Release 3.01-RC10
2.6k
    Leblond
    guys good evening, I updated to Release 3.01-RC10, but the extruder doesn't work even in manual, do you know anything about it?
      insertnamehere
      I had a similar problem when I first upgraded to firmware 3.
      Can you tell me what firmware version you upgraded from?
      Also posting your config.g may help.
        Did you also update DWC?
        undefined 1 Reply Last reply 29 Apr 2020, 09:08 Reply Quote 0
          Leblond @Phaedrux
          @Phaedrux
          good morning World
          yes I also updated DWC, if I go to extrude with the command on DWC it does it the first time and then that's enough, and it doesn't tell me if there are problems or not, however I send you the configuration and the log.
          29/4/2020, 11:04:05 M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC10 running on Duet WiFi 1.02 or later
          Board ID: 08DGM-917NK-F23T0-6JTD0-3S06T-TYAJFUsed output buffers: 3 of 24 (10 max)
          Static ram: 28044
          Dynamic ram: 93632 of which 44 recycled
          Exception stack ram used: 256
          Never used ram: 9096
          Tasks: NETWORK(ready,208) HEAT(blocked,1228) MAIN(running,1544) IDLE(ready,80)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:00:58 ago, cause: power up
          Last software reset at 2020-04-29 00:45, reason: User, spinning module GCodes, available RAM 8128 bytes (slot 1)
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
          Error status: 0
          Free file entries: 10
          MCU temperature: min 27.8, current 32.1, max 32.2
          Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
          Date/time: 2020-04-29 11:04:04
          Cache data hit count 104735100
          Slowest loop: 7.35ms; fastest: 0.13ms
          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
          === MainDDARing ===
          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
          === AuxDDARing ===
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 15.91ms; fastest: 0.00ms
          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.23
            WiFi MAC address 84:0d:8e:b3:b4:8a
            WiFi Vcc 3.40, reset reason Unknown
            WiFi flash size 4194304, free heap 25832
            WiFi IP address 192.168.178.22
            WiFi signal strength -62dBm, reconnections 0, sleep mode modem
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 23 2020 22:39:29 GMT+0200 (Ora legale dell’Europa centrale)
          M550 P"Lanzet 3d" ; set printer name
          M669 K1 ; select CoreXY mode
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P1 S0 ; physical drive 1 goes forwards
          M569 P3 S0 ; physical drive 3 goes forwards
          M92 X80.0 Y80.0 Z400.00 E424.00 ; set steps per mm
          M566 X500.00 Y500.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X10000.00 Y10000.00 Z400.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X900.00 Y900.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
          M84 S240 ; Set idle timeout
          M208 X330 Y330 Z385 S0 ; set axis maxima
          M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
          M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
          M558 P1 C"zprobe.in" H5 F300 T10000 ; set Z probe type to unmodulated and the dive height + speeds
          G31 P500 X-30 Y0 Z2.14 ; set Z probe trigger value, offset and trigger height
          M557 X55:310 Y50:300 S60 ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
          M143 H0 S90 ; set temperature limit for heater 0 to 90C
          M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
          M143 H1 S260 ; set temperature limit for heater 1 to 260C
          M106 P1 S0.5 H1 T45 ; set fan 1 value. Thermostatic control is turned on
          M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
          M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
          M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
          T0
          undefined 1 Reply Last reply 29 Apr 2020, 09:12 Reply Quote 0
            Leblond @Leblond
            @Leblond I tried to bring it back to version 3.0 but with the same results, it also gives me z offset problems, even following the procedure available with the macros, the height of the z offset is incorrect, in practice it is too low and the I find the G30 command only in the configuration and not elsewhere
              @Leblond, I've used extrusion from DWC many timis with RRF 3.01-RC10 and DWC 2.1.5. So I think there must be something in the sequence of what you are doing that is different. Please can you do the following:
              • Install 3.01-RC10 and DWC 2.1.5
              • In DWC Settings, check that you really are running those versions.
              • Try to reproduce the problem, taking note of the sequence of commands you used to get to the problem
              When the problem occurs:
              • Check that you have a tool selected
              • Check that the temperature of that tool is at least 160C or that you have cold extrusion enabled
              Report the sequence you used to get to the problem here.
              undefined 2 Replies Last reply 29 Apr 2020, 10:54 Reply Quote 0
                Leblond @dc42
                hello dc42 Thank you for your intervention
                the update sequence was:
                1. Update of FW 3.01-RC10
                2. DWC update directly from the .zip file
                The nozzle is selected and active: ok
                FW 3.01-RC10 loaded: ok
                DWC 2.1.5 loaded: ok
                The temperature is 220: ok
                I created a macro for ease of use to clean the nozzle:
                G1 X0 Y0
                M104 S220 T0
                M109 S220 T0
                G1 E30 F200
                I bring the temperature to 220, the macro is active, the head moves to the chosen coordinates, but it does not extrude and it is still, I manually try to extrude, but nothing happens and it does not give me any errors whatsoever
                I am attaching photos for viewing:
                  Leblond @dc42
                  droftartsundefined 1 Reply Last reply 29 Apr 2020, 11:17 Reply Quote 0
                    Thanks. So the manual extrusion buttons in DWC are not greyed out, but pressing them does nothing. Is that correct?
                    Which firmware version were you using before, when extrusion was working?
                    Please send the following commands from the console, and check that the E values reported in the responses are expected:
                    M92
                    M906
                    M913
                    M563 P0
                    Also please confirm that the hot end heatsink fan is running, and that you can push filament through the hot end by hand to make sure that you don't have a filament jam.
                      droftarts administrators @Leblond
                      @Leblond Does the extruder position change? Here:
                      undefined 2 Replies Last reply 29 Apr 2020, 11:30 Reply Quote 0
                        Leblond @droftarts
                        @droftarts guys I will make the checks tonight after work and keep you informed, I realized that the E0 motor is struggling to turn Responding to @droftarts it is at 0.0 but once I try to extrude 10mm the motor vibrates but does not move, but on extruder driver it marks me from 0 to 10mm, tonight i try to clean the nozzle and i will tell you everything
                          Leblond @droftarts
                          @droftarts good morning everyone, after several tests I found out that the nozzle was blocked, what stole me was the engine that did not jump but remained motionless, however I had to replace the nozzle and clean the heat breack, therefore solved, thanks to everyone for the commitment, there is always something to learn here.
                            Leblond
                            the cases are two at the origin to the problem of the blocking of the extrusures "correct me if I'm wrong !!", 1: when the trigger is wrong, that is too attached to the plate and does not extrude, by force of give and give yes the filament is compact and freezes, 2: filament dirty or low temperature, but the problem encountered by me is strange perhaps it has something to do with it
                            the motor voltage? it is set to 800 but, and in any case it should jump, make the usual "tac tac ..." noise which has not happened to me and which has caused a waste of time for me and for you, I was wondering if there was a way via SW to check if an engine actually runs or not, type ammeter?
                            chrishammundefined 1 Reply Last reply 30 Apr 2020, 11:56 Reply Quote 0
                            • chrishammundefined
                              chrishamm administrators @Leblond
                              @Leblond Yes, there is a way to detect motor stalls. See https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing#main
                              Duet software engineer
                              undefined 1 Reply Last reply 30 Apr 2020, 11:58 Reply Quote 0
                                Leblond @chrishamm
                                @chrishamm ok thanks, I print it and I care about it
                                  Leblond
                                  Good morning and good May 1st
                                  Well I have a problem that repeats itself every time I homing, then I thought the last problem had been the fault of the nozzle blocked by the filament, in part yes, it blocked because the extruder motor stops, now I understood the reason, the tests I did are all without filament in order not to damage the nozzle, I describe what I did:
                                  1: I set the temperature to 180 in order to have the extrusion and retraction buttons active the drive buttons work very well and the motor responds
                                  2: if I homing all the axes and retry the procedure n.1 the extruder no longer works
                                  3: I did the single homing of the axes
                                  4: homing x axis and retrying the extruder and it works
                                  5: homing y axis and retrying the extruder and it works
                                  6: z axis homing and try again the extruder does not work
                                  I tried to load the fw one by one starting from 3.0 until the last beta and the problem persists,
                                  7: I removed the sd and reformatted and loaded the fw but nothing happens
                                  Any suggestions on this?
                                  for @ dc42
                                  m92
                                  Steps / mm: X: 80.000, Y: 80.000, Z: 400.000, E: 424.000
                                  M906
                                  Motor current (mA) - X: 800, Y: 800, Z: 800, E: 800, idle factor 30%
                                  M913
                                  Motor current% of normal - X: 100, Y: 100, Z: 100, E: 0
                                  m563 p0
                                  Tool 0 - drives: 0; heaters (active / standby temps): 1 (180.0 / 0.0); xmap: X; ymap: Y; fans: 0; status: selected
                                  dc42undefined 1 Reply Last reply 1 May 2020, 11:54 Reply Quote 0
                                    Leblond
                                    to restart the engine I have to reset with the command M999
                                      dc42 administrators @Leblond
                                      @Leblond said in Release 3.01-RC10:
                                      Please post your homez.g file.
                                      undefined 1 Reply Last reply 1 May 2020, 12:00 Reply Quote 0
                                        Leblond @dc42
                                        ; homez.g
                                        ; called to home the Z axis
                                        G91 ; relative positioning
                                        G90 ; absolute positioning
                                        G1 X60 Y50 F6000 ; go to first probe point
                                        ;G91 ; relative positioning
                                        ;G1 Z10 F100 ; lift Z relative to current position
                                        ;G90 ; absolute positioning
                                          Leblond
                                          now I have mounted the fw 2.05 to see if even with this it does the same problem
                                          1 out of 62
