    Connect a Lerdge Power Monitoring Module to the Duet Wifi v1.04?
    30
    3.8k
    • CrazyCreatorundefined
      CrazyCreator
      how locks your config.g now
      http://www.crazycreatorcube.com
      ediikundefined 1 Reply Last reply Reply Quote 0
      • ediikundefined
        ediik @CrazyCreator
        @CrazyCreator it does not matter. The lerdge board simply gets 5v from the duet and stays on for the time it has 5v connected. No cdg changes necessary. 🙂
          CrazyCreator
          ok ... I would test it
          • Meltexundefined
            Meltex @ediik
            @ediik Hi! I came across this thing. 🙂 One question - why don't you use PS_ON signal for controlling Lerdge power module?
            • ediikundefined
              ediik @Meltex
              @Meltex hi sorry for late reply. i honestly dont know how to wire it up the right way.
              • bitminterundefined
                bitminter
                Don’t feel bad this module has beaten me as well for time being. I went to the solid state relay setup as highlighted above and was much simpler to get going with the same button. But... I really would like to figure this out too at some point lol.
                  bitminter
                  Little correction, for me, it’s the Makerbase MKS PWC V2.0 module. No matter what I tried, just couldn’t get it to work.
                  • Richygoatundefined
                    Richygoat
                    Hello, did anybody the Lerdge Power Modul to work with the Duet. I want to try the same thing. Have a Lerdge Power Modul laying around here. What does the PS_ON pin on the Duet exactly? Act it like a 5v on and off switch?
                      A Former User @Richygoat
                      @Richygoat said in Connect a Lerdge Power Monitoring Module to the Duet Wifi v1.04?:
                      https://duet3d.dozuki.com/Wiki/Power_Wiring#Section_Controlling_the_external_power_supply
                        Richygoat
                        Here is no answer to this question. I want to turn the PSU off with this modul. When it get 5v continuously from the Duet it stays always on. When there is 5v, GND an PS_ON on that connector how does it exactly work. I know this is 5v in. Does the PS_ON switch the 5V to PS_ON?
                          Richygoat
                          Ok the PS_ON pin will be connected to Ground when the PSU have to be enabled. Is there a way to get a 5v Signal to shut the Relay down? See the picture attached.dr6X10S.png
                            Richygoat
                            Is something like this possible?
                              Richygoat
                              This is how it works perfekt. Big thanks to Eryion from Rics 3D Discord.dr6X10S.png
                              CrazyCreatorundefined Ugurundefined 2 Replies Last reply Reply Quote 0
                                CrazyCreator @Richygoat
                                @Richygoat
                                I edited your sketch and "connected" the switch button. Is that right, did you mean it?1587974008507-dr6x10s.png
                                And a other, next question ...
                                Can you turn off the printer when it is connected via web interface???
                                Del87undefined 1 Reply Last reply Reply Quote 0
                                  Richygoat
                                  Yes that is correct. The 12V/24V is only for the Button LED. Yes i can turn the Printer via Web Interface off.
                                    CrazyCreator
                                    thanks for the info
                                    • Del87undefined
                                      Del87 @CrazyCreator
                                      @CrazyCreator Hello! Tell me please: what is the white line at the bottom? It is pin connection
                                      between top left on black port and top one on the white? And the black line
                                      between ps_on and module connects central pins?
                                      Thank you in advance for the answer.
                                      Dmitry
                                      • Ugurundefined
                                        Ugur @Richygoat
                                        @Richygoat hi, I have panel due with sd card. How i will connect this module?
