    Connect a Lerdge Power Monitoring Module to the Duet Wifi v1.04?
    30
    3.8k
    • bitminterundefined
      bitminter
      Don’t feel bad this module has beaten me as well for time being. I went to the solid state relay setup as highlighted above and was much simpler to get going with the same button. But... I really would like to figure this out too at some point lol.
        bitminter
        Little correction, for me, it’s the Makerbase MKS PWC V2.0 module. No matter what I tried, just couldn’t get it to work.
        • Richygoatundefined
          Richygoat
          Hello, did anybody the Lerdge Power Modul to work with the Duet. I want to try the same thing. Have a Lerdge Power Modul laying around here. What does the PS_ON pin on the Duet exactly? Act it like a 5v on and off switch?
            A Former User @Richygoat
            @Richygoat said in Connect a Lerdge Power Monitoring Module to the Duet Wifi v1.04?:
            https://duet3d.dozuki.com/Wiki/Power_Wiring#Section_Controlling_the_external_power_supply
              Richygoat
              Here is no answer to this question. I want to turn the PSU off with this modul. When it get 5v continuously from the Duet it stays always on. When there is 5v, GND an PS_ON on that connector how does it exactly work. I know this is 5v in. Does the PS_ON switch the 5V to PS_ON?
                Richygoat
                Ok the PS_ON pin will be connected to Ground when the PSU have to be enabled. Is there a way to get a 5v Signal to shut the Relay down? See the picture attached.dr6X10S.png
                  Richygoat
                  Is something like this possible?
                    Richygoat
                    This is how it works perfekt. Big thanks to Eryion from Rics 3D Discord.dr6X10S.png
                    CrazyCreatorundefined Ugurundefined 2 Replies Last reply Reply Quote 0
                    • CrazyCreatorundefined
                      CrazyCreator @Richygoat
                      @Richygoat
                      I edited your sketch and "connected" the switch button. Is that right, did you mean it?1587974008507-dr6x10s.png
                      And a other, next question ...
                      Can you turn off the printer when it is connected via web interface???
                      http://www.crazycreatorcube.com
                      Del87undefined 1 Reply Last reply Reply Quote 0
                        Richygoat
                        Yes that is correct. The 12V/24V is only for the Button LED. Yes i can turn the Printer via Web Interface off.
                          CrazyCreator
                          thanks for the info
                          • Del87undefined
                            Del87 @CrazyCreator
                            @CrazyCreator Hello! Tell me please: what is the white line at the bottom? It is pin connection
                            between top left on black port and top one on the white? And the black line
                            between ps_on and module connects central pins?
                            Thank you in advance for the answer.
                            Dmitry
                            • Ugurundefined
                              Ugur @Richygoat
                              @Richygoat hi, I have panel due with sd card. How i will connect this module?
