    Cura Script to Automatically Probe Only Printed Area
    60
    7.4k
    • insertnamehereundefined
      insertnamehere @CCS86
      Thanks @CCS86, what a brilliant idea, and @mwolter, thanks, I used most of your code and got it working on Slic3r.
      Works just great.
      I never used mesh leveling because of the time involved probing the entire bed before printing. However, now I can, and I'm getting great first layer results.
      Cheers guys.
      Luke'sLaboratoryundefined 1 Reply Last reply Reply Quote 1
      • Luke'sLaboratoryundefined
        Luke'sLaboratory @insertnamehere
        @insertnamehere
        Care to share?
        Luke
        http://lukeslab.online
        insertnamehereundefined 1 Reply Last reply Reply Quote 1
          insertnamehere @Luke'sLaboratory
          @Luke-sLaboratory said in Cura Script to Automatically Probe Only Printed Area:
          @insertnamehere
          Care to share?
          I was afraid that someone would ask that. ☺
          Its butt-ugly code right now. Let me clean it up and I'll post it here.
            insertnamehere
            For @Luke-sLaboratory.
            This is @mwolter 's code modified to work with Slic3r, PrusaSlicer or Slic3r++. Follow the instructions in the comments to configure Slic3r.
            Slightly changed so that the minimum size of the mesh is 3x3 on prints with small base size.
            #!/usr/bin/python
            	Slic3r post-processing script for RepRap firmware printers which dynamically defines the mesh grid dimensions (M557) based on the print dimensions.
            {1}
            Usage:
            {1}
            	Slic3r Settings:
            	In Print Settings > Output Options
            	1. turn no "Verbose G-code"
            	2. in "Post-processing scripts" type the full path to python and the full path to this script
            	e.g. <Python Path>\python.exe  <Script Path>\meshcalc.py;
            	In Printer Settings > Custom G-code > Start G-code
            	Make sure the start g-code contains the M557 command, and that you probe the bed and load the compensation map,  e.g.
            	M557 X10:290 Y10:290 S20	; Setup default grid
            	G29							; Mesh bed probe
            	G29 S1						; Load compensation map
            	Script Settings
            	probeSpacing = 20 - change this to the preferred probe point spacing in M557
            	Note: The minimum X and Y of the probed area is limited to 2 times the probeSpacing.
            	This is so that prints with a small footprint will have a minimum 3x3 probe mesh
            {1}
            Args:
            {1}
            	Path: The path parameter will be provided by Slic3r.
            {1}
            Requirements:
            {1}
            	The latest version of Python.
            	Note that I use this on windows and haven't tried it on any other platform.
            	Also this script assumes that the bed origin (0,0) is NOT the centre of the bed. Go ahead and modify this script as required.
            {1}
            Credit:
            {1}
            	Based on code originally posted by CCS86 on https://forum.duet3d.com/topic/15302/cura-script-to-automatically-probe-only-printed-area?_=1587348242875.
            	and maybe 90% or more is code posted by MWOLTER on the same thread.
            	Thank you both.
            import sys
            import re
            import math
            import os
            probeSpacing = 20   		# set your required probe point spacing for M557
            def main(fname):
            	print("Starting Mesh Calculations")
            	try:
            		_Slic3rFile = open(fname, encoding='utf-8')
            	except TypeError:
            		try:
            			_Slic3rFile = open(fname)
            		except:
            			print("Open file exception. Exiting.")
            			error()
            	except FileNotFoundError:
            		print('File not found. Exiting.')
            		error()
            	lines = _Slic3rFile.readlines()
            	_Slic3rFile.close()
            	linesNew = calcBed(lines)
            	_Slic3rFile = open(fname, "r+")
            	_Slic3rFile.seek(0)
            	_Slic3rFile.truncate()
            	for element in linesNew:
            		_Slic3rFile.write(element)
            	_Slic3rFile.close()
            	return
            def error():
            	# remove the next 2 lines to close console automatically
            	print("Press Enter to close")
            	input()
            	sys.exit()
            def calcBed(lines):
            	bounds = findBounds(lines)
            	bed = findBed()
            	for axis in bounds:
            		if bounds[axis]['max'] - bounds[axis]['min'] < bed[axis]:
            			print(f'Success: {axis} mesh is smaller than bed')
            		else:
            			print('Error: Mesh is larger than bed. Exiting.')
            			error()
            		for limit in bounds[axis]:
            			if limit == 'min':
            				if (bed[axis]) - bounds[axis][limit] > 0:
            					print(f'Success: {axis} {limit} coordinate is on the bed.')
            				else:
            					print(f'Error: {axis} {limit} coordinate is off the bed. Exiting.')
            					error()
            			if limit == 'max':
            				else:
            					error()
            	return fillGrid(bounds, lines)
            def findBed():
            	bed = {
            		'X': 0,
            		'Y': 0,
            	bedCorners = os.environ.get("SLIC3R_BED_SHAPE")
            	maxXY = bedCorners.split(',')[2].split('x')
            	bed['X'] = int(maxXY[0])
            	bed['Y'] = int(maxXY[1])
            	print(bed)
            	return bed
            def findBounds(lines):
            	bounds = {
            		'X': {'min': 9999, 'max': 0},
            		'Y': {'min': 9999, 'max': 0},
            	parsing = False
            	for line in lines:
            		if "move to next layer (0)" in line:
            			parsing = True
            			continue
            		elif "move to next layer (1)" in line:
            			break
            		if parsing:
            			# Get coordinates on this line
            			for match in re.findall(r'([YX])([\d.]+)\s', line):
            				# Get axis letter
            				axis = match[0]
            				# Skip axes we don't care about
            				if axis not in bounds:
            					continue
            				# Parse parameter value
            				value = float(match[1])
            				# Update bounds
            				bounds[axis]['min'] = math.floor(min(bounds[axis]['min'], value))
            				bounds[axis]['max'] = math.ceil(max(bounds[axis]['max'], value))
            	# make sure the bounds are at least 2 x Probe Point Spacing, for small prints.
            	if parsing:
            		global probeSpacing
            		for axis in bounds:
            			spacing = (bounds[axis]['max'] - bounds[axis]['min'])/2
            			if spacing < probeSpacing:
            				probeSpacing = spacing
            	print("Bounds are: " + str(bounds))
            	return bounds
            def fillGrid(bounds, lines):
            	# Fill in the level command template
            	gridNew = 'M557 X%d:%d Y%d:%d S%d' % (
            		bounds['X']['min'], bounds['X']['max'],
            		bounds['Y']['min'], bounds['Y']['max'],
            		probeSpacing
            	# Replace M557 command in GCODE
            	linesNew = []
            	for line in lines:
            		if line.startswith('M557'):
            			linesNew.append(re.sub(r'^M557 X\d+:\d+ Y\d+:\d+ S\d+', gridNew, line, flags=re.MULTILINE))
            			print('New M557: ' + linesNew[-1])
            		else:
            			linesNew.append(line)
            	return linesNew
            if __name__ == '__main__':
            	if sys.argv[1]:
            		main(fname = sys.argv[1])
            	else:
            		print('Error: Proper Slic3r post processing command is python3')
            		error()
            I've updated with improvements so that the console remains open if there is an error, and the probe point spacing automatically reduces in size for small prints.
            Luke'sLaboratoryundefined 1 Reply Last reply Reply Quote 2
              @insertnamehere
              You the Bomb!
              Thanks!
              Luke
                Luke'sLaboratory
                Alright - I've made an improvement to the script, I have an extra-large machine and depending on how much of the bed I'm using at any given point, I can exceed the points-per-axis limitations of duet firmware (currently 21:21). It now will run the calculations, and if there are more than 21 points required, it converts over to using the P parameter instead of the S parameter, trying to honor the original requested spacing.
                #!/usr/bin/python
                {1}
                Usage:
                {1}
                	Slic3r Settings:
                {1}
                	Script Settings
                {1}
                Args:
                {1}
                {1}
                Requirements:
                {1}
                {1}
                Credit:
                {1}
                	Thank you both.
                import sys
                import re
                import math
                import os
                def main(fname):
                	try:
                	except TypeError:
                		try:
                		except:
                			error()
                		error()
                	_Slic3rFile.close()
                	_Slic3rFile.seek(0)
                	_Slic3rFile.close()
                	return
                def error():
                	input()
                	sys.exit()
                def calcBed(lines):
                	bed = findBed()
                	for axis in bounds:
                		else:
                			error()
                			if limit == 'min':
                				else:
                					error()
                			if limit == 'max':
                				else:
                					error()
                def findBed():
                	bed = {
                		'X': 0,
                		'Y': 0,
                	print(bed)
                	return bed
                	bounds = {
                	parsing = False
                	for line in lines:
                			parsing = True
                			continue
                			break
                		if parsing:
                				# Get axis letter
                				axis = match[0]
                					continue
                				# Update bounds
                    # also, make sure that the maximum amount of points isn't exceeded.
                	if parsing:
                		global probeSpacing
                		for axis in bounds:
                	return bounds
                    #Check the quantity of points - cannot exceed 21points per axis, otherwise will throw error and ruin print by not running a mesh
                    X_points=(bounds['X']['max']-bounds['X']['min'])/probeSpacing
                    Y_points=(bounds['Y']['max']-bounds['Y']['min'])/probeSpacing
                    if X_points>21 or Y_points>21:
                     Points=True
                	 #basically, if its over 21, just use 21, if not, round up, keeping roughly the same spacing for the non-affected axis
                     if X_points>21: X_points = 21
                     else: X_points = math.ceil(X_points)
                     if Y_points>21: Y_points=21
                     else:Y_points = math.ceil(Y_points)
                     print('With your required print footprint, you\'ll exceed 21 points on either axis, changing to point based. Your new point grid is {}:{} points'.format(X_points,Y_points))
                    else:
                     Points=False
                    if Points == True:
                        gridNew = 'M557 X{}:{} Y{}:{} P{}:{}'.format(bounds['X']['min'], bounds['X']['max'],bounds['Y']['min'], bounds['Y']['max'], X_points, Y_points)
                    else:
                	    gridNew = 'M557 X{}:{} Y{}:{} S{}'.format(bounds['X']['min'], bounds['X']['max'],bounds['Y']['min'], bounds['Y']['max'], probeSpacing)
                    linesNew = []
                    for line in lines:
                        else:
                    return linesNew
                	if sys.argv[1]:
                	else:
                		error()
                Luke
                zaptaundefined 1 Reply Last reply Reply Quote 1
                • Baenwortundefined
                  Baenwort
                  Does this work for Deltas who don't have their M557 as a x and y coordinate?
                  insertnamehereundefined 1 Reply Last reply Reply Quote 0
                    insertnamehere @Baenwort
                    @Baenwort said in Cura Script to Automatically Probe Only Printed Area:
                    No it won't. But it could be modified.
                    Baenwortundefined 1 Reply Last reply Reply Quote 0
                    • zaptaundefined
                      zapta @Luke'sLaboratory
                      Do we need to add to the prusaslicer gcode settings generation of layer markers or is there a setting to have it enabled automatically.
                      • zaptaundefined
                        zapta @zapta
                        I setup my prusaslicer to use this script and it works very well. I looked for some time for per-print mesh automation and this one does the job. Thanks for sharing it.
                        The file version I am using is in the github link below. It uses utility classes to handle intervals and rectangles but otherwise it's the same flow. There are still a few TODOs but I am using it with my regular prints.
                        https://github.com/zapta/misc/blob/master/duet3d_automesh/duet3d_automesh.py
                        • Baenwortundefined
                          Baenwort @insertnamehere
                          @insertnamehere
                          It would be great!
                          • zaptaundefined
                            zapta @Baenwort
                            I cleaned up the python script. It now has command line flags that allow customization (set them in the slicer post processing command line).
                            I am very happy with the per-print quick partial meshing, getting good first layer without worrying about leveling. Ideally the slicers would provide the first layer's bounding box as place holders we can embed in gcode.
                            tcjundefined 1 Reply Last reply Reply Quote 1
                            • tcjundefined
                              tcj @zapta
                              @zapta could you please change the script that it can handle negative coordinates in --meshable ?
                              This will make it usable for Delta printers, because
                              "For Cartesian printers, specify minimum and maximum X and Y values to probe and the probing interval. For Delta printers, specify the probing radius. If you define both, the probing area will be the intersection of the rectangular area and the circle. "
                              https://duet3d.dozuki.com/Wiki/Gcode#Section_M557_Set_Z_probe_point_or_define_probing_grid
                              Thank you
                              • zaptaundefined
                                zapta @tcj
                                @tcj, I made the change. Can you give it another try?
                                https://github.com/zapta/misc/tree/master/duet3d_automesh
                                tcjundefined 1 Reply Last reply Reply Quote 0
                                • tcjundefined
                                  tcj @zapta
                                  @zapta thank you for the effort, but ist does not work yet
                                  only defining the default meshable area within the script (line 50) by
                                  default="-185:185,-185:185"
                                  works,
                                  but when adding
                                  <path to your python3> <path_to_the_duet3d_automesh.py file> --meshable "-185:185,-185:185"
                                  to the Post-processing script, it fails
                                  • zaptaundefined
                                    zapta @tcj
                                    @tcj, try this syntax for the flags (notice the '=')
                                    --meshable=-30:250,-3:280
                                    • tcjundefined
                                      tcj @zapta
                                      @zapta 👍 👏
                                      Thank you
                                      • DK90undefined
                                        DK90
                                        @zapta said in Cura Script to Automatically Probe Only Printed Area:
                                        Hello, i have the following error when i am trying to ad the postprocess
                                        can some one help me please?
                                        Thanks
                                        Post-processing script C:\Users\Dominic\AppData\Local\Programs\Python\Python36-32\python.exe C:\Program Files\Prusa3D\PrusaSlicer\duet3d_automesh.py file on file D:\2_Projekte\3D Druck\2_Modelle\28_R2D2_Did3D\R2D2_Did3D_SW_FullPack_h\STL_Final\zumdruckenbereit\Cube_PLA_Center foot_0.2mm_PET_2h24m.gcode failed.
                                        Error code: 2
                                        • tcjundefined
                                          tcj @DK90
                                          @DK90 the space in "Program Files" leads to this error
                                          change it to
                                          C:\Users\Dominic\AppData\Local\Programs\Python\Python36-32\python.exe "C:\Program Files\Prusa3D\PrusaSlicer\duet3d_automesh.py"
                                          notice the "
                                          DK90undefined 1 Reply Last reply Reply Quote 1
                                          • DK90undefined
                                            DK90 @tcj
                                            @tcj said in Cura Script to Automatically Probe Only Printed Area:
                                            Oh 🙂 thank you now ot works 🙂
                                            but wehn i start the print, there is now mesh leveling ....
                                            where is my error?
                                            Start G-Code
                                            M83  ; extruder relative mode
                                            M140 S[first_layer_bed_temperature] ; set bed temp
                                            M190 S[first_layer_bed_temperature] ; wait for bed temp
                                            ; For automesh
                                                 M557 TBD  ; parameters will be set automatically
                                                 G28  ;home
                                                 ;G29 S1 P"heightmap.csv"; Hoehenkarte Laden
                                            M109 S[first_layer_temperature] ; wait for extruder temp
                                            ; Reinigungs Fahrt
                                            G1 X-3.0 Y-10 F1500.0 ; go outside print area
                                            G92 E0.0
                                            G1 Z0
                                            G1 E8 ; Purge Bubble
                                            G1 X60.0 E9.0  F1000.0 ; intro line
                                            G1 X100.0 E12.5  F1000.0 ; intro line
                                            G92 E0.0
                                            G-Code layer change setting
                                            ; Automesh: begin layer [layer_num]
