    Print stuttering around curves, LaErrors
    58
    4.4k
    • NitroFreakundefined
      NitroFreak
      I just sliced the same 100mm circle with cura 4.5 and it works well without stuttering up to 135mm/s, after that the same thing happens.
      BUT i used to be able to do it at 250mm/sec.
      How is it possible that the code grips the throat of the duet so hard? Especially with the increased maximum resolition and deviation?
      Can an external 360 steps/mm stepper really strain the duet so hard?
      This is the latest M122 with Cura 4.5 and a print speed of between 60 and 180mm/s for the 100mm circle.
      How can i reduce the 971000 hiccups?
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-917NK-F23T0-6J9DJ-3S86S-TWBWD
      Used output buffers: 1 of 24 (8 max)
      Static ram: 25680
      Dynamic ram: 94004 of which 0 recycled
      Exception stack ram used: 444
      Never used ram: 10944
      Tasks: NETWORK(ready,652) HEAT(blocked,1172) MAIN(running,3748) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:26:33 ago, cause: power up
      Last software reset at 2020-04-27 10:32, reason: User, spinning module GCodes, available RAM 11076 bytes (slot 3)
      Error status: 16
      Free file entries: 10
      SD card longest block write time: 393.1ms, max retries 0
      MCU temperature: min 26.7, current 40.0, max 42.4
      Supply voltage: min 24.3, current 24.6, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: standstill, SG min/max 0/464
      Driver 1: standstill, SG min/max 0/1023
      Driver 2: standstill, SG min/max 0/243
      Driver 3: standstill, SG min/max 0/1023
      Date/time: 2020-04-28 16:22:48
      Slowest loop: 161.60ms; fastest: 0.07ms
      Hiccups: 971463, FreeDm: 169, MinFreeDm: 106, MaxWait: 397961ms
      === DDARing ===
      Heater 0 is on, I-accum = 0.3
      Heater 1 is on, I-accum = 0.4
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 394.79ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.23
        WiFi MAC address b4:e6:2d:52:f6:45
        WiFi Vcc 3.35, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 23328
        WiFi IP address 192.168.0.93
        WiFi signal strength -63dBm, reconnections 0, sleep mode modem
      botundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • botundefined
        bot @NitroFreak
        @NitroFreak this is likely because about a year and a few months ago, a change was made to RRF to eliminate the fallback to double/quad stepping when the step pulse generator gets overwhelmed. IE, hiccups are more common now because the system is always running at the set microstepping mode.
        Have you configured any axes to be higher than 16x microstepping?
        Edit: I see now from your first post that you seem to have 16x enabled on all axes, which should be fine. But, these high speeds are inducing the hiccups. See if you can get away with running 8x microstepping on your x/y axes. (by get away with, I mean if the noise bothers you too much or not)
        *not actually a robot
          dc42 administrators @NitroFreak
          @NitroFreak said in Print stuttering around curves, LaErrors:
          @dc42 said in Print stuttering around curves, LaErrors:
          • SD card issues. Make sure the SD card is formatted with a high cluster size, preferably 64kb. Also confirm that you are using the built-in SD card of the Duet, because external SD cards use a slower interface.
          Do you mean the SD card that is in the slot directly on the duet?
          I usually use the upload function over DWC, does that put it at the correct location?
          Yes it does, unless you change to SD card 1 in Duet Web Control.
            Something isn't right, because if you are using x16 microstepping on all drivers, you should be getting no hiccups, or at most just a few. Please send M350 after printing the 100mm circle and check that it still reports x16 microstepping.
            NitroFreakundefined 1 Reply Last reply Reply Quote 0
            • Charlieundefined
              Charlie
              As an update, I was able to eliminate the stuttering (the banding is likely an issue for another day, lol) by re slicing in Cura 4.5 (Cura 4.6 was where I was having the issues).
              Settings are:
              No wall overlap compensation
              Max resolution: 2.333 mm
              Max travel resolution: 0.8 mm
              Max deviation: 0.05 mm
              x16 Microstepping with interpolation
              Still had Look Ahead Errors (forgot to copy the M122) but MaxWait was 0 ms.
              • botundefined
                bot
                Interesting. Can you inspect the gcode manually and see a vast difference? Are the segment lengths much different?
                  NitroFreak @dc42
                  Yes it is,
                  M350
                  Microstepping - X:16(on), Y:16, Z:16, E:16(on):16(on)
                  But, it reports Y as x16 microstepping while it shouldn´t, i have configured Y as x1 microstepping due to the external drive. But the scale at which Y drives is still correct. so I don´t know?
                  • botundefined
                    bot @NitroFreak
                    @NitroFreak Ah, I was looking at Charlie's config.g not yours.
                    The way you write your M350 statement is a bit odd. you comment out the I0 in the first statement. Try refining it into two clear statements like this:
                    M350 Y1 Z16 ;E16:16I0 ; Configure microstepping without interpolation
                    M350 X16:16 I1 E16:16 I1 ; Configure microstepping with interpolation
                    M350 Y1 Z16 I0
                    M350 X16 E16 I1
                      Phaedrux Moderator @Charlie
                      @Charlie said in Print stuttering around curves, LaErrors:
                      That sounds plausible and would match with the update notes in my custom version being a fix for the issue.
                      I think @NitroFreak is having a separate issue though. Or at least an additional issue.
                      • Charlieundefined
                        Charlie
                        @bot I was thinking of using a diff checker (any recommended tools would be greatly appreciated) to see what the difference between the two versions may be. I'll update on my findings.
                          Notepad++ on windows, Atom on Mac probably
                          • botundefined
                            bot
                            I use Visual Studio Code because it comes with a nicer out-of-the-box config than notepad++ (my former choice). Nice comparison functionality, and an all around great little mini-IDE style text editor.
                            • Charlieundefined
                              Charlie
                              Thank you both for your replies! I tried a normal diff checker, but there was far too much different for me to compare. Using "gcodeanalyser.com" (amazing tool, way better than the "gcode.ws" that I used originally which didn't depict accelerations) I think I found my issue.
                              First image is using Cura 4.5 (no issues).
                              Second image is using Cura 4.6 (stuttering issues).
                              Same exact settings, same layer, but notice how Cura 4.6 speeds up and slows down many more times during the layer. I would assume that it would accelerate once for the layer start, and again for the small radius corner (as in 4.5) but 4.6 changes a lot more.
                              It's worth noting that the version of Cura that @Phaedrux kindly provided does not appear to have the issues that "stock" Cura 4.6 seems to have.
                              Please let me know if I'm mistaken with any of my assumptions.
                              Phaedruxundefined 1 Reply Last reply Reply Quote 2
                                gcodeanalyser.com
                                Have not seen that one before. I'll have to compare the gcodes and see if I get the same.
                                  Unfortunately my 30mb gcode file is choking the analyser and it eventually crashes the page. I'll see if I can find a smaller one that was sliced with that version.
                                  • CCS86undefined
                                    CCS86 @brisma
                                    @brisma said in Print stuttering around curves, LaErrors:
                                    Why 1428 (that's useless) and not 1400 on extruder?
                                    What's useless about 1428 instead of 1400? That's a 2% difference. Seems more than worthwhile to correctly define.
                                    botundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                    • CCS86undefined
                                      CCS86
                                      Did you guys report this over on the Cura Github?
                                      • botundefined
                                        bot @CCS86
                                        @CCS86 On Duet2 Wifi/Ethernet, the current can only be set in increments of 100 mA, and will be rounded down always.
                                        IE 1428 == 1400, and 1478 == 1400
                                        On Maestro, the current can be set in increments of 50 mA, rounded down in the same fashion. I'm not sure of the Duet3.
                                        CCS86undefined 1 Reply Last reply Reply Quote 1
                                          Phaedrux Moderator @CCS86
                                          @CCS86 said in Print stuttering around curves, LaErrors:
                                          He means (however bluntly) is that you only have a 100ma resolution with the Duetwifi and 50ma on the Maestro
                                          https://duet3d.dozuki.com/Wiki/Gcode#Section_M906_Set_motor_currents
                                            No, but I think it's known because the custom build from a few days ago lists "upstream changes" and a fix for geometry simplification, which sounds applicable. I quickly poked around the github of the smartavionics build but not yet the main cura github.
