.0
                  brismaundefined 1 Reply Last reply Reply Quote 0
                  • brismaundefined
                    brisma @Leblond
                    @Leblond Mah guarda, sono italiano anch'io... eppure leggo e scrivo in inglese, basta avere la voglia ed il tempo di impararlo 🙂
                    In ogni caso, aggiorna prima a 3.0 usando questa guida:
                    https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Summary_of_what_you_need_to_do_to_convert_your_configuration_and_other_files
                    • Leblondundefined
                      Leblond @brisma
                      @brisma ok quindi devo installare la versione 3 del fw forse mi era sfuggito questo passaggio, GRAZIE!! , e per quanto riguarda l'inglese e capiscimi bene che non voglio fare polemica, dici bene tu ma a 50 anni non ho proprio voglia di studiare inglese esistono i traduttori apposta e sinceramente mai a nessuno ho detto di studiarsi l'italiano solo perche' non si sa' l'italiano... uso il traduttore e se c'e' qualcosa che non capisco traduco in inglese e gli rimando il tutto, semplice no?.😀
                      • brismaundefined
                        brisma @Leblond
                        @Leblond Certo, ma ripeto: sei su un forum inglese dove si parla inglese. Se non lo conosci e non hai voglia di impararlo almeno sforzati di usare il traduttore anziché scrivere in italiano.
                        Sorry for the OT.
                        • Leblondundefined
                          Leblond @brisma
                          @brisma tell me it's my fault if the forum in Italian does not exist, but please ... anyway, would you like it more like this?
                          • Leblondundefined
                            Leblond
                            however the only one to complain is you, I have never complained about anything or anyone and I have always adapted to the situation
                            • Leblondundefined
                              Leblond
                              thanks @brisma it worked and I don't want to ...
                                @Leblond @brisma
                                The forum is predominantly english but that's not a requirement. We try to help anyone who asks for help. You may get more assistance if you post in english because more people can read it. Google Translation is built into Google Chrome, so it's not as bit of a barrier as it used to be.
                                Leblondundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                • Leblondundefined
                                  Leblond @Phaedrux
                                  @Phaedrux 👍 👍
                                    droftarts administrators @Phaedrux
                                    @Phaedrux said in rincoglionito io?:
                                    Nice. But I use Firefox! Can't find an extension that does the whole page, so I end up going to google translate. Which is why it takes me a bit longer to reply to @Leblond !
                                    • Leblondundefined
                                      Leblond @droftarts
                                      @droftarts I use chrome to read, and to write I go directly to google translator, I have to do this because I realized that if I write directly in Italian when it is then translated into English you have problems, so that's fine, I don't have I never asked for anything from anyone and I understand if it takes time to answer, it does nothing, the important thing is to answer👍 👍 😊
                                      • Danalundefined
                                        Danal
                                        @brisma said in rincoglionito io?:
                                        I'd actually prefer people post in their native language, so that I can use multiple translation tools. Including just reading the original. Latin root languages aren't that hard...
                                        Leblondundefined 2 Replies Last reply Reply Quote 0
                                        • Leblondundefined
                                          Leblond @Danal
                                          @Danal but can you know what the problem is? am I writing in english still not okay?
                                          • Leblondundefined
                                            Leblond @Danal
                                            @Danal and thank goodness that all languages are accepted, let's end it here please
