    Release 3.01-RC10
    2.8k
    • sebkritikelundefined
      sebkritikel @Leblond
      @Leblond said in Release 3.01-RC10:
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 23 2020 22:39:29 GMT+0200 (Ora legale dell’Europa centrale)
      G91 ; relative positioning
      M913 X50 Y50 ; Riduci la corrente al 50%
      G1 H1 X-9999 Y-9999 F4000 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X-9999 ; home X axis
      G1 H1 Y-9999 ; home Y axis
      G1 X5 Y5 F2000 ; go back a few mm
      G1 H1 X-9999 F360 ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y-9999 ; then move slowly to Y axis endstop
      G90 ; absolute positioning
      G1 X60 Y50 F9000 ; go to first bed probe point and home Z
      M913 X100 Y100 :Riporta la corrente al 100%
      ;G91 ; relative positioning
      ;G1 Z10 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      Can you try:
      ;homeall.g
      ;;;M913 X50 Y50 ; Riduci la corrente al 50%
      G1 H1 Y-9999 F360 ; then move slowly to Y axis endstop
      ;;;M913 X100 Y100 :Riporta la corrente al 100%
      Leblondundefined 2 Replies Last reply Reply Quote 0
      • Leblondundefined
        Leblond @sebkritikel
        @sebkritikel ok now i try
        • Leblondundefined
          @sebkritikel said in Release 3.01-RC10:
          ;homeall.g G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position ;;;M913 X50 Y50 ; Riduci la corrente al 50% G1 H1 X-9999 Y-9999 F4000 ; move quickly to X or Y endstop and stop there (first pass) G1 X5 Y5 F2000 ; go back a few mm G1 H1 X-9999 F360 ; move slowly to X axis endstop once more (second pass) G1 H1 Y-9999 F360 ; then move slowly to Y axis endstop G90 ; absolute positioning G1 X60 Y50 F9000 ; go to first bed probe point and home Z ;;;M913 X100 Y100 :Riporta la corrente al 100% G30 ; home Z by probing the bed
          91/5000
          wait because it gives me an error "6/5/2020, 18:12:41 G28
          Error: G0 / G1: insufficient axes homed "
          sebkritikelundefined 2 Replies Last reply Reply Quote 0
            This post is deleted!
              91/5000
              Ok maybe my mistake. Please try:
              ;homeall.g
              G1 H1 Y-9999 F360; then move slowly to Y axis endstop
              • Leblondundefined
                • Leblondundefined
                  @sebkritikel there was a small error, so it works:
                  ; homeall.g
                  G91; relative positioning
                  G1 H2 Z5 F6000; lift Z relative to current position
                  ; M913 X50 Y50; Reduce the current to 50%
                  G1 H1 X-9999 F4000
                  G1 H1 Y-9999; move quickly to X or Y endstop and stop there (first pass)
                  G1 X5 Y5 F2000; go back a few mm
                  G1 H1 X-9999 F360
                  G1 H1 Y-9999; move slowly to X axis endstop once more (second pass)
                  G90; absolute positioning
                  G1 X60 Y50 F9000; go to first bed probe point and home Z
                  ; M913 X100 Y100: Returns the current to 100%
                  G30; home Z by probing the bed
                  Change something for you?
                  sebkritikelundefined 1 Reply Last reply Reply Quote 0
                  • Leblondundefined
                    Leblond
                    by the test I mean
                      ; homeall.g
                      G1 H1 X-9999 F4000
                      G1 H1 X-9999 F360
                      I think I made a mistake. I am not a CoreXY expert 🤠 Sorry!
                      So does:
                      ; homeall.g
                      G1 H1 X-9999 F4000
                      G1 H1 X-9999 F360
                      Work ok?
                      • Leblondundefined
                        @sebkritikel quello che ho corretto io funziona bene
                        ho provato e l'estrusore funziona bene
                        • Leblondundefined
                          @sebkritikel thank you so much my friend
                          sebkritikelundefined 1 Reply Last reply Reply Quote 1
                          • Leblondundefined
                            Leblond
                            so does the M913 command make a mess?
                              Happy to help!
                              I do not know. Can you test this:
                              ; homeall.g
                              G1 H1 X-9999 F4000
                              G1 H1 X-9999 F360
                              with M913
                              Leblondundefined sebkritikelundefined 2 Replies Last reply Reply Quote 1
                              • Leblondundefined
                                @sebkritikel ok wait for it to load
                                • Leblondundefined
                                  Leblond
                                  no it doesn't work that way
                                  • Leblondundefined
                                    Leblond
                                    with the command M913 inserted it does not work
                                      sebkritikel @sebkritikel
                                      Happy to help!
                                      ; homeall.g
                                      G1 H1 X-9999 F4000
                                      G1 H1 X-9999 F360
                                      with M913
                                      Ok, I do not know why. @dc42 to me it looks like its narrowed down to M913. I do not use this command, so unfortunately I do not have any insight.
                                      • Leblondundefined
                                        Leblond
                                        no problem, I don't wear it and I'm happy like this
                                        • Leblondundefined
                                          Leblond
                                          maybe it can depend on which position it is inserted ..
                                          • Leblondundefined
                                            Leblond
                                            however it does it only and exclusively in the homeall.g file, because in other files I have inserted it and it works well
