    Cura Script to Automatically Probe Only Printed Area
    60
    7.6k
    • mwolterundefined
      mwolter
      Thought it would be a fun project to learn Python and modified CCS86's script to work with Simplify3D. It was created with Python 3.8.1 on a Mac running Catalina and S3D 4.1.2 and tested with a 6mb gcode file. It will not work with Python2.
      All you should need to do is copy the script to your computer (removing the .txt), make sure your starting script contains probing grid definition (ie M557 X30:300 Y30:300 S13.5) and add the following to the post processing.
      python3 <full path to folder>/meshgrid.py "[output_filepath]" (quotes around [output_filepath] are manditory)
      The script will read the first layer to obtain the print boundaries, verify it fits within the bed size specified in S3D, find the existing M557 and rewrite the min and max X Y coordinates. It might need some fine-tuning if used on a printer with 0,0 in the center of the bed.
      Enjoy!
      Edit: The forum server is not allowing the upload of txt files. Paste the code below into a text editor and save it as meshgrid.py .
      #!/usr/bin/env python3
      """Simplify3D post-processing script for RepRap firmware printers which dynamically defines the mesh grid dimensions (M557) based on the print dimensions.
      Usage:
          Within Simplify3D > Process Settings > Scripts > Post Processing > add the following command:
              python3 <script_location>/meshgrid.py "[output_filepath]"
          Starting script must contain M557 Command (ie M557 X30:300 Y30:300 P20).
      Args:
          Path: Complete path to the gcode file created by Simplify 3d.
      Requirements:
          Tested using Python 3.8.1.
      Credit:
          Adapted from code originally posted by CCS86 on https://forum.duet3d.com/topic/15302/cura-script-to-automatically-probe-only-printed-area?_=1587348242875.
      import sys
      import re
      import math
      def main(filename):
          try:
              _s3dFile = open(filename, encoding='utf-8')
          except TypeError:
              try:
                  _s3dFile = open(filename)
              except:
                  print("Open file exception. Exiting meshgrid.py.")
                  sys.exit()
          except FileNotFoundError:
              print('File not found. Exiting meshgrid.py.')
              sys.exit()
          lines = _s3dFile.readlines()
          _s3dFile.close()
          linesNew = calcBed(lines)
          _s3dFileNew = open(filename, "r+")
          _s3dFileNew.seek(0)
          _s3dFileNew.truncate()
          for element in linesNew:
              _s3dFileNew.write(element)
          _s3dFileNew.close()
          return
      def calcBed(lines):
          bounds = findBounds(lines)
          bed = findBed(lines)
          for axis in bounds:
              if bounds[axis]['max'] - bounds[axis]['min'] < bed[axis]:
                  print(f'Success: {axis} mesh is smaller than bed')
              else:
                  print('Error: Mesh is larger than bed. Exiting meshgrid.py.')
                  sys.exit()
              for limit in bounds[axis]:
                  if limit == 'min':
                      if (bed[axis] / 2) - bounds[axis][limit] > 0:
                          print (f'Success: {axis} {limit} coordinate is on the bed.')
                      else:
                          print (f'Error: {axis} {limit} coordinate is off the bed. Exiting meshgrid.py.')
                          sys.exit()
                  if limit == 'max':
                      if (bed[axis]) - bounds[axis][limit] > 0:
                      else:
                          sys.exit()
          return fillGrid(bounds, lines)
      def findBed(lines):
          bed = {
              'X': 0,
              'Y': 0,
          for line in lines:
              if line.startswith(';   strokeXoverride,'):
                  bed['X'] = int(re.search(r'\d.+\S', line).group())
              elif line.startswith(';   strokeYoverride,'):
                  bed['Y'] = int(re.search(r'\d.+', line).group())
                  break
          return bed
      def findBounds(lines):
          bounds = {
              'X': {'min': 9999, 'max': 0},
              'Y': {'min': 9999, 'max': 0},
          parsing = False
          for line in lines:
              if line.startswith('; layer 1,'):
                  parsing = True
                  continue
              elif line.startswith('; layer 2,'):
                  break
              if parsing:
                  # Get coordinates on this line
                  for match in re.findall(r'([YX])([\d.]+)\s', line):
                      # Get axis letter
                      axis = match[0]
                      # Skip axes we don't care about
                      if axis not in bounds:
                          continue
                      # Parse parameter value
                      value = float(match[1])
                      # Update bounds
                      bounds[axis]['min'] = math.floor(min(bounds[axis]['min'], value))
                      bounds[axis]['max'] = math.ceil(max(bounds[axis]['max'], value))
          return bounds
      def fillGrid(bounds, lines):
          # Fill in the level command template
          gridNew = 'M557 X%d:%d Y%d:%d' % (
              bounds['X']['min'], bounds['X']['max'],
              bounds['Y']['min'], bounds['Y']['max'],
          # Replace M557 command in GCODE
          linesNew = []
          for line in lines:
              if line.startswith('M557'):
                  linesNew.append(re.sub(r'^M557 X\d+:\d+ Y\d+:\d+', gridNew, line, flags=re.MULTILINE))
              else:
                  linesNew.append(line)
          return linesNew
      if __name__ == '__main__':
          if sys.argv[1]:
              main(filename = sys.argv[1])
          else:
              print('Error: Proper s3d post processing command is python3 <script_location>/meshgrid.py "[output_filepath]". Exiting meshgrid.py.')
              sys.exit()
      • insertnamehereundefined
        insertnamehere @CCS86
        Thanks @CCS86, what a brilliant idea, and @mwolter, thanks, I used most of your code and got it working on Slic3r.
        Works just great.
        I never used mesh leveling because of the time involved probing the entire bed before printing. However, now I can, and I'm getting great first layer results.
        Cheers guys.
        Luke'sLaboratoryundefined 1 Reply Last reply Reply Quote 1
        • Luke'sLaboratoryundefined
          Luke'sLaboratory @insertnamehere
          @insertnamehere
          Care to share?
          Luke
          http://lukeslab.online
          insertnamehereundefined 1 Reply Last reply Reply Quote 1
            insertnamehere @Luke'sLaboratory
            @Luke-sLaboratory said in Cura Script to Automatically Probe Only Printed Area:
            @insertnamehere
            Care to share?
            I was afraid that someone would ask that. ☺
            Its butt-ugly code right now. Let me clean it up and I'll post it here.
              insertnamehere
              For @Luke-sLaboratory.
              This is @mwolter 's code modified to work with Slic3r, PrusaSlicer or Slic3r++. Follow the instructions in the comments to configure Slic3r.
              Slightly changed so that the minimum size of the mesh is 3x3 on prints with small base size.
              #!/usr/bin/python
              	Slic3r post-processing script for RepRap firmware printers which dynamically defines the mesh grid dimensions (M557) based on the print dimensions.
              {1}
              Usage:
              {1}
              	Slic3r Settings:
              	In Print Settings > Output Options
              	1. turn no "Verbose G-code"
              	2. in "Post-processing scripts" type the full path to python and the full path to this script
              	e.g. <Python Path>\python.exe  <Script Path>\meshcalc.py;
              	In Printer Settings > Custom G-code > Start G-code
              	Make sure the start g-code contains the M557 command, and that you probe the bed and load the compensation map,  e.g.
              	M557 X10:290 Y10:290 S20	; Setup default grid
              	G29							; Mesh bed probe
              	G29 S1						; Load compensation map
              	Script Settings
              	probeSpacing = 20 - change this to the preferred probe point spacing in M557
              	Note: The minimum X and Y of the probed area is limited to 2 times the probeSpacing.
              	This is so that prints with a small footprint will have a minimum 3x3 probe mesh
              {1}
              Args:
              {1}
              	Path: The path parameter will be provided by Slic3r.
              {1}
              Requirements:
              {1}
              	The latest version of Python.
              	Note that I use this on windows and haven't tried it on any other platform.
              	Also this script assumes that the bed origin (0,0) is NOT the centre of the bed. Go ahead and modify this script as required.
              {1}
              Credit:
              {1}
              	Based on code originally posted by CCS86 on https://forum.duet3d.com/topic/15302/cura-script-to-automatically-probe-only-printed-area?_=1587348242875.
              	and maybe 90% or more is code posted by MWOLTER on the same thread.
              	Thank you both.
              import sys
              import re
              import math
              import os
              probeSpacing = 20   		# set your required probe point spacing for M557
              def main(fname):
              	print("Starting Mesh Calculations")
              	try:
              		_Slic3rFile = open(fname, encoding='utf-8')
              	except TypeError:
              		try:
              			_Slic3rFile = open(fname)
              		except:
              			print("Open file exception. Exiting.")
              			error()
              		print('File not found. Exiting.')
              		error()
              	lines = _Slic3rFile.readlines()
              	_Slic3rFile.close()
              	_Slic3rFile = open(fname, "r+")
              	_Slic3rFile.seek(0)
              	_Slic3rFile.truncate()
              		_Slic3rFile.write(element)
              	_Slic3rFile.close()
              	return
              def error():
              	# remove the next 2 lines to close console automatically
              	print("Press Enter to close")
              	input()
              	sys.exit()
              def calcBed(lines):
              	bed = findBed()
              	for axis in bounds:
              		else:
              			print('Error: Mesh is larger than bed. Exiting.')
              			error()
              			if limit == 'min':
              					print(f'Success: {axis} {limit} coordinate is on the bed.')
              				else:
              					print(f'Error: {axis} {limit} coordinate is off the bed. Exiting.')
              					error()
              			if limit == 'max':
              				else:
              					error()
              def findBed():
              	bed = {
              		'X': 0,
              		'Y': 0,
              	bedCorners = os.environ.get("SLIC3R_BED_SHAPE")
              	maxXY = bedCorners.split(',')[2].split('x')
              	bed['X'] = int(maxXY[0])
              	bed['Y'] = int(maxXY[1])
              	print(bed)
              	return bed
              	bounds = {
              	parsing = False
              	for line in lines:
              		if "move to next layer (0)" in line:
              			parsing = True
              			continue
              		elif "move to next layer (1)" in line:
              			break
              		if parsing:
              				# Get axis letter
              				axis = match[0]
              					continue
              				# Update bounds
              	# make sure the bounds are at least 2 x Probe Point Spacing, for small prints.
              	if parsing:
              		global probeSpacing
              		for axis in bounds:
              			spacing = (bounds[axis]['max'] - bounds[axis]['min'])/2
              			if spacing < probeSpacing:
              				probeSpacing = spacing
              	print("Bounds are: " + str(bounds))
              	return bounds
              	gridNew = 'M557 X%d:%d Y%d:%d S%d' % (
              		probeSpacing
              	linesNew = []
              	for line in lines:
              			linesNew.append(re.sub(r'^M557 X\d+:\d+ Y\d+:\d+ S\d+', gridNew, line, flags=re.MULTILINE))
              			print('New M557: ' + linesNew[-1])
              		else:
              	return linesNew
              	if sys.argv[1]:
              		main(fname = sys.argv[1])
              	else:
              		print('Error: Proper Slic3r post processing command is python3')
              		error()
              I've updated with improvements so that the console remains open if there is an error, and the probe point spacing automatically reduces in size for small prints.
              Luke'sLaboratoryundefined 1 Reply Last reply Reply Quote 2
                @insertnamehere
                You the Bomb!
                Thanks!
                Luke
                  Luke'sLaboratory
                  Alright - I've made an improvement to the script, I have an extra-large machine and depending on how much of the bed I'm using at any given point, I can exceed the points-per-axis limitations of duet firmware (currently 21:21). It now will run the calculations, and if there are more than 21 points required, it converts over to using the P parameter instead of the S parameter, trying to honor the original requested spacing.
                  #!/usr/bin/python
                  {1}
                  Usage:
                  {1}
                  	Slic3r Settings:
                  {1}
                  	Script Settings
                  {1}
                  Args:
                  {1}
                  {1}
                  Requirements:
                  {1}
                  {1}
                  Credit:
                  {1}
                  	Thank you both.
                  import sys
                  import re
                  import math
                  import os
                  def main(fname):
                  	try:
                  	except TypeError:
                  		try:
                  		except:
                  			error()
                  		error()
                  	_Slic3rFile.close()
                  	_Slic3rFile.seek(0)
                  	_Slic3rFile.close()
                  	return
                  def error():
                  	input()
                  	sys.exit()
                  def calcBed(lines):
                  	bed = findBed()
                  	for axis in bounds:
                  		else:
                  			error()
                  			if limit == 'min':
                  				else:
                  					error()
                  			if limit == 'max':
                  				else:
                  					error()
                  def findBed():
                  	bed = {
                  		'X': 0,
                  		'Y': 0,
                  	print(bed)
                  	return bed
                  	bounds = {
                  	parsing = False
                  	for line in lines:
                  			parsing = True
                  			continue
                  			break
                  		if parsing:
                  				# Get axis letter
                  				axis = match[0]
                  					continue
                  				# Update bounds
                      # also, make sure that the maximum amount of points isn't exceeded.
                  	if parsing:
                  		global probeSpacing
                  		for axis in bounds:
                  	return bounds
                      #Check the quantity of points - cannot exceed 21points per axis, otherwise will throw error and ruin print by not running a mesh
                      X_points=(bounds['X']['max']-bounds['X']['min'])/probeSpacing
                      Y_points=(bounds['Y']['max']-bounds['Y']['min'])/probeSpacing
                      if X_points>21 or Y_points>21:
                       Points=True
                  	 #basically, if its over 21, just use 21, if not, round up, keeping roughly the same spacing for the non-affected axis
                       if X_points>21: X_points = 21
                       else: X_points = math.ceil(X_points)
                       if Y_points>21: Y_points=21
                       else:Y_points = math.ceil(Y_points)
                       print('With your required print footprint, you\'ll exceed 21 points on either axis, changing to point based. Your new point grid is {}:{} points'.format(X_points,Y_points))
                      else:
                       Points=False
                      if Points == True:
                          gridNew = 'M557 X{}:{} Y{}:{} P{}:{}'.format(bounds['X']['min'], bounds['X']['max'],bounds['Y']['min'], bounds['Y']['max'], X_points, Y_points)
                      else:
                  	    gridNew = 'M557 X{}:{} Y{}:{} S{}'.format(bounds['X']['min'], bounds['X']['max'],bounds['Y']['min'], bounds['Y']['max'], probeSpacing)
                      linesNew = []
                      for line in lines:
                          else:
                      return linesNew
                  	if sys.argv[1]:
                  	else:
                  		error()
                  Luke
                  zaptaundefined 1 Reply Last reply Reply Quote 1
                  • Baenwortundefined
                    Baenwort
                    Does this work for Deltas who don't have their M557 as a x and y coordinate?
                    insertnamehereundefined 1 Reply Last reply Reply Quote 0
                      insertnamehere @Baenwort
                      @Baenwort said in Cura Script to Automatically Probe Only Printed Area:
                      No it won't. But it could be modified.
                      Baenwortundefined 1 Reply Last reply Reply Quote 0
                      • zaptaundefined
                        zapta @Luke'sLaboratory
                        Do we need to add to the prusaslicer gcode settings generation of layer markers or is there a setting to have it enabled automatically.
                        • zaptaundefined
                          zapta @zapta
                          I setup my prusaslicer to use this script and it works very well. I looked for some time for per-print mesh automation and this one does the job. Thanks for sharing it.
                          The file version I am using is in the github link below. It uses utility classes to handle intervals and rectangles but otherwise it's the same flow. There are still a few TODOs but I am using it with my regular prints.
                          https://github.com/zapta/misc/blob/master/duet3d_automesh/duet3d_automesh.py
                          • Baenwortundefined
                            Baenwort @insertnamehere
                            @insertnamehere
                            It would be great!
                            • zaptaundefined
                              zapta @Baenwort
                              I cleaned up the python script. It now has command line flags that allow customization (set them in the slicer post processing command line).
                              I am very happy with the per-print quick partial meshing, getting good first layer without worrying about leveling. Ideally the slicers would provide the first layer's bounding box as place holders we can embed in gcode.
                              tcjundefined 1 Reply Last reply Reply Quote 1
                              • tcjundefined
                                tcj @zapta
                                @zapta could you please change the script that it can handle negative coordinates in --meshable ?
                                This will make it usable for Delta printers, because
                                "For Cartesian printers, specify minimum and maximum X and Y values to probe and the probing interval. For Delta printers, specify the probing radius. If you define both, the probing area will be the intersection of the rectangular area and the circle. "
                                https://duet3d.dozuki.com/Wiki/Gcode#Section_M557_Set_Z_probe_point_or_define_probing_grid
                                Thank you
                                • zaptaundefined
                                  zapta @tcj
                                  @tcj, I made the change. Can you give it another try?
                                  https://github.com/zapta/misc/tree/master/duet3d_automesh
                                  tcjundefined 1 Reply Last reply Reply Quote 0
                                  • tcjundefined
                                    tcj @zapta
                                    @zapta thank you for the effort, but ist does not work yet
                                    only defining the default meshable area within the script (line 50) by
                                    default="-185:185,-185:185"
                                    works,
                                    but when adding
                                    <path to your python3> <path_to_the_duet3d_automesh.py file> --meshable "-185:185,-185:185"
                                    to the Post-processing script, it fails
                                    • zaptaundefined
                                      zapta @tcj
                                      @tcj, try this syntax for the flags (notice the '=')
                                      --meshable=-30:250,-3:280
                                      • tcjundefined
                                        tcj @zapta
                                        @zapta 👍 👏
                                        Thank you
                                        • DK90undefined
                                          DK90
                                          @zapta said in Cura Script to Automatically Probe Only Printed Area:
                                          Hello, i have the following error when i am trying to ad the postprocess
                                          can some one help me please?
                                          Thanks
                                          Post-processing script C:\Users\Dominic\AppData\Local\Programs\Python\Python36-32\python.exe C:\Program Files\Prusa3D\PrusaSlicer\duet3d_automesh.py file on file D:\2_Projekte\3D Druck\2_Modelle\28_R2D2_Did3D\R2D2_Did3D_SW_FullPack_h\STL_Final\zumdruckenbereit\Cube_PLA_Center foot_0.2mm_PET_2h24m.gcode failed.
                                          Error code: 2
                                          • tcjundefined
                                            tcj @DK90
                                            @DK90 the space in "Program Files" leads to this error
                                            change it to
                                            C:\Users\Dominic\AppData\Local\Programs\Python\Python36-32\python.exe "C:\Program Files\Prusa3D\PrusaSlicer\duet3d_automesh.py"
                                            notice the "
                                            DK90undefined 1 Reply Last reply Reply Quote 1
