Why I went back to RRF2
Example setups and prints
12
27
2.2k
    @CaLviNx said in Why I went back to RRF2:
    I updated multiple Duet-2 Wifi boards and couldnt get prints to complete
    In what way did the prints not complete? Did the Duet reset (in which case, did you run M122 to get the reason); or did the extruder jam; or something else?
    ? 1 Reply Last reply 19 May 2020, 22:44 Reply Quote 0
      CCS86
      You sound much more interested in convincing everyone that "you did the right thing" in reverting to RRF2, than in fixing the issue you ran into.
      Maybe it's a bug. But, more likely, it is a mistake that you made.
      Instead of telling us how everything you did was perfect, like Trump; post both config files and stop snapping at everyone who is spending their time trying to help you.
      undefined ? undefined 3 Replies Last reply 19 May 2020, 21:38 Reply Quote 5
        zapta @CCS86
        @CCS86 said in Why I went back to RRF2:
        ... stop snapping at everyone who is spending their time trying to help
        I don't think the OP asked for help. Read his post.
        undefined 1 Reply Last reply 19 May 2020, 21:48 Reply Quote 0
          CCS86 @zapta
          @zapta said in Why I went back to RRF2:
          Yup, I read his post. Check out sentence #1 of my post; I covered that.
          This is a forum for people to help each other and share ideas. I really doubt if anyone cares about his justifications for giving up almost immediately. But, a bunch of people cared enough to help him fix the actual problem.
          This category specifically is for example prints. This isn't an "example" of how prints come out with RRF3. It is a configuration error, or bug. Both can be fixed with some participation.
            zapta @A Former User
            @CaLviNx, FYI, according to this thread, in a month or so it will be easier to switch to V3.
            https://forum.duet3d.com/topic/16326/its-safe-to-move-a-duet-v2-to-firmware-3-x/5?_=1589924880315
              DaveA
              I moved two printers from 2 to 3.1.1. A delta and a cartesian and had no substantial problems without using the configuration software. I don't think I can see any difference between a part printed in RRF2 versus one printed in 3. I certainly don't see any reason to move back to 2.
              ? 1 Reply Last reply 19 May 2020, 22:23 Reply Quote 0
                A Former User @CCS86
                This post is deleted!
                  A Former User @DaveA
                  @DaveA said in Why I went back to RRF2:
                  I think you need to look at this exact forum others have reported issues, and even to the point where they are posting they are reverting back to older firmware. And i think if you look even harder there are actual instances for the duet team advising people to revert back.......
                    luckyflyer @CCS86
                    Why must we get political?? This is the Duet forum not facebook.
                    undefined 1 Reply Last reply 19 May 2020, 22:41 Reply Quote 2
                      CCS86 @luckyflyer
                      @luckyflyer said in Why I went back to RRF2:
                      What is political about that? I made reference to a human being who constantly tells the world about how perfect he is, and blaming everything besides himself for any shortcomings. I'm talking about character, not political policy.
                      "what did I mess up", " what could I have done better" are the types of questions we should ask ourselves, if we want to be better makers.
                      undefined 1 Reply Last reply 19 May 2020, 23:19 Reply Quote -1
                        A Former User @dc42
                        @dc42 said in Why I went back to RRF2:
                        What happened in every other case apart from the print I showed, is that at various random times the print head would try to dive itself back into the print which would lead to the the z axis complaining and me hitting the emergency stop button, So I didn't even consider doing a M122. The one time I did do a M122 the only info I got is that the board reset with no reason given.
                        And as someone noticed the Y axis steps/mm didnt seem to be correct this I played with and didnt get any resolution with some odd number of steps being required to get it anywhere near correct but then on another print the steps/mm value would require to be changed again
                        In the beginning I was not thinking it was a firmware issue (I was convinced it was dodgy SD cards) coming to the conclusion that the firmware could be an issue issue was the LAST step.
                        The work you and the core guys here do is sterling, and as I tried to allude to in my initial post this is not a bash RRF3 firmware or Duet3d in any way (no matter how much some of the little girls in here seem to have gotten their panties in a bunch) I have a total of 18 duet equipped machines, I will only ever fit Duet and NOTHING else.
                        And For clarity, the test printer in question (an Anycubic Chiron) has had a duet 2 wifi installed for nearly 2 years and after its initial setup it has been a "press print & forget it" machine for all of that time on RRF2.
                          zapta @CCS86
                          You may intended to discuss Trump's character but instead you revealed yours.
                          undefined 1 Reply Last reply 19 May 2020, 23:52 Reply Quote 3
                            CCS86 @zapta
                            If you get offended that easily, I wish you the best of luck, sir.
                            1 Reply Last reply Reply Quote -1
                              jens55
                              Moderators .... could we please lock this thread and stop with the negativity please ?
                              undefined 1 Reply Last reply 20 May 2020, 02:48 Reply Quote 3
                                Phaedrux Moderator @jens55
                                @jens55 said in Why I went back to RRF2:
                                Yikes. Consider it locked! I take a day to do some yard work and y'all turn to hooliganism!
                                1 Reply Last reply Reply Quote 7
                                22 out of 27
