    Connect a Lerdge Power Monitoring Module to the Duet Wifi v1.04?
    30
    3.8k
    • Stephen6309undefined
      Stephen6309 @CrazyCreator
      @crazycreator Duet is able to resume after a power loss, if you set it up: https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure
      For powering on/off: https://duet3d.dozuki.com/Wiki/Power_Wiring and
      • CrazyCreatorundefined
        CrazyCreator @CrazyCreator
        @thwe and @Stephen6309
        My only concern is to have a 16mm button on the front of the printer, with this I want to turn on the printer.
        If I can turn off the printer with this button, that would be nice, but it is not necessary. I can do that also via web interface
        http://www.crazycreatorcube.com
        • ediikundefined
          ediik
          If anybody came accross the same thing 😃 i got a solution. now the baord turns ON with the front button.
          Sidenote: it does not matter where you get the 5v from. The pins from the main extension ports are allready if use on my board (bltouch).
          Meltexundefined 1 Reply Last reply Reply Quote 0
            CrazyCreator
            how locks your config.g now
            ediikundefined 1 Reply Last reply Reply Quote 0
            • ediikundefined
              ediik @CrazyCreator
              @CrazyCreator it does not matter. The lerdge board simply gets 5v from the duet and stays on for the time it has 5v connected. No cdg changes necessary. 🙂
                CrazyCreator
                ok ... I would test it
                • Meltexundefined
                  Meltex @ediik
                  @ediik Hi! I came across this thing. 🙂 One question - why don't you use PS_ON signal for controlling Lerdge power module?
                  • ediikundefined
                    ediik @Meltex
                    @Meltex hi sorry for late reply. i honestly dont know how to wire it up the right way.
                    • bitminterundefined
                      bitminter
                      Don’t feel bad this module has beaten me as well for time being. I went to the solid state relay setup as highlighted above and was much simpler to get going with the same button. But... I really would like to figure this out too at some point lol.
                        bitminter
                        Little correction, for me, it’s the Makerbase MKS PWC V2.0 module. No matter what I tried, just couldn’t get it to work.
                        • Richygoatundefined
                          Richygoat
                          Hello, did anybody the Lerdge Power Modul to work with the Duet. I want to try the same thing. Have a Lerdge Power Modul laying around here. What does the PS_ON pin on the Duet exactly? Act it like a 5v on and off switch?
                            A Former User @Richygoat
                            @Richygoat said in Connect a Lerdge Power Monitoring Module to the Duet Wifi v1.04?:
                            https://duet3d.dozuki.com/Wiki/Power_Wiring#Section_Controlling_the_external_power_supply
                              Richygoat
                              Here is no answer to this question. I want to turn the PSU off with this modul. When it get 5v continuously from the Duet it stays always on. When there is 5v, GND an PS_ON on that connector how does it exactly work. I know this is 5v in. Does the PS_ON switch the 5V to PS_ON?
                                Richygoat
                                Ok the PS_ON pin will be connected to Ground when the PSU have to be enabled. Is there a way to get a 5v Signal to shut the Relay down? See the picture attached.dr6X10S.png
                                  Richygoat
                                  Is something like this possible?
                                    Richygoat
                                    This is how it works perfekt. Big thanks to Eryion from Rics 3D Discord.dr6X10S.png
                                    CrazyCreatorundefined Ugurundefined 2 Replies Last reply Reply Quote 0
                                      CrazyCreator @Richygoat
                                      @Richygoat
                                      I edited your sketch and "connected" the switch button. Is that right, did you mean it?1587974008507-dr6x10s.png
                                      And a other, next question ...
                                      Can you turn off the printer when it is connected via web interface???
                                      Del87undefined 1 Reply Last reply Reply Quote 0
                                        Richygoat
                                        Yes that is correct. The 12V/24V is only for the Button LED. Yes i can turn the Printer via Web Interface off.
                                          CrazyCreator
                                          thanks for the info
                                          • Del87undefined
                                            Del87 @CrazyCreator
                                            @CrazyCreator Hello! Tell me please: what is the white line at the bottom? It is pin connection
                                            between top left on black port and top one on the white? And the black line
                                            between ps_on and module connects central pins?
                                            Thank you in advance for the answer.
                                            Dmitry
