    Print abberation input requested
    854
      Thin wall settings. Print speed. Extrusion width, layer height. Just trying to get a full picture of what's going on.
      • jens55undefined
        jens55 @giostark
        @giostark, thanks for that. I had noticed the x shift but figured it not to be a big deal.
        What gets me is the randomness of the fault with the same model.
        • jens55undefined
          jens55 @Phaedrux
          @Phaedrux, I have exported the project and the file is attached. This version, with the wider clearance between objects, did not produce the aberations but it's the same as the closer spaced version that did show the faults. .3mf extension was changed to .txt extension for upload.
          CFFFP_karen-ink pad storage v11.txt
          • jens55undefined
            jens55
            Tried upgrading to 3.1.0 but things are broken now. Until that is sorted, I can not try out different things 😞
            • jens55undefined
              jens55 @jens55
              Finally got RRF3.1.1 going. It still hung initially but reverting to DWC1 and running the upgrade from there worked !
                I downloaded your 3mf but it looks like it just included the model, but not the print settings.
                • jens55undefined
                  jens55
                  Hmmm .... I had the model loaded and just exported the whole thing. Didn't even know that there is a way to NOT export all the settings at the same time.
                  Any suggestion what I might be doing wrong?
                    Not sure. Normally the settings go right along with it.
                    How bout a sliced gcode file, most of the settings are usually appended.
                    • jens55undefined
                      jens55
                      Could it have been related to the fact that I changed te file extension frm .3mf (or whatever) to .txt ?
                      I assume you changed it back to look at it ....
                      I have changed the model a bit with fillets and currently, printing one at a time, I do not see the previous faults. I have not yet printed this as a multiple model print close together (which is when the earlier problems arose)
                      Do you want the .3mf file anyway or should I wait until I can reproduce the issue with the current model ? Do you want the sliced gcode file anyway or wait ?
                        Oddly when I saved it, it chose .zip as the extension. I renamed it to .3mf. That kind of makes sense though, since .3mf is also a zipped archive, so it must have detected the mimi type or something.
                        Regardless. If you share the 3mf again or the gcode or a screen shot or text description of the settings I'll take a look at it, but if it's not happening on a single object I'm thinking it has less to do with settings, but who knows.
                        • jens55undefined
                          jens55
                          It sure is a weird thing ... and I have no clue why this could be happening. In any case, by tomorrow I will print two at a time and see what happens.
                          Thanks for trying to help!
                            If you do get the defects when printing two together capture an M122 as well.
                            • jens55undefined
                              jens55
                              Will do - thanks!
                              • jens55undefined
                                jens55
                                I got some aberation on a single print and am now doing a three models at once print.
                                M122 of the one model print:
                                m122 may21.txt
                                Project file of 3 model print as being printed right now (same settings as the one model print)
                                Note that I have increased bed temperature to fairly high 80C and reduced layer height from 0.3 mm to 0.2 mm with a 0.4 mm nozzle.
                                  Photo of the fault?
                                    I was able to get this 3mf to load in cura 4.6.1 but it didn't select the print profile though it did load them. Which profile are you using?
                                    Also, Cura gave a warning that the model is not water tight. This can lead to all sorts of crazy things. So I suggest running the model through Netfabb online if you have an autodesk account: https://service.netfabb.com/login.php
                                    • jens55undefined
                                      jens55
                                      Issues are same as before but here is a new picture (although not quite as clear)
                                      Profile is "Duet-PLA on glass,volcano,0.8 mm" .... doesn't make any sense whatsoever that it would not select the right ptofile. Makes the exported project useless.
                                      I never had Cura report anything being non-watertight but am not exactly surprised. These non-watertight sections are likely only on the first layer as I had (and still have) problems with the interlinking protrusions of the model.
                                      It's kinda hard to see but here is one interlink section:
                                      What you don't see is that there is a gap that is 5 mm tall between the interlock and the main body of the model. The previous/lower model slides into that gap when stacking vertically. For some reason this fails very often in the print so I added some attaching wings that are 0.3 mm tall but they are kinda afterthoughts and likely would cause the error (although I have not seen it)
                                      The first 5 mm of the attachment section is also very weak and breaks off easily. The print is rougher than the remaining section which is part of the main model. You can see a bit of that roughness if you magnify the picture. I suspect a pressure advance issue but it's very frustrating and a single print takes 5 hours !
                                      • jens55undefined
                                        jens55
                                        It is possible that the issues with the profile and even the 'not watertight' are caused by us using different versions of Cura. I am using the 'Master' branch whereas you are using the 'official' Cura release.
                                          I'll try with the master branch.
                                            Still complains about being not water tight, and no profiles actually came across.
