    Wifi camera
    14
    7.8k
    • StephenRCundefined
      StephenRC
      I found a simple way of getting a web cam for using in the DWC: Raspberry Pi, any model that can run OctoPrint. It's already setup up to be able to use a web cam or raspi cam, once it's enabled. Using the current version, OctoPrint's setting page gives you what's needed. Get the snapshot url and copy it to DWC with it edited to use octopi.local or the pi's ip address instead of the local home address.
      • CRPerryJrundefined
        CRPerryJr
        I use this cheap network camera ($20.00)
        https://www.amazon.com/ELP-Megapixel-Camera-Hidden-Network/dp/B00KA4M4WS/ref=sr_1_23?s=electronics&ie=UTF8&qid=1486167105&sr=1-23&keywords=ip+camera
        And created the info in this post to make it work great in Duet Web Control.
        https://duet3d.com/forum/thread.php?id=815#p7924
        • elmoretundefined
          elmoret
          IP Webcam on an old Android device works. Picked up a phone with a cracked screen for $5.
          • briangilbertundefined
            briangilbert
            @CRPerryJr:
            Grrr, doesn't ship to Australia 😞
            Co-creator of the Zesty Nimble direct drive extruder
            • Nuffeundefined
              Nuffe
              I am using Playstation Eye (ps3 camera) with OctoPi. I had an extra one, but new ones are very cheap currently.
              • iDeveloundefined
                iDevelo
                Also if you use http://www.ispyconnect.com you can use the streams from that:
                http://192.168.1.13:8080/mjpegfeed?oid={CAMERAID}&full
                • jmg123undefined
                  jmg123
                  @kingfisher:
                  I couldn't get motion to work on my Pi - I ended up using RPi-Cam (http://elinux.org/RPi-Cam-Web-Interface)
                  I've not integrated it with Duet Web Control (Yet?!)
                  I have integrated it, just follow the installation instructions as normal, I changed the default port from 80 to 4123, as 80 was already in use on my pi. The url to add to DWC is then as follows
                  http://<ipaddress>:<port>/html/cam_pic_new.php?
                  e.g.
                  http://192.168.1.12:4123/html/cam_pic_new.php?</port></ipaddress>
                  • CaptAwesomeundefined
                    CaptAwesome
                    Did I see it right, that ur connecting the Webcam with ur WiFi seperat? There are no way to connect the Webcam direct with the duet wifi?
                    • kingfisherundefined
                      kingfisher
                      @jmg123:
                      @kingfisher:
                      e.g.
                      Thanks, just integrated 😉
                        @CaptAwesome:
                        That's right, you can't connect a camera directly to the Duet WiFi.
