    3.1.0 firmware reboots periodically
    1.7k
    • k3lagundefined
      k3lag @dc42
      @dc42 said in 3.1.0 firmware reboots periodically:
      You actually have two M575 P1 lines in config.g, of which the second is commented out. You need a M575 P1 command to support PanelDue even if you are using the ribbon cable.
      I missed the first one when I was checking to make sure I had one. That explains why it worked when I commented it out. 😊
      I'm in the middle of a print and so far so good.
      • Thaliosundefined
        Thalios
        Having same issue with my Duet 3. Will install the build linked and report back.
        My M122 reports:
        m122
        RepRapFirmware for Duet 3 MB6HC version 3.1.0 running on Duet 3 MB6HC v0.6 or 1.0
        Board ID: 08DJM-956L2-G43S4-6J9D0-3SD6Q-9U5GF
        Used output buffers: 1 of 40 (11 max)
        Static ram: 154804
        Dynamic ram: 163068 of which 44 recycled
        Exception stack ram used: 328
        Never used ram: 74972
        Tasks: NETWORK(ready,68) ETHERNET(blocked,436) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1452) TMC(blocked,204) MAIN(running,4520) IDLE(ready,76)
        Owned mutexes:
        Last reset 00:00:22 ago, cause: software
        Last software reset at 2020-05-16 13:30, reason: Stack overflow, spinning module GCodes, available RAM 74648 bytes (slot 0)
        Software reset code 0x4103 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0440f80e BFAR 0x00000000 SP 0x2045ffb4 Task NETW
        Stack: 204120c0 204120f4 00463465 00000000 20412228 0000000a ffffffff 00020021 00462a89 2041211c 20417e30
        Error status: 0
        MCU temperature: min 45.4, current 45.6, max 45.8
        Supply voltage: min 24.2, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
        12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
        Driver 0: standstill, reads 44331, writes 15 timeouts 0, SG min/max 0/0
        Driver 1: standstill, reads 44332, writes 15 timeouts 0, SG min/max 0/0
        Driver 2: standstill, reads 44333, writes 15 timeouts 0, SG min/max 0/0
        Driver 3: standstill, reads 44334, writes 14 timeouts 0, SG min/max 0/0
        Driver 4: standstill, reads 44338, writes 11 timeouts 0, SG min/max 0/0
        Driver 5: standstill, reads 44339, writes 11 timeouts 0, SG min/max 0/0
        Date/time: 2020-05-16 13:30:50
        Slowest loop: 5.78ms; fastest: 0.15ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 3.1ms, write time 0.0ms, max retries 0
        === MainDDARing ===
        === AuxDDARing ===
        Heater 1 is on, I-accum = 0.0
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Aux2 is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 4.94ms; fastest: 0.03ms
        HTTP sessions: 2 of 8
        - Ethernet -
        State: active
        Error counts: 0 0 0 0 0
        Socket states: 2 2 2 2 2 0 0 0
        === Filament sensors ===
        Extruder 0: pos -3.87, errs: frame 7 parity 0 ovrun 0 pol 0 ovdue 0
        === CAN ===
        Messages sent 88, longest wait 0ms for type 0
        === Linux interface ===
        State: 0, failed transfers: 0
        Last transfer: 22277ms ago
        RX/TX seq numbers: 0/1
        SPI underruns 0, overruns 0
        Number of disconnects: 0
        Buffer RX/TX: 0/0-0
        Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
        Heavily modified Ender 3 Pro (Duet 3 6HC)
        Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
        CR-10S Pro V2 (Duet 3 Mini 5+)
        and a bunch of SLA printers..
        • Thaliosundefined
          Thalios
          On first firmware upgrade to 3.1.0, it would reset every 30 sec to 1 minute. Now with the one from Dropbox, it has been stable for 10 minutes.
          Here's my config.g
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed Apr 29 2020 20:50:30 GMT-0400 (EDT)
          G90                                                ; send absolute coordinates...
          M83                                                ; ...but relative extruder moves
          M550 P"Ender 3 Pro"                                ; set printer name
          M918 P1 E4 F2000000                                ; configure direct-connect display
          M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
          M586 P0 S1                                         ; enable HTTP
          M586 P1 S0                                         ; disable FTP
          M586 P2 S0                                         ; disable Telnet
          M569 P0.0 S1 D3                                    ; physical drive 0.0 goes forwards
          M569 P0.1 S1 D3                                    ; physical drive 0.1 goes forwards
          M569 P0.2 S0 D3                                    ; physical drive 0.2 goes backwards
          M569 P0.3 S1                                       ; physical drive 0.3 goes forwards
          M584 X0.0 Y0.1 Z0.2 E0.3                           ; set drive mapping
          M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
          M92 X80.00 Y80.00 Z400.00 E141.32                  ; set steps per mm
          M566 X1200.00 Y1200.00 Z24.00 E300.00              ; set maximum instantaneous speed changes (mm/min)
          M203 X9000.00 Y9000.00 Z250.00 E6000.00            ; set maximum speeds (mm/min)
          M201 X300.00 Y300.00 Z200.00 E5000.00            ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E1000 I50                      ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                            ; Set idle timeout
          M208 X0 Y0 Z0 S1                                   ; set axis minima
          M208 X245 Y225 Z230 S0                             ; set axis maxima
          M574 X1 S1 P"io0.in"                               ; configure active-high endstop for low end on X via pin io0.in
          M574 Y1 S1 P"io1.in"                               ; configure active-high endstop for low end on Y via pin io1.in
          M574 Z1 S2			                               ; configure to use z-probe
          M558 P1 C"io6.in+io6.out" H2.5 F100 T9000          ; set Z probe type to unmodulated and the dive height + speeds
          G31 P500 X-22 Y4 Z1.30                             ; set Z probe trigger value, offset and trigger height
          M557 X30:195 Y25:200 P5                            ; define mesh grid
          M308 S0 P"temp1" Y"thermistor" T100000 B4092       ; configure sensor 0 as thermistor on pin temp1
          M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
          M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
          M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                            ; map heated bed to heater 0
          M308 S1 P"temp0" Y"thermistor" T100000 B4092       ; configure sensor 1 as thermistor on pin temp0
          M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
          M143 H1 S270                                       ; set temperature limit for heater 1 to 270C
          M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
          M950 F0 C"out8" Q500                               ; create fan 0 on pin out8 and set its frequency
          M106 P0 S1 H-1                                     ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"!out4" Q25000                             ; create fan 1 on pin out4 and set its frequency
          M106 P1 S1 H1 T45								   ; set fan 1 value. Thermostatic control is turned on
          M950 F2 C"!out6" Q25000							   ; create fan 2 on pin out6 and set its frequency
          M106 P2 S1 H1 T20                                  ; set fan 2 value. Thermostatic control is turned on
          M563 P0 D0 H1 F-1                                  ; define tool 0
          G10 P0 X-5 Y0 Z0                                   ; set tool 0 axis offsets
          G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
          ; Custom settings
          M591 D0 P5 C"io3.in" R25:130 E3 S1 A0              ; Enable and set Filament monitor
          T0                                                 ; select first tool
          M501                                               ; Load config overrides
            Thanks. When it has been running for a while, please run M122 and post the report here.
            • k3lagundefined
              k3lag
              Just completed a 1hr 42min print with no issues. Here is the M122 after the print:
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.0+ running on Duet WiFi 1.02 or later + DueX5
              Board ID: 08DGM-917DA-G4MSJ-6JKDJ-3S46L-TVPMB
              Used output buffers: 3 of 24 (18 max)
              Static ram: 28260
              Dynamic ram: 93992 of which 60 recycled
              Exception stack ram used: 544
              Never used ram: 8216
              Tasks: NETWORK(ready,92) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1640) IDLE(ready,80)
              Owned mutexes: WiFi(NETWORK)
              Last reset 01:49:28 ago, cause: software
              Last software reset at 2020-05-16 12:21, reason: User, spinning module GCodes, available RAM 8496 bytes (slot 3)
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
              Error status: 8
              MCU temperature: min 31.1, current 33.5, max 37.0
              Supply voltage: min 24.2, current 24.5, max 24.9, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: standstill, SG min/max 0/1023
              Driver 1: standstill, SG min/max 0/1023
              Driver 3: standstill, SG min/max 0/1023
              Driver 5: standstill, SG min/max 0/257
              Driver 6: standstill, SG min/max 0/272
              Driver 7: standstill, SG min/max 0/281
              Date/time: 2020-05-16 14:10:39
              Slowest loop: 82.69ms; fastest: 0.14ms
              === Storage ===
              SD card longest read time 1.7ms, write time 2.1ms, max retries 0
              Hiccups: 0(0), FreeDm: 169, MinFreeDm: 118, MaxWait: 290918ms
              === MainDDARing ===
              Scheduled moves: 47669, completed moves: 47669, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
              === AuxDDARing ===
              Heater 0 is on, I-accum = 0.0
              Heater 1 is on, I-accum = 0.4
              Segments left: 0
              === Network ===
              Slowest loop: 22.55ms; fastest: 0.00ms
              HTTP sessions: 1 of 8
              - WiFi -
              Network state is active
              WiFi firmware version 1.23
              WiFi MAC address ec:fa:bc:01:d6:19
              WiFi Vcc 3.43, reset reason Unknown
              WiFi flash size 4194304, free heap 20336
              WiFi IP address 192.168.1.16
              WiFi signal strength -30dBm, reconnections 0, sleep mode modem
              === DueX ===
              Read count 1, 0.01 reads/min
              Update: It's been another 2+ hours and no restarts. It seems happy now.
              • Thaliosundefined
                Thalios
                Same here, works great. 2h up time more or less, no more reboots.
                M122 results:
                m122
                RepRapFirmware for Duet 3 MB6HC version 3.1.0+ running on Duet 3 MB6HC v0.6 or 1.0
                Used output buffers: 3 of 40 (24 max)
                Static ram: 154884
                Never used ram: 74892
                Tasks: NETWORK(ready,84) ETHERNET(blocked,436) HEAT(blocked,1112) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1424) TMC(blocked,204) MAIN(running,4536) IDLE(ready,76)
                Owned mutexes:
                Last reset 01:54:43 ago, cause: power up
                Last software reset at 2020-05-16 15:58, reason: Stack overflow, spinning module Platform, available RAM 74648 bytes (slot 2)
                Software reset code 0x4100 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0443780e BFAR 0x00000000 SP 0x2045ffb4 Task NETW
                Stack: 204120c0 204120f4 00463465 00000000 00000000 204121f0 00000000 a0000000 00462a89 204120fc 20417e30
                Error status: 0
                MCU temperature: min 45.1, current 45.4, max 45.6
                Supply voltage: min 24.2, current 24.3, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
                Driver 0: standstill, reads 26432, writes 0 timeouts 0, SG min/max not available
                Driver 1: standstill, reads 26431, writes 0 timeouts 0, SG min/max not available
                Driver 2: standstill, reads 26432, writes 0 timeouts 0, SG min/max not available
                Driver 3: standstill, reads 26433, writes 0 timeouts 0, SG min/max not available
                Driver 4: standstill, reads 26432, writes 0 timeouts 0, SG min/max not available
                Driver 5: standstill, reads 26434, writes 0 timeouts 0, SG min/max not available
                Date/time: 2020-05-16 19:24:41
                Slowest loop: 6.87ms; fastest: 0.15ms
                === Storage ===
                SD card longest read time 3.4ms, write time 0.0ms, max retries 0
                === MainDDARing ===
                === AuxDDARing ===
                Segments left: 0
                === Network ===
                Slowest loop: 7.35ms; fastest: 0.03ms
                - Ethernet -
                State: active
                Extruder 0: pos 0.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                === CAN ===
                Messages sent 7589, longest wait 0ms for type 0
                Last transfer: 6883973ms ago
                Buffer RX/TX: 0/0-0
                • luckyflyerundefined
                  luckyflyer
                  When will the internal build be available for a pi update?
                  • FBGundefined
                    FBG
                    Happen me the same, After update from RC12, in the first print (around 16h) in the middle (around 60%) the firmware reset...
                    this is the M122:
                    m122
                    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.0 running on Duet Ethernet 1.02 or later
                    Board ID: 08DGM-917DA-G4MSD-6JTD8-3SS6M-K8S38
                    Used output buffers: 3 of 24 (11 max)
                    Static ram: 28180
                    Dynamic ram: 93332 of which 20 recycled
                    Exception stack ram used: 256
                    Never used ram: 9284
                    Tasks: NETWORK(ready,136) HEAT(blocked,1224) MAIN(running,1816) IDLE(ready,80)
                    Owned mutexes:
                    Last reset 07:35:56 ago, cause: software
                    Last software reset at 2020-05-17 00:23, reason: Stack overflow, spinning module none, available RAM 8896 bytes (slot 2)
                    Software reset code 0x4111 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80e BFAR 0xe000ed38 SP 0x2001ffb4 Task NETW
                    Stack: 20002860 20002894 00455625 00000000 20000000 200029b8 20002a55 a0000000 00454c35 200028c4 200055f4
                    Error status: 0
                    MCU temperature: min 23.2, current 23.7, max 38.9
                    Supply voltage: min 23.8, current 23.9, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                    Slowest loop: 6.71ms; fastest: 0.12ms
                    === Storage ===
                    SD card longest read time 2.0ms, write time 0.0ms, max retries 0
                    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                    === MainDDARing ===
                    === AuxDDARing ===
                    Segments left: 0
                    === Network ===
                    Slowest loop: 5.53ms; fastest: 0.02ms
                    Interface state active, link 100Mbps full duplex
                    Extruder 0 sensor: ok
                    Extruder 1 sensor: ok
                    I go to install the new version of dropbox and i will comment...
                    Best Regards
                    • FBGundefined
                      FBG
                      Sorry again, inside the link of dropbox i see the file Duet2Conbinedfirmware.bin, and also show 3.1.0 folder, inside this folder also the file Duet2Conbinedfirmware.bin.
                      Which i must use?
                      • Thaliosundefined
                        Thalios
                        the file directly in the main folder, not the one in the sub folder. Version should show 3.1.0+ when you do M122
                        FBGundefined 1 Reply Last reply Reply Quote 0
                        • FBGundefined
                          FBG @Thalios
                          @Thalios thank you, testing...
                            dc42 administrators @luckyflyer
                            @luckyflyer said in 3.1.0 firmware reboots periodically:
                            We'll do an 3.1.1 release within the next few days. Meanwhile you can install the new binary the old way, i.e. upload it through DWC.
                              Unfortunately I have been unable to reproduce the original problem, or identify what it is in config.g that causes the network task to use more stack than on my test machines.
                              Therefore, please can any of you who were experiencing this issue install the candidate RRF 3.1.1 binary from https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0, check that the issue remains resolved, and report the network task free stack from the M122 report after it has been running for a while. The network task free stack is this bit:
                              I suspect that a good way to reproduce the original fault quickly may be to set the printer doing something that causes motion (e.g. homing) and refresh the browser tab several times while it is doing that.
                              PS - please check the the build date you are using ends with 18b6.
                              • Thaliosundefined
                                Thalios
                                Installing. Will report back.
                                • Thaliosundefined
                                  Thalios
                                  Problem is back it seems.
                                  M122 result:
                                  M122
                                  RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0
                                  Used output buffers: 1 of 40 (24 max)
                                  Static ram: 154524
                                  Dynamic ram: 163148 of which 44 recycled
                                  Exception stack ram used: 560
                                  Never used ram: 74940
                                  Tasks: NETWORK(ready,148) ETHERNET(blocked,436) HEAT(blocked,1112) CanReceiv(suspended,3820) CanSender(suspended,1420) CanClock(blocked,1424) TMC(blocked,68) MAIN(running,4464) IDLE(ready,76)
                                  Owned mutexes:
                                  Last reset 00:45:42 ago, cause: software
                                  Error status: 0
                                  MCU temperature: min 47.0, current 47.3, max 47.5
                                  Supply voltage: min 24.0, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                                  Driver 0: ok, reads 48824, writes 0 timeouts 0, SG min/max 0/277
                                  Driver 1: ok, reads 48825, writes 0 timeouts 0, SG min/max 0/1017
                                  Driver 2: standstill, reads 48825, writes 0 timeouts 0, SG min/max 0/0
                                  Driver 3: ok, reads 48826, writes 0 timeouts 0, SG min/max 0/969
                                  Driver 4: standstill, reads 48825, writes 0 timeouts 0, SG min/max not available
                                  Driver 5: standstill, reads 48826, writes 0 timeouts 0, SG min/max not available
                                  Date/time: 2020-05-18 12:51:28
                                  Slowest loop: 6.49ms; fastest: 0.15ms
                                  === Storage ===
                                  Free file entries: 9
                                  SD card longest read time 3.3ms, write time 0.0ms, max retries 0
                                  Hiccups: 0(0), FreeDm: 370, MinFreeDm: 303, MaxWait: 0ms
                                  === MainDDARing ===
                                  Scheduled moves: 31056, completed moves: 31009, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: 3
                                  === AuxDDARing ===
                                  Heater 0 is on, I-accum = 0.6
                                  Segments left: 1
                                  === Network ===
                                  Slowest loop: 6.90ms; fastest: 0.03ms
                                  - Ethernet -
                                  State: active
                                  Extruder 0: pos -7.73, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                                  === CAN ===
                                  Messages sent 315, longest wait 0ms for type 0
                                  Last transfer: 2742318ms ago
                                  Buffer RX/TX: 0/0-0
                                  I've been printing 2x 30 minutes jobs without hiccups, but it has reset on its own before i printed.
                                  version is 18b6 in machine-specific tab in DWC
                                    @Thalios, thank you very much for testing this.
                                    I've put a further build (18b7) of RRF3 for Duet 3 at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0. Please try that one, and if it works post the M122 report after it has run for a while, preferably after it has been printing with DWC 3.1.0 connected.
                                    I still have no idea why your configuration uses so much more network stack than mine. The config.g file on my Duet 3 controlled tool changer is much more complex than yours.
                                    • Thaliosundefined
                                      Thalios
                                      Will do. Printing a 2h print at the moment though so it'll be right after.
                                      • Thaliosundefined
                                        Thalios
                                        One weird thing though, it did it right after the firmware upgrade, but hasn't since it seems.
                                        m122
                                        Static ram: 154524
                                        Exception stack ram used: 568
                                        Never used ram: 74932
                                        Owned mutexes:
                                        Last reset 01:30:48 ago, cause: software
                                        Error status: 0
                                        MCU temperature: min 45.6, current 47.4, max 47.4
                                        Supply voltage: min 24.0, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                                        Driver 0: ok, reads 28162, writes 8 timeouts 0, SG min/max 0/976
                                        Driver 1: ok, reads 28161, writes 8 timeouts 0, SG min/max 0/332
                                        Driver 2: ok, reads 28163, writes 8 timeouts 0, SG min/max 0/140
                                        Driver 3: ok, reads 28166, writes 4 timeouts 0, SG min/max 0/1023
                                        Driver 4: standstill, reads 28170, writes 0 timeouts 0, SG min/max not available
                                        Driver 5: standstill, reads 28170, writes 0 timeouts 0, SG min/max not available
                                        Date/time: 2020-05-18 13:36:34
                                        Slowest loop: 113.03ms; fastest: 0.15ms
                                        === Storage ===
                                        SD card longest read time 3.5ms, write time 40.0ms, max retries 0
                                        Hiccups: 0(0), FreeDm: 351, MinFreeDm: 301, MaxWait: 846322ms
                                        === MainDDARing ===
                                        Scheduled moves: 7273, completed moves: 7214, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: 3
                                        === AuxDDARing ===
                                        Heater 0 is on, I-accum = 0.2
                                        Segments left: 0
                                        File is doing "G1 X104.142 Y97.383 E0.00889" in state(s) 0
                                        === Network ===
                                        Slowest loop: 40.45ms; fastest: 0.03ms
                                        - Ethernet -
                                        State: active
                                        Extruder 0: pos 4.70, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                                        === CAN ===
                                        Messages sent 5662, longest wait 0ms for type 0
                                        Last transfer: 5448813ms ago
                                        Buffer RX/TX: 0/0-0
                                          What's most noticeable to me in that report is that it gives the Network task stack remaining (when the M122 report was run, not when the reboot occurred) as 148 bytes. Whereas with that firmware version, the lowest I had was 212 bytes.
                                          • Thaliosundefined
                                            Thalios
                                            I'm running in standalone. Does that help?
