    Brand new Paneldue 7 not connecting (RRF3)
    PanelDue
    • toufou54undefined
      toufou54
      Hi, I've just received my first Duet 2 Ethernet with Panel 7" yesterday, I'm a little be confused about a lot of missing feature like notifications and a real user friendly Web GUI, but the worse things is this panel with old school graphics which apparently not working (I can see with an oscilloscope that it send 3.3v data and when a want to test RX the signal is very weird with a lot of parasites).
      So no effects on any action on the panel, and no data from the duet (all temperatures stays at 0)
      Maybe an issue with RRF3 ? (I hope otherwise it seems that panel and/or this duet board will not have a great future...)
        A Former User @toufou54
        @toufou54 said in Brand new Paneldue 7 not connecting (RRF3):
        the indicator to look for is top right corner where it says connecting / idle / etc.
        in any case, as of 3.1.0 you need to enable the PanelDue port, do you have M575 P1 S1 B57600 in your config.g? ref https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md#reprapfirmware-310
        • toufou54undefined
          toufou54
          Thanks, that what I was thinking, but never found that in Panelduet documentations, maybe it will be good to make a fresh install documentation, because I did read the page you send me, bu only when I plug and update the board before anything else...so I didn't see the panel M575 g-code.
          I will get a try right now !
          • toufou54undefined
            toufou54
            That's ok now it's working thanks again
              Phaedrux Moderator @toufou54
              Added a note in the PanelDue install for Duet3.
              sebkritikelundefined 1 Reply Last reply Reply Quote 0
              • sebkritikelundefined
                sebkritikel @Phaedrux
                @Phaedrux said in Brand new Paneldue 7 not connecting (RRF3):
                M575 P1 S1 B57600 is now applicable to Duet 2 as well
                Large(ish?) IDEX - 6HC, 1HCL
                Stratasys Dimension 1200es to 6HC Conversion
                  Phaedrux Moderator @sebkritikel
                  @sebkritikel Ah yes, thanks for pointing that out. It's a RRF3 change not specifically a Duet 3 change.
