    Cura Script to Automatically Probe Only Printed Area
    60
    7.7k
    • Luke'sLaboratoryundefined
      Luke'sLaboratory
      Alright - I've made an improvement to the script, I have an extra-large machine and depending on how much of the bed I'm using at any given point, I can exceed the points-per-axis limitations of duet firmware (currently 21:21). It now will run the calculations, and if there are more than 21 points required, it converts over to using the P parameter instead of the S parameter, trying to honor the original requested spacing.
      #!/usr/bin/python
      	Slic3r post-processing script for RepRap firmware printers which dynamically defines the mesh grid dimensions (M557) based on the print dimensions.
      {1}
      Usage:
      {1}
      	Slic3r Settings:
      	In Print Settings > Output Options
      	1. turn no "Verbose G-code"
      	2. in "Post-processing scripts" type the full path to python and the full path to this script
      	e.g. <Python Path>\python.exe  <Script Path>\meshcalc.py;
      {1}
      	In Printer Settings > Custom G-code > Start G-code
      	Make sure the start g-code contains the M557 command, and that you probe the bed and load the compensation map,  e.g.
      	M557 X10:290 Y10:290 S20	; Setup default grid
      	G29							; Mesh bed probe
      	G29 S1						; Load compensation map
      	Script Settings
      	probeSpacing = 20 - change this to the preferred probe point spacing in M557
      	Note: The minimum X and Y of the probed area is limited to 2 times the probeSpacing.
      	This is so that prints with a small footprint will have a minimum 3x3 probe mesh
      {1}
      Args:
      {1}
      	Path: The path parameter will be provided by Slic3r.
      {1}
      Requirements:
      {1}
      	The latest version of Python.
      	Note that I use this on windows and haven't tried it on any other platform.
      	Also this script assumes that the bed origin (0,0) is NOT the centre of the bed. Go ahead and modify this script as required.
      {1}
      Credit:
      {1}
      	Based on code originally posted by CCS86 on https://forum.duet3d.com/topic/15302/cura-script-to-automatically-probe-only-printed-area?_=1587348242875.
      	and maybe 90% or more is code posted by MWOLTER on the same thread.
      	Thank you both.
      import sys
      import re
      import math
      import os
      probeSpacing = 20   		# set your required probe point spacing for M557
      def main(fname):
      	print("Starting Mesh Calculations")
      	try:
      		_Slic3rFile = open(fname, encoding='utf-8')
      	except TypeError:
      		try:
      			_Slic3rFile = open(fname)
      		except:
      			print("Open file exception. Exiting.")
      			error()
      	except FileNotFoundError:
      		print('File not found. Exiting.')
      		error()
      	lines = _Slic3rFile.readlines()
      	_Slic3rFile.close()
      	linesNew = calcBed(lines)
      	_Slic3rFile = open(fname, "r+")
      	_Slic3rFile.seek(0)
      	_Slic3rFile.truncate()
      	for element in linesNew:
      		_Slic3rFile.write(element)
      	_Slic3rFile.close()
      	return
      def error():
      	# remove the next 2 lines to close console automatically
      	print("Press Enter to close")
      	input()
      	sys.exit()
      def calcBed(lines):
      	bounds = findBounds(lines)
      	bed = findBed()
      	for axis in bounds:
      		if bounds[axis]['max'] - bounds[axis]['min'] < bed[axis]:
      			print(f'Success: {axis} mesh is smaller than bed')
      		else:
      			print('Error: Mesh is larger than bed. Exiting.')
      			error()
      		for limit in bounds[axis]:
      			if limit == 'min':
      				if (bed[axis]) - bounds[axis][limit] > 0:
      					print(f'Success: {axis} {limit} coordinate is on the bed.')
      				else:
      					print(f'Error: {axis} {limit} coordinate is off the bed. Exiting.')
      					error()
      			if limit == 'max':
      				else:
      					error()
      	return fillGrid(bounds, lines)
      def findBed():
      	bed = {
      		'X': 0,
      		'Y': 0,
      	bedCorners = os.environ.get("SLIC3R_BED_SHAPE")
      	maxXY = bedCorners.split(',')[2].split('x')
      	bed['X'] = int(maxXY[0])
      	bed['Y'] = int(maxXY[1])
      	print(bed)
      	return bed
      def findBounds(lines):
      	bounds = {
      		'X': {'min': 9999, 'max': 0},
      		'Y': {'min': 9999, 'max': 0},
      	parsing = False
      	for line in lines:
      		if "move to next layer (0)" in line:
      			parsing = True
      			continue
      		elif "move to next layer (1)" in line:
      			break
      		if parsing:
      			# Get coordinates on this line
      			for match in re.findall(r'([YX])([\d.]+)\s', line):
      				# Get axis letter
      				axis = match[0]
      				# Skip axes we don't care about
      				if axis not in bounds:
      					continue
      				# Parse parameter value
      				value = float(match[1])
      				# Update bounds
      				bounds[axis]['min'] = math.floor(min(bounds[axis]['min'], value))
      				bounds[axis]['max'] = math.ceil(max(bounds[axis]['max'], value))
      	# make sure the bounds are at least 2 x Probe Point Spacing, for small prints.
          # also, make sure that the maximum amount of points isn't exceeded.
      	if parsing:
      		global probeSpacing
      		for axis in bounds:
      			spacing = (bounds[axis]['max'] - bounds[axis]['min'])/2
      			if spacing < probeSpacing:
      				probeSpacing = spacing
      	print("Bounds are: " + str(bounds))
      	return bounds
      def fillGrid(bounds, lines):
          #Check the quantity of points - cannot exceed 21points per axis, otherwise will throw error and ruin print by not running a mesh
          X_points=(bounds['X']['max']-bounds['X']['min'])/probeSpacing
          Y_points=(bounds['Y']['max']-bounds['Y']['min'])/probeSpacing
          if X_points>21 or Y_points>21:
           Points=True
      	 #basically, if its over 21, just use 21, if not, round up, keeping roughly the same spacing for the non-affected axis
           if X_points>21: X_points = 21
           else: X_points = math.ceil(X_points)
           if Y_points>21: Y_points=21
           else:Y_points = math.ceil(Y_points)
           print('With your required print footprint, you\'ll exceed 21 points on either axis, changing to point based. Your new point grid is {}:{} points'.format(X_points,Y_points))
          else:
           Points=False
          if Points == True:
              # Fill in the level command template
              gridNew = 'M557 X{}:{} Y{}:{} P{}:{}'.format(bounds['X']['min'], bounds['X']['max'],bounds['Y']['min'], bounds['Y']['max'], X_points, Y_points)
          else:
      	    gridNew = 'M557 X{}:{} Y{}:{} S{}'.format(bounds['X']['min'], bounds['X']['max'],bounds['Y']['min'], bounds['Y']['max'], probeSpacing)
      	# Replace M557 command in GCODE
          linesNew = []
          for line in lines:
              if line.startswith('M557'):
                  linesNew.append(re.sub(r'^M557 X\d+:\d+ Y\d+:\d+ S\d+', gridNew, line, flags=re.MULTILINE))
                  print('New M557: ' + linesNew[-1])
              else:
                  linesNew.append(line)
          return linesNew
      if __name__ == '__main__':
      	if sys.argv[1]:
      		main(fname = sys.argv[1])
      	else:
      		print('Error: Proper Slic3r post processing command is python3')
      		error()
      Luke
      http://lukeslab.online
      zaptaundefined 1 Reply Last reply Reply Quote 1
      • Baenwortundefined
        Baenwort
        Does this work for Deltas who don't have their M557 as a x and y coordinate?
        insertnamehereundefined 1 Reply Last reply Reply Quote 0
        • insertnamehereundefined
          insertnamehere @Baenwort
          @Baenwort said in Cura Script to Automatically Probe Only Printed Area:
          No it won't. But it could be modified.
          Baenwortundefined 1 Reply Last reply Reply Quote 0
          • zaptaundefined
            zapta @Luke'sLaboratory
            @Luke-sLaboratory said in Cura Script to Automatically Probe Only Printed Area:
            Do we need to add to the prusaslicer gcode settings generation of layer markers or is there a setting to have it enabled automatically.
            • zaptaundefined
              zapta @zapta
              I setup my prusaslicer to use this script and it works very well. I looked for some time for per-print mesh automation and this one does the job. Thanks for sharing it.
              The file version I am using is in the github link below. It uses utility classes to handle intervals and rectangles but otherwise it's the same flow. There are still a few TODOs but I am using it with my regular prints.
              https://github.com/zapta/misc/blob/master/duet3d_automesh/duet3d_automesh.py
              • Baenwortundefined
                Baenwort @insertnamehere
                @insertnamehere
                It would be great!
                • zaptaundefined
                  zapta @Baenwort
                  I cleaned up the python script. It now has command line flags that allow customization (set them in the slicer post processing command line).
                  I am very happy with the per-print quick partial meshing, getting good first layer without worrying about leveling. Ideally the slicers would provide the first layer's bounding box as place holders we can embed in gcode.
                  tcjundefined 1 Reply Last reply Reply Quote 1
                  • tcjundefined
                    tcj @zapta
                    @zapta could you please change the script that it can handle negative coordinates in --meshable ?
                    This will make it usable for Delta printers, because
                    "For Cartesian printers, specify minimum and maximum X and Y values to probe and the probing interval. For Delta printers, specify the probing radius. If you define both, the probing area will be the intersection of the rectangular area and the circle. "
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M557_Set_Z_probe_point_or_define_probing_grid
                    Thank you
                    • zaptaundefined
                      zapta @tcj
                      @tcj, I made the change. Can you give it another try?
                      https://github.com/zapta/misc/tree/master/duet3d_automesh
                      tcjundefined 1 Reply Last reply Reply Quote 0
                      • tcjundefined
                        tcj @zapta
                        @zapta thank you for the effort, but ist does not work yet
                        only defining the default meshable area within the script (line 50) by
                        default="-185:185,-185:185"
                        works,
                        but when adding
                        <path to your python3> <path_to_the_duet3d_automesh.py file> --meshable "-185:185,-185:185"
                        to the Post-processing script, it fails
                        • zaptaundefined
                          zapta @tcj
                          @tcj, try this syntax for the flags (notice the '=')
                          --meshable=-30:250,-3:280
                          • tcjundefined
                            tcj @zapta
                            @zapta 👍 👏
                            Thank you
                            • DK90undefined
                              DK90
                              @zapta said in Cura Script to Automatically Probe Only Printed Area:
                              Hello, i have the following error when i am trying to ad the postprocess
                              can some one help me please?
                              Thanks
                              Post-processing script C:\Users\Dominic\AppData\Local\Programs\Python\Python36-32\python.exe C:\Program Files\Prusa3D\PrusaSlicer\duet3d_automesh.py file on file D:\2_Projekte\3D Druck\2_Modelle\28_R2D2_Did3D\R2D2_Did3D_SW_FullPack_h\STL_Final\zumdruckenbereit\Cube_PLA_Center foot_0.2mm_PET_2h24m.gcode failed.
                              Error code: 2
                              • tcjundefined
                                tcj @DK90
                                @DK90 the space in "Program Files" leads to this error
                                change it to
                                C:\Users\Dominic\AppData\Local\Programs\Python\Python36-32\python.exe "C:\Program Files\Prusa3D\PrusaSlicer\duet3d_automesh.py"
                                notice the "
                                DK90undefined 1 Reply Last reply Reply Quote 1
                                • DK90undefined
                                  DK90 @tcj
                                  @tcj said in Cura Script to Automatically Probe Only Printed Area:
                                  Oh 🙂 thank you now ot works 🙂
                                  but wehn i start the print, there is now mesh leveling ....
                                  where is my error?
                                  Start G-Code
                                  M83  ; extruder relative mode
                                  M140 S[first_layer_bed_temperature] ; set bed temp
                                  M190 S[first_layer_bed_temperature] ; wait for bed temp
                                  ; For automesh
                                       M557 TBD  ; parameters will be set automatically
                                       G28  ;home
                                       ;G29 S1 P"heightmap.csv"; Hoehenkarte Laden
                                  M109 S[first_layer_temperature] ; wait for extruder temp
                                  ; Reinigungs Fahrt
                                  G1 X-3.0 Y-10 F1500.0 ; go outside print area
                                  G92 E0.0
                                  G1 Z0
                                  G1 E8 ; Purge Bubble
                                  G1 X60.0 E9.0  F1000.0 ; intro line
                                  G1 X100.0 E12.5  F1000.0 ; intro line
                                  G92 E0.0
                                  G-Code layer change setting
                                  ; Automesh: begin layer [layer_num]
                                  • tcjundefined
                                    tcj @DK90
                                    @DK90 said in Cura Script to Automatically Probe Only Printed Area:
                                    and it never will without G29 😉
                                    this is a part of my start sequence
                                    M104 S[first_layer_temperature]
                                    M116; wait for temperatures to be reached
                                    ; For automesh
                                    G28 ; home
                                    G29 ; mesh
                                    • DK90undefined
                                      DK90
                                      oh 😄 yes that sounds good....that was my mistake...:D Thank you
                                      • zaptaundefined
                                        zapta @DK90
                                        @DK90, if you use panel due and prusaslicer (and maybe cura, didn't try), try to enable Support Remaining Time in the Printer Settings | General, tab. This will include M73 time markers in the gcode that which cause the post processing script to show remaining hours and minutes in the Standby fields of Panel Duet (ignore the '-' prefix).
                                        This time estimation is much more consistent than the ones provided by Duet.
                                        • DK90undefined
                                          DK90 @zapta
                                          @zapta Thank you for the info. I will try it. That sound good.
                                          • tcjundefined
                                            tcj
                                            @zapta I'm sorry to say that, but it does not work properly yet.
                                            The script gives
                                            M557 X-10:32 Y-10:32 P3:3
                                            where it should deliver
                                            M557 X-32:32 Y-32:32 P3:3
                                            for a testcube in the middle of the bed with some mm of skirt
                                            total dimensions +/- 21.xx mm
                                            OwenDundefined zaptaundefined 2 Replies Last reply Reply Quote 0
