    Reprap G-Code syntax now part of RJ TextEd text editor
    1.1k
    • OwenDundefined
      OwenD
      Just a note to advise that the creator of RJ TextEd has added the Reprap G-Code syntax files I created to the main program. (I am not affiliated in any way, I just happen to use it).
      RJ Text Ed
      So as of version 14.41 you can go to the new document drop-down list and select Reprap G-Code
      I've tried to make auto-completion as complete and useful (to newbies) as possible by having G-Codes the object model and the correct syntax for if-else blocks etc. by also having links to the dozuki help section for that code and giving an empty if/else block etc.
      Obviously this part will have to be updated as the object model develops.
      Also I'm not used to languages which use indenting for flow control (Mainly use delphi/pascal), so can't guarantee a mistake free implementation.
      • chas2706undefined
        chas2706
        @OwenD said in Reprap G-Code syntax now part of RJ TextEd text editor:
        RJ Text Ed
        Just downloaded version 14.41 and RepRap G-Code is NOT in the dropdown list.
        • OwenDundefined
          OwenD
          EDIT:
          My mistake.
          Just did a full uninstall/reinstall.
          It seems the syntax file is not in the 14.41 download, but IS in the update file.
          The link is just below the main download.
          You THEN have to go to
          Environment >> Add-ons and select it in the list of active highlighters
          • OwenDundefined
            OwenD
            You also need to go into the options and enable whatever auto completion and html link following options etc you want.
            That is to say RTFM 🤘
            • chas2706undefined
              chas2706
              EDIT:
              My mistake.
              Got it Thanks.
              • OwenDundefined
                OwenD
                I have added some new object model items to the code completion syntax file and also added mouse-over hints for most GCode commands and object model functions.
                Requires RJ Texted version 14.5 beta 1 or later for hints to work!
                Updated syntax file is here
                Some video here
                Screen shots
                mod() code completion
                Mod() hint mouse-over
                • OwenDundefined
                  OwenD
                  I have updated the syntax file for RJ TextEd to include more object model items.
                  I have also included a suggested colour format file.
                  You will need to update RJ TextEd to the latest version in order to take advantage of hints etc.
                  Download here
                  Replace the existing files (reprap.syx, reprap.ini) in C:\Users"yourname"\AppData\Roaming\RJ TextEd\Syntax
                  Copy the file "Reprap Dark.xml" to C:\Users"yourname"\AppData\Roaming\RJ TextEd\Syntax color themes\
                  To install.
                  1: Go to ENVIRONMENT > THEMES > CUSTOMISE
                  2: Select "Reprap G Code" from the drop down list of highlighters
                  3: Click the button, and select import colors from file
                  4: Select the "Reprap Dark.xml" file previously copied.
                  You can customize the colours to suit yourself.
                  Different G Code parameters such as X, Y, Z , E, F, G etc can be coloured to make individually.
                  Likewise, comments and other items can be individually coloured.
                  1 Reply Last reply Reply Quote 4
                  • OwenDundefined
                    OwenD
                    I'm not sure that the Reprap Firmware syntax file I created is being installed by default anymore.
                    I think it was changing too rapidly.
                    Anyway, I have just uploaded the latest version of the syntax file if anyone is using it.
                    Download from the RJ TextEd forum
                    https://www.rj-texted.se/Forum/viewtopic.php?f=4&t=4813
                    or from my google drive
                    https://drive.google.com/file/d/1D-rgpotqU647yfLAryguhP6uK8KHwBcY/view?usp=sharing
                    • OwenDundefined OwenD referenced this topic
                    • fcwiltundefined fcwilt referenced this topic
                    • OwenDundefined
                      OwenD
                      I have updated the syntax files to include the new G Codes introduced in RRF 3.4.x
                      I have also updated the hyperlinks to point to the new docs pages.
                      Download here
                      https://www.rj-texted.se/Forum/viewtopic.php?p=18275#p18275
                      tom33undefined 1 Reply Last reply Reply Quote 0
                      • tom33undefined
                        tom33 @OwenD
                        @OwenD is it possible to use it with visual studio code ?
                        OwenDundefined 1 Reply Last reply Reply Quote 0
                        • OwenDundefined
                          OwenD @tom33
                          @tom33 said in Reprap G-Code syntax now part of RJ TextEd text editor:
                          No, I wouldn't think so.
                          Each editor seems to have their own format for the syntax highlighting files.
                          There is at least one GCode syntax extension for VS Code
                          You could create your own
                          https://code.visualstudio.com/api/language-extensions/syntax-highlight-guide
                          I note that it uses the same format as YAML
